4T175FA0
4T175FA0
    JWWINCO
    HEAVY DUTY VIBRATION MOUNT
4T175FA0 数据手册
MM 100 “Mighty Mount”™ Heavy Duty Vibration Mounts Steel, Fixed Threaded Stud Type, with Rubber Pad Inch | Metric 4 Type D With heavy duty pad Specification Information • Base High strength steel, safety yellow powder coated Similar to Barrymounts®, MM 100 “Mighty Mount”™ heavy duty vibration mounts are ideal for drill presses, grinders, CNC machines, die casting machines, punch presses, saws, and injection molding equipment. • Hexagon cap screw Steel -- Grade 8 -- Zinc plated -- Bolt is separate, screws into mount base -- Hexagon nut is included They offer a high level of shock and vibration isolation for an extended machinery life and reduce noise levels. • Vibration damping pad Elastomer rubber -- High density -- Non-skid • RoHS compliant They are sturdy, have a reliable construction and a safety yellow finish. The full inch of elastomer padding is oil resistant. To insure a proper vibration mount size, divide the machine weight by the number of mounts required. This will equal the pounds or load per mount. see also... • Vibration Damping Leveling Feet EN 248 • Anti-Vibration Leveling Mounts LP 100 / LP 100.1 • ”Anti-Vibe ®” Anti-Vibration Leveling Mounts AVM • ”Anti-Vibe ®” Anti-Vibration Leveling Mounts MAVM • Vibration Damping Leveling Feet GN 342.2 On request • For certain minimum quantities, other sizes and bolt lengths How to order (Inch) 1 2 3 4 MM100-2.00-1/4X28-1.75-D How to order (Metric) 1 2 3 4 MM100-5.00-M12-5.00-D 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Diameter d1 2 Thread d 2 3 Stud length l1 4 Type 1 Diameter d1 2 Thread d 2 3 Stud length l1 4 Type www.jwwinco.com | phone: 1-800-877-8351 MM 100 “Mighty Mount”™ Heavy Duty Vibration Mounts continued Inch table 1 2 3 d1 d2 l1 Dimensions in: inches - millimeters l2 h Load rating Thread min. max. 2.00 50.8 1/4 x 28 - 1.75 44.5 1.00 25.4 0.24 6.1 30.00 lbf 133.44 N 100.00 lbf 444.82 N 2.00 50.8 3/8 x 16 3/8 x 24 3.00 76.2 1.00 25.4 0.24 6.1 100.00 lbf 444.82 N 300 lbf 1334.46 N 3.00 76.2 3/8 x 16 3/8 x 24 3.00 76.2 1.50 38.1 0.39 9.9 100.00 lbf 444.82 N 300 lbf 1334.46 N 3.00 76.2 1/2 x 13 - 6.00 152.4 1.50 38.1 0.39 9.9 100.00 lbf 444.82 N 300 lbf 1334.46 N 5.00 127.0 1/2 x 13 - 5.00 127.0 1.50 38.1 0.47 11.9 500 lbf 2224.11 N 1500 lbf 6672.33 N 5.00 127.0 5/8 x 11 - 8.00 203.2 1.50 38.1 0.47 11.9 500 lbf 2224.11 N 1500 lbf 6672.33 N 6.00 152.4 1/2 x 13 3/4 x 10 5.00 127.0 1.73 43.9 0.43 10.9 1000 lbf 4448.22 N 4200 lbf 18682.53 N 6.00 152.4 3/4 x 10 - 8.00 203.2 1.73 43.9 0.43 10.9 1000 lbf 4448.22 N 4200 lbf 18682.53 N Metric table 1 2 3 d1 d2 l1 Dimensions in: millimeters - inches l2 h Load rating Thread min. 76.2 3.00 M 10 76.2 3.00 38.1 1.50 9.9 0.39 127.0 5.00 M 12 127.0 5.00 38.1 1.50 11.9 0.47 www.jwwinco.com | phone: 1-800-877-8351 444.82 N 100.00 lbf 2224.11 N 500 lbf max. 1334.46 N 300 lbf 6672.33 N 1500 lbf 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 3
4T175FA0 价格&库存
很抱歉,暂时无法提供与“4T175FA0”相匹配的价格&库存,您可以联系我们找货
