TNSM
“SnapLock”™ Leveling Mounts
Steel / Stainless Steel
Tapped Socket Type, with Non-Skid Rubber Cap
Inch | Metric
Specification
3
• Base / tapped socket
-- Steel, yellow zinc plated ST
-- Stainless steel NI
European Standard No. 1.4305 (AISI 303)
Tapped socket, hardened
• Rubber cap
Neoprene ®, non-skid
• RoHS compliant
Information
Unlike the standard glue-on non-skid elastomer pad, TNSM “SnapLock”™ leveling mounts offer a
unique snap-on elastomer cap that gives greater stability to non-skid application requirements. It is
especially durable when equipment needs to be moved or repositioned.
These leveling mounts were developed for applications where the mount needs to be easily removed, a
longer than standard stud needs to be attached or the equipment already has a fixed stud on it.
The mount swivels 7 1/2° to all sides of the center line to adjust to uneven surfaces.
To insure a proper leveling mount size, divide the machine weight by the number of mounts required.
This will equal the pounds or load per mount.
see also...
• ”SnapLock”™ Leveling Mounts SNSM (Threaded Stud Type)
On request
• Leveling Feet GN 343.1 (Steel, with or without Plastic / Rubber Cap)
• Leveling Feet GN 343.5 (Stainless Steel, with or without Plastic / Rubber Cap)
• Additional thread sizes
How to order (Inch)
1
2
3
TNSM-1.00-1/4X20-ST
How to order (Metric)
1
2
3
TNSM-2.50-M16-NI
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Base diameter d1
2
Thread d 2
3
Material
1
Base diameter d1
2
Thread d 2
3
Material
www.jwwinco.com | phone: 1-800-877-8351
TNSM “SnapLock”™ Leveling Mounts continued
Inch table
1
2
d1
d2
Thread
Dimensions in: inches - millimeters
l1
l2
Cap height
A/F
t
Max. load
1.00
25.4
1/4 x 20
0.69
17.5
0.22
5.6
0.50
12.7
0.17
4.3
750 lbf
3336.16 N
1.00
25.4
1/4 x 28
0.69
17.5
0.22
5.6
0.50
12.7
0.17
4.3
750 lbf
3336.16 N
1.25
31.8
5/16 x 18
0.88
22.4
0.22
5.6
0.63
16.0
0.21
5.3
1875 lbf
8340.41 N
1.25
31.8
3/8 x 16
0.88
22.4
0.22
5.6
0.63
16.0
0.21
5.3
2800 lbf
12455.02 N
1.25
31.8
3/8 x 24
0.88
22.4
0.22
5.6
0.63
16.0
0.21
5.3
2475 lbf
11009.34 N
1.88
47.8
1/2 x 13
1.12
28.4
0.31
7.9
0.75
19.1
0.25
6.4
3750 lbf
16680.83 N
1.88
47.8
1/2 x 20
1.12
28.4
0.31
7.9
0.75
19.1
0.25
6.4
3000 lbf
13344.66 N
2.50
63.5
5/8 x 11
1.25
31.8
0.37
9.4
0.88
22.4
0.35
8.9
4500 lbf
20016.99 N
2.50
63.5
5/8 x 18
1.25
31.8
0.37
9.4
0.88
22.4
0.35
8.9
3750 lbf
16680.83 N
3.00
76.2
3/4 x 10
1.50
38.1
0.54
13.7
1.06
26.9
0.32
8.1
5550 lbf
24687.63 N
3.00
76.2
3/4 x 16
1.50
38.1
0.54
13.7
1.06
26.9
0.32
8.1
4650 lbf
20684.23 N
Metric table
Dimensions in: millimeters - inches
1
2
d1
d2
l1
25.4
1.00
M 8
17.5
0.69
31.8
1.25
M 10
47.8
1.88
A/F
t
5.6
0.22
12.7
0.50
4.3
0.17
3336.16 N
750 lbf
22.4
0.88
5.6
0.22
16.0
0.63
5.3
0.21
12455.02 N
2800 lbf
M 12
28.4
1.12
7.9
0.31
19.1
0.75
6.4
0.25
16680.83 N
3750 lbf
63.5
2.50
M 16
31.8
1.25
9.4
0.37
22.4
0.88
8.9
0.35
20016.99 N
4500 lbf
76.2
3.00
M 20
38.1
1.50
13.7
0.54
26.9
1.06
8.1
0.32
24687.63 N
5550 lbf
Thread
l2
Cap height
Max. load
3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements |
3
很抱歉,暂时无法提供与“5TTNT”相匹配的价格&库存,您可以联系我们找货
