8TPTC
8TPTC
    JWWINCO
    THREADED TUBE END, PLASTIC
8TPTC 数据手册
SN 993 Threaded Tube Ends Plastic, Square Type, without Insert l2 t l1 Inch s2 d s1 Inch table Dimensions in: inches - millimeters 1 2 3 s1 s2 d V 1.50 V 1.39 3/8 x 16 1/2 x 13 5/8 x 11 V 1.50 V 1.27 3/8 x 16 1/2 x 13 V 2.00 V 1.90 3/8 x 16 V 2.00 V 1.81 3/8 x 16 Outer Inner l1 l2 t External diameter of tube Wall thickness of tube Comparable material gauge Load rating 3/4 x 10  1.72 43.7  0.33  8.4  1.00 25.4  1.50 38.1 0.065 1.7 16 ga. square   3500 lbf 15568 N 5/8 x 11 3/4 x 10  1.72 43.7  0.33  8.4  1.00 25.4  1.50 38.1 0.120 3.0 11 ga. square   3500 lbf 15568 N 1/2 x 13 5/8 x 11 3/4 x 10  1.72 43.7  0.33  8.4  1.00 25.4  2.00 50.8 0.065 1.7 16 ga. square   3500 lbf 15568 N 1/2 x 13 5/8 x 11 3/4 x 10  1.97 50.0  0.41 10.4  1.00 25.4  2.00 50.8 0.120 3.0 11-12 ga. square   3500 lbf 15568 N Thread Specification Information • Polyglass filled nylon, black SN 993 threaded tube ends support more weight than traditional brass insert tube ends, at a fraction of the cost. It’s an easy and cost-effective way to attach leveling mounts and glides to the tubes and pipes commonly used to construct frames, conveyor bases and industrial machinery. On request • Additional inch and metric thread sizes Use a plastic mallet or a similar tool, hammer the threaded tube end into the bottom of the tube and attach the mount. see also... • Threaded Tube Ends SN 992 (Round Type, without Insert) • Threaded Tube Ends EN 348 (Square Type, with Nickel Plated Brass Insert) • Threaded Tube Ends EN 448 (Square Type, with Nickel Plated Brass Insert) • Threaded Tube Ends GN 992 (Aluminum / Stainless Steel, Round or Square Type) How to order 1 2 3 SN 993-V2.00-V1.81-3/4X10 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Outer diameter s1 2 Inner diameter s 2 3 Thread d www.jwwinco.com | phone: 1-800-877-8351
8TPTC 价格&库存
很抱歉,暂时无法提供与“8TPTC”相匹配的价格&库存,您可以联系我们找货
