10TTNS
10TTNS
    JWWINCO
    SNAP LOCK LEVELING MOUNT
10TTNS 数据手册
TNSM “SnapLock”™ Leveling Mounts Steel / Stainless Steel Tapped Socket Type, with Non-Skid Rubber Cap Inch | Metric Specification 3 • Base / tapped socket -- Steel, yellow zinc plated ST -- Stainless steel NI European Standard No. 1.4305 (AISI 303) Tapped socket, hardened • Rubber cap Neoprene ®, non-skid • RoHS compliant Information Unlike the standard glue-on non-skid elastomer pad, TNSM “SnapLock”™ leveling mounts offer a unique snap-on elastomer cap that gives greater stability to non-skid application requirements. It is especially durable when equipment needs to be moved or repositioned. These leveling mounts were developed for applications where the mount needs to be easily removed, a longer than standard stud needs to be attached or the equipment already has a fixed stud on it. The mount swivels 7 1/2° to all sides of the center line to adjust to uneven surfaces. To insure a proper leveling mount size, divide the machine weight by the number of mounts required. This will equal the pounds or load per mount. see also... • ”SnapLock”™ Leveling Mounts SNSM (Threaded Stud Type) On request • Leveling Feet GN 343.1 (Steel, with or without Plastic / Rubber Cap) • Leveling Feet GN 343.5 (Stainless Steel, with or without Plastic / Rubber Cap) • Additional thread sizes How to order (Inch) 1 2 3 TNSM-1.00-1/4X20-ST How to order (Metric) 1 2 3 TNSM-2.50-M16-NI 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Base diameter d1 2 Thread d 2 3 Material 1 Base diameter d1 2 Thread d 2 3 Material www.jwwinco.com | phone: 1-800-877-8351 TNSM “SnapLock”™ Leveling Mounts continued Inch table 1 2 d1 d2 Thread Dimensions in: inches - millimeters l1 l2 Cap height A/F t Max. load 1.00 25.4 1/4 x 20 0.69 17.5 0.22 5.6 0.50 12.7 0.17 4.3 750 lbf 3336.16 N 1.00 25.4 1/4 x 28 0.69 17.5 0.22 5.6 0.50 12.7 0.17 4.3 750 lbf 3336.16 N 1.25 31.8 5/16 x 18 0.88 22.4 0.22 5.6 0.63 16.0 0.21 5.3 1875 lbf 8340.41 N 1.25 31.8 3/8 x 16 0.88 22.4 0.22 5.6 0.63 16.0 0.21 5.3 2800 lbf 12455.02 N 1.25 31.8 3/8 x 24 0.88 22.4 0.22 5.6 0.63 16.0 0.21 5.3 2475 lbf 11009.34 N 1.88 47.8 1/2 x 13 1.12 28.4 0.31 7.9 0.75 19.1 0.25 6.4 3750 lbf 16680.83 N 1.88 47.8 1/2 x 20 1.12 28.4 0.31 7.9 0.75 19.1 0.25 6.4 3000 lbf 13344.66 N 2.50 63.5 5/8 x 11 1.25 31.8 0.37 9.4 0.88 22.4 0.35 8.9 4500 lbf 20016.99 N 2.50 63.5 5/8 x 18 1.25 31.8 0.37 9.4 0.88 22.4 0.35 8.9 3750 lbf 16680.83 N 3.00 76.2 3/4 x 10 1.50 38.1 0.54 13.7 1.06 26.9 0.32 8.1 5550 lbf 24687.63 N 3.00 76.2 3/4 x 16 1.50 38.1 0.54 13.7 1.06 26.9 0.32 8.1 4650 lbf 20684.23 N Metric table Dimensions in: millimeters - inches 1 2 d1 d2 l1 25.4 1.00 M 8 17.5 0.69 31.8 1.25 M 10 47.8 1.88 A/F t 5.6 0.22 12.7 0.50 4.3 0.17 3336.16 N 750 lbf 22.4 0.88 5.6 0.22 16.0 0.63 5.3 0.21 12455.02 N 2800 lbf M 12 28.4 1.12 7.9 0.31 19.1 0.75 6.4 0.25 16680.83 N 3750 lbf 63.5 2.50 M 16 31.8 1.25 9.4 0.37 22.4 0.88 8.9 0.35 20016.99 N 4500 lbf 76.2 3.00 M 20 38.1 1.50 13.7 0.54 26.9 1.06 8.1 0.32 24687.63 N 5550 lbf Thread www.jwwinco.com | phone: 1-800-877-8351 l2 Cap height Max. load 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 3
10TTNS 价格&库存
很抱歉,暂时无法提供与“10TTNS”相匹配的价格&库存,您可以联系我们找货
