16N2SNT
16N2SNT
    JWWINCO
    SNAP LOCK LEVELING MOUNT
16N2SNT 数据手册
SNSM “SnapLock”™ Leveling Mounts Steel / Stainless Steel Threaded Stud Type, with Non-Skid Rubber Cap Inch | Metric Specification 4 • Base / threaded stud with ball end -- Steel, yellow zinc plated ST -- Stainless steel NI European Standard No. 1.4305 (AISI 303) Threaded stud with ball end, hardened and machined from solid bar • Rubber cap Neoprene ®, non-skid • RoHS compliant Information Unlike the standard glue-on non-skid elastomer pad, SNSM “SnapLock”™ leveling mounts offer a unique snap-on elastomer cap that gives greater stability to non-skid application requirements. It is especially durable when equipment needs to be moved or repositioned. The mount swivels 7 1/2° to all sides of the center line to adjust to uneven surfaces. The coupling nut is not recommended to use for installation. Use nut on tapped hole of 1 - 1 1/2 times the thread diameter being used. To insure a proper leveling mount size, divide the machine weight by the number of mounts required. This will equal the pounds or load per mount. The jam nut is a standard part of the assembly. see also... • ”SnapLock”™ Leveling Mounts TNSM (Tapped Socket Type) On request • Additional thread sizes • Leveling Feet GN 343.2 (Steel, with or without Plastic / Rubber Cap) • Leveling Feet GN 343.6 (Stainless Steel, with or without Plastic or Rubber Cap) How to order (Inch) 1 2 3 4 SNSM-1.00-1/4X20-1.25-ST How to order (Metric) 1 2 3 4 SNSM-2.50-M16-2.00-NI 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Base diameter d1 2 Thread d 2 3 Stud length l1 4 Material 1 Base diameter d1 2 Thread d 2 3 Stud length l1 4 Material www.jwwinco.com | phone: 1-800-877-8351 SNSM “SnapLock”™ Leveling Mounts continued Inch table 1 2 3 d1 d2 l1 Thread Dimensions in: inches - millimeters l2 l3 Cap height A/F Max. load 1.00 25.4 1/4 x 20 1.25 31.8 0.69 17.5 0.22 5.6 0.50 12.7 750 lbf 3336.16 N 1.00 25.4 1/4 x 20 2.50 63.5 0.69 17.5 0.22 5.6 0.50 12.7 750 lbf 3336.16 N 1.00 25.4 1/4 x 28 1.25 31.8 0.69 17.5 0.22 5.6 0.50 12.7 580 lbf 2579.96 N 1.25 31.8 5/16 x 18 2.00 50.8 0.88 22.4 0.22 5.6 0.63 16.0 1875 lbf 8340.41 N 1.25 31.8 5/16 x 18 4.00 101.6 0.88 22.4 0.22 5.6 0.63 16.0 1875 lbf 8340.41 N 1.25 31.8 3/8 x 16 2.00 50.8 0.88 22.4 0.22 5.6 0.63 16.0 2800 lbf 12455.02 N 1.25 31.8 3/8 x 16 4.00 101.6 0.88 22.4 0.22 5.6 0.63 16.0 2800 lbf 12455.02 N 1.25 31.8 3/8 x 24 2.00 50.8 0.88 22.4 0.22 5.6 0.63 16.0 2475 lbf 11009.34 N 1.88 47.8 1/2 x 13 2.00 50.8 1.12 28.4 0.31 7.9 0.75 19.1 3750 lbf 16680.83 N 1.88 47.8 1/2 x 13 4.00 101.6 1.12 28.4 0.31 7.9 0.75 19.1 3750 lbf 16680.83 N 1.88 47.8 1/2 x 20 2.00 50.8 1.12 28.4 0.31 7.9 0.75 19.1 3000 lbf 13344.66 N 2.50 63.5 5/8 x 11 2.00 50.8 1.25 31.8 0.37 9.4 0.88 22.4 4500 lbf 20016.99 N 2.50 63.5 5/8 x 11 4.00 101.6 1.25 31.8 0.37 9.4 0.88 22.4 4500 lbf 20016.99 N 2.50 63.5 5/8 x 18 2.00 50.8 1.25 31.8 0.37 9.4 0.88 22.4 3750 lbf 16680.83 N 3.00 76.2 3/4 x 10 2.00 50.8 1.50 38.1 0.54 13.7 1.06 26.9 5550 lbf 24687.63 N 3.00 76.2 3/4 x 10 4.00 101.6 1.50 38.1 0.54 13.7 1.06 26.9 5550 lbf 24687.63 N 3.00 76.2 3/4 x 16 2.00 50.8 1.50 38.1 0.54 13.7 1.06 26.9 4650 lbf 20684.23 N Metric table Dimensions in: millimeters - inches 1 2 3 d1 d2 l1 l2 25.4 1.00 M 8 31.8 1.25 17.5 0.69 5.6 0.22 12.7 0.50 3336.16 N 750 lbf 31.8 1.25 M 10 50.8 2.00 22.4 0.88 5.6 0.22 16.0 0.63 12455.02 N 2800 lbf 47.8 1.88 M 12 50.8 2.00 28.4 1.12 7.9 0.31 19.1 0.75 16680.83 N 3750 lbf 63.5 2.50 M 16 50.8 2.00 31.8 1.25 9.4 0.37 22.4 0.88 20016.99 N 4500 lbf 76.2 3.00 M 20 50.8 2.00 38.1 1.50 13.7 0.54 26.9 1.06 24687.23 N 5550 lbf Thread www.jwwinco.com | phone: 1-800-877-8351 l3 Cap height A/F Max. load 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 3
16N2SNT 价格&库存
很抱歉,暂时无法提供与“16N2SNT”相匹配的价格&库存,您可以联系我们找货
