SN 993
Threaded Tube Ends
Plastic, Square Type, without Insert
l2
t
l1
Inch
s2
d
s1
Inch table
Dimensions in: inches - millimeters
1
2
3
s1
s2
d
V 1.50
V 1.39
3/8 x 16
1/2 x 13
5/8 x 11
V 1.50
V 1.27
3/8 x 16
1/2 x 13
V 2.00
V 1.90
3/8 x 16
V 2.00
V 1.81
3/8 x 16
Outer
Inner
l1
l2
t
External diameter
of tube
Wall thickness
of tube
Comparable
material gauge
Load rating
3/4 x 10
1.72
43.7
0.33
8.4
1.00
25.4
1.50
38.1
0.065
1.7
16 ga. square
3500 lbf
15568 N
5/8 x 11
3/4 x 10
1.72
43.7
0.33
8.4
1.00
25.4
1.50
38.1
0.120
3.0
11 ga. square
3500 lbf
15568 N
1/2 x 13
5/8 x 11
3/4 x 10
1.72
43.7
0.33
8.4
1.00
25.4
2.00
50.8
0.065
1.7
16 ga. square
3500 lbf
15568 N
1/2 x 13
5/8 x 11
3/4 x 10
1.97
50.0
0.41
10.4
1.00
25.4
2.00
50.8
0.120
3.0
11-12 ga. square 3500 lbf
15568 N
Thread
Specification
Information
• Polyglass filled nylon, black
SN 993 threaded tube ends support more weight than traditional brass insert tube ends, at a fraction of
the cost. It’s an easy and cost-effective way to attach leveling mounts and glides to the tubes and pipes
commonly used to construct frames, conveyor bases and industrial machinery.
On request
• Additional inch and metric thread sizes
Use a plastic mallet or a similar tool, hammer the threaded tube end into the bottom of the tube and
attach the mount.
see also...
• Threaded Tube Ends SN 992 (Round Type, without Insert)
• Threaded Tube Ends EN 348 (Square Type, with Nickel Plated Brass Insert)
• Threaded Tube Ends EN 448 (Square Type, with Nickel Plated Brass Insert)
• Threaded Tube Ends GN 992 (Aluminum / Stainless Steel, Round or Square Type)
How to order
1
2
3
SN 993-V2.00-V1.81-3/4X10
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Outer diameter s1
2
Inner diameter s 2
3
Thread d
www.jwwinco.com | phone: 1-800-877-8351
很抱歉,暂时无法提供与“8TPTD”相匹配的价格&库存,您可以联系我们找货
