SNSM
“SnapLock”™ Leveling Mounts
Steel / Stainless Steel
Threaded Stud Type, with Non-Skid Rubber Cap
Inch | Metric
Specification
4
• Base / threaded stud with ball end
-- Steel, yellow zinc plated ST
-- Stainless steel NI
European Standard No. 1.4305 (AISI 303)
Threaded stud with ball end, hardened and
machined from solid bar
• Rubber cap
Neoprene ®, non-skid
• RoHS compliant
Information
Unlike the standard glue-on non-skid elastomer pad, SNSM “SnapLock”™ leveling mounts offer a
unique snap-on elastomer cap that gives greater stability to non-skid application requirements. It is
especially durable when equipment needs to be moved or repositioned.
The mount swivels 7 1/2° to all sides of the center line to adjust to uneven surfaces.
The coupling nut is not recommended to use for installation. Use nut on tapped hole of 1 - 1 1/2 times
the thread diameter being used.
To insure a proper leveling mount size, divide the machine weight by the number of mounts required.
This will equal the pounds or load per mount.
The jam nut is a standard part of the assembly.
see also...
• ”SnapLock”™ Leveling Mounts TNSM (Tapped Socket Type)
On request
• Additional thread sizes
• Leveling Feet GN 343.2 (Steel, with or without Plastic / Rubber Cap)
• Leveling Feet GN 343.6 (Stainless Steel, with or without Plastic or Rubber Cap)
How to order (Inch)
1
2
3
4
SNSM-1.00-1/4X20-1.25-ST
How to order (Metric)
1
2
3
4
SNSM-2.50-M16-2.00-NI
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Base diameter d1
2
Thread d 2
3
Stud length l1
4
Material
1
Base diameter d1
2
Thread d 2
3
Stud length l1
4
Material
www.jwwinco.com | phone: 1-800-877-8351
SNSM “SnapLock”™ Leveling Mounts continued
Inch table
1
2
3
d1
d2
l1
Thread
Dimensions in: inches - millimeters
l2
l3
Cap height
A/F
Max. load
1.00
25.4
1/4 x 20
1.25
31.8
0.69
17.5
0.22
5.6
0.50
12.7
750 lbf
3336.16 N
1.00
25.4
1/4 x 20
2.50
63.5
0.69
17.5
0.22
5.6
0.50
12.7
750 lbf
3336.16 N
1.00
25.4
1/4 x 28
1.25
31.8
0.69
17.5
0.22
5.6
0.50
12.7
580 lbf
2579.96 N
1.25
31.8
5/16 x 18
2.00
50.8
0.88
22.4
0.22
5.6
0.63
16.0
1875 lbf
8340.41 N
1.25
31.8
5/16 x 18
4.00
101.6
0.88
22.4
0.22
5.6
0.63
16.0
1875 lbf
8340.41 N
1.25
31.8
3/8 x 16
2.00
50.8
0.88
22.4
0.22
5.6
0.63
16.0
2800 lbf
12455.02 N
1.25
31.8
3/8 x 16
4.00
101.6
0.88
22.4
0.22
5.6
0.63
16.0
2800 lbf
12455.02 N
1.25
31.8
3/8 x 24
2.00
50.8
0.88
22.4
0.22
5.6
0.63
16.0
2475 lbf
11009.34 N
1.88
47.8
1/2 x 13
2.00
50.8
1.12
28.4
0.31
7.9
0.75
19.1
3750 lbf
16680.83 N
1.88
47.8
1/2 x 13
4.00
101.6
1.12
28.4
0.31
7.9
0.75
19.1
3750 lbf
16680.83 N
1.88
47.8
1/2 x 20
2.00
50.8
1.12
28.4
0.31
7.9
0.75
19.1
3000 lbf
13344.66 N
2.50
63.5
5/8 x 11
2.00
50.8
1.25
31.8
0.37
9.4
0.88
22.4
4500 lbf
20016.99 N
2.50
63.5
5/8 x 11
4.00
101.6
1.25
31.8
0.37
9.4
0.88
22.4
4500 lbf
20016.99 N
2.50
63.5
5/8 x 18
2.00
50.8
1.25
31.8
0.37
9.4
0.88
22.4
3750 lbf
16680.83 N
3.00
76.2
3/4 x 10
2.00
50.8
1.50
38.1
0.54
13.7
1.06
26.9
5550 lbf
24687.63 N
3.00
76.2
3/4 x 10
4.00
101.6
1.50
38.1
0.54
13.7
1.06
26.9
5550 lbf
24687.63 N
3.00
76.2
3/4 x 16
2.00
50.8
1.50
38.1
0.54
13.7
1.06
26.9
4650 lbf
20684.23 N
Metric table
Dimensions in: millimeters - inches
1
2
3
d1
d2
l1
l2
25.4
1.00
M 8
31.8
1.25
17.5
0.69
5.6
0.22
12.7
0.50
3336.16 N
750 lbf
31.8
1.25
M 10
50.8
2.00
22.4
0.88
5.6
0.22
16.0
0.63
12455.02 N
2800 lbf
47.8
1.88
M 12
50.8
2.00
28.4
1.12
7.9
0.31
19.1
0.75
16680.83 N
3750 lbf
63.5
2.50
M 16
50.8
2.00
31.8
1.25
9.4
0.37
22.4
0.88
20016.99 N
4500 lbf
76.2
3.00
M 20
50.8
2.00
38.1
1.50
13.7
0.54
26.9
1.06
24687.23 N
5550 lbf
Thread
l3
Cap height
A/F
Max. load
3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements |
3
很抱歉,暂时无法提供与“5T2SNS”相匹配的价格&库存,您可以联系我们找货
