1T32F33O
1T32F33O
    JWWINCO
    ADJ LEVER PLASTIC, STEEL 10-32
1T32F33O 数据手册
WN 300 Adjustable Levers Nylon Plastic, Threaded Stud Type, with Steel Components Inch | Metric Specification 1 5 • Lever body Plastic KT Nylon thermoplastic -- Glass fiber reinforced -- With molded-in stainless steel inlay -- Temperature resistant up to 230 °F (110 °C) • Color Black, RAL 9005, textured finish Orange, RAL 2004, textured finish Gray, RAL 7035, textured finish • Threaded stud / retaining screw Steel -- Blackened finish -- Tensile strength class 5.8 SW OS GS Information Made in the USA, WN 300 adjustable levers are the result of modern industrial design: glass fiber reinforced thermoplastic with molded-in stainless steel inlay. All such levers have proven to be ideal wherever parts have to be clamped in a confined space or in a particular lever position. The insert is connected to the lever via serrations that can easily be disengaged. Pulling the lever upwards disengages the serrations, allowing it to be swiveled to the ideal clamping position. When releasing the lever, the serrations automatically re-engage. see also... • Adjustable Levers WN 300 (Nylon Plastic, Tapped or Plain Bore Type) • Adjustable Levers GN 300 (Zinc Die-Cast, Threaded Stud Type) • Adjustable Levers WN 303 (Nylon Plastic, with Push Button, Threaded Stud Type) • Adjustable Levers GN 303 (Zinc Die-Cast, with Push Button, Threaded Stud Type) • RoHS compliant On request • Special colors, stud lengths, and threads How to order (Inch) 1 2 3 4 5 WN 300-KT-30-1/4X20-20-GS How to order (Metric) 1 2 3 4 5 WN 300-KT-63-M10-80-OS 8 | 2.1 Tensioning, Clamping, Switching with Levers 1 Material 2 Lever length l1 3 Thread d1 4 Thread length l 2 5 Color 1 Material 2 Lever length l1 3 Thread d1 4 Thread length l 2 5 Color www.jwwinco.com | phone: 1-800-877-8351 WN 300 Adjustable Levers continued Inch table 2 3 4 l1 d1 l2 Thread 1.18 30 10 x 32 1.18 30 10 x 24 1.18 30 1/4 x 20 1.77 45 10 x 32 1.77 45 10 x 24 1.77 45 1/4 x 20 2.48 63 1/4 x 20 2.48 63 5/16 x 18 2.48 63 3/8 x 16 3.07 78 3/8 x 16 3.07 78 1/2 x 13 3.62 92 3/8 x 16 3.62 92 1/2 x 13 10 Dimensions in: inches - millimeters d3 .39 12 10 12 10 12 12 16 16 16 16 16 h2 .39 .57 14.5 .96 24.5 4 .39 .57 14.5 .96 24.5 4 .39 .57 14.5 .96 24.5 4 .39 .57 14.5 .96 24.5 4 .39 .57 14.5 .96 24.5 4 .39 .57 14.5 .96 24.5 4 h3 h4 .16 1.20 30.5 .14 3.5 .16 1.20 30.5 .14 3.5 .16 1.20 30.5 .14 3.5 .16 1.38 35 .14 3.5 .16 1.38 35 .14 3.5 .16 1.38 35 .14 3.5 Stroke .79 20 .98 25 1.26 32 - - - .79 20 .98 25 1.26 32 - - - - .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 - .63 .79 20 .98 25 1.26 32 - - - .79 20 .98 25 1.26 32 - - - - .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 - .63 .79 20 .98 25 - - - - - .53 13.5 .76 19.4 1.22 31 .26 6.5 1.77 45 4 .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 1.97 50 2.48 63 .53 13.5 .76 19.4 1.22 31 .26 6.5 1.77 45 4 .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 1.97 50 2.48 63 - .53 13.5 .76 19.4 1.22 31 .26 6.5 1.77 45 4 .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 1.97 50 2.48 63 - .63 .87 22.2 1.42 36 8 .31 2.17 55 4 .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 1.97 50 - - .63 .87 22.2 1.42 36 8 .31 2.17 55 4 .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 1.97 50 2.48 63 - .75 .99 25.2 1.69 43 11 .43 2.56 65 4 .63 .79 20 .98 25 1.26 32 1.38 35 1.57 40 1.77 45 1.97 50 2.48 63 .75 .99 25.2 1.69 43 11 .43 2.56 65 4 .47 10 h1 .63 12 16 .39 12 .39 12 .47 16 .39 12 .47 16 .47 16 .47 d4 16 .63 .47 16 .47 16 .63 .47 16 10 10 10 10 10 10 16 16 19 19 .16 .16 .16 .16 .16 .16 .16 Metric table Dimensions in: millimeters - inches 2 3 4 l1 d1 l2 30 1.18 M 3 - 6 30 1.18 M 4 - 10 30 1.18 M 5 - 12 30 1.18 M 6 - 10 45 1.77 M 4 - 10 45 1.77 M 5 - 12 45 1.77 M 6 - 10 63 2.48 M 6 - 12 63 2.48 M 8 - 12 63 2.48 M 10 - 16 78 3.07 M 8 M 10 16 78 3.07 M 12 - 25 92 3.62 M 10 M 12 16 Thread .24 .39 .47 .39 .39 .47 .39 .47 .47 .63 .63 .98 .63 8 12 .47 16 12 12 16 12 16 16 20 20 .31 .63 .47 .47 .63 .47 .63 .63 .79 10 24.5 .96 4 .39 14.5 .57 24.5 .96 4 30.5 1.20 3.5 .14 .39 14.5 .57 24.5 .96 4 .16 30.5 1.20 3.5 .14 .39 14.5 .57 24.5 .96 4 .16 30.5 1.20 3.5 .14 .39 14.5 .57 24.5 .96 4 .16 35 1.38 3.5 .14 .39 14.5 .57 24.5 .96 4 .16 35 1.38 3.5 .14 - 10 32 1.26 40 1.57 50 1.97 - - 10 25 .98 32 1.26 40 1.57 45 1.77 50 1.97 10 .98 32 1.26 - - - 10 32 1.26 40 1.57 50 1.97 - - 10 25 .98 32 1.26 40 1.57 45 1.77 50 1.97 10 .39 14.5 .57 24.5 .96 4 .16 35 1.38 3.5 .14 .98 32 1.26 40 1.57 50 1.97 63 2.48 - 13.5 .53 19.4 .76 31 1.22 6.5 .26 45 1.77 4 .98 32 1.26 40 1.57 45 1.77 50 1.97 63 2.48 13.5 .53 19.4 .76 31 1.22 6.5 .26 45 1.77 4 .98 32 1.26 40 1.57 45 1.77 50 1.97 63 2.48 80 3.15 13.5 .53 19.4 .76 31 1.22 6.5 .26 45 1.77 4 40 1.57 45 1.77 50 1.97 63 2.48 80 3.15 16 .63 22.2 .87 36 1.42 8 55 2.17 4 .63 22.2 .87 36 1.42 8 .31 55 2.17 4 .75 25.2 .99 43 1.69 11 .43 65 2.56 4 .79 .63 .63 .79 .63 .79 .79 25 20 20 25 20 25 25 .98 .79 .79 .98 .79 25 25 .98 40 1.57 50 1.97 63 2.48 80 3.15 - - - 16 20 25 32 1.26 40 1.57 45 1.77 50 1.97 63 2.48 80 3.15 19 www.jwwinco.com | phone: 1-800-877-8351 .16 - .79 32 1.26 .79 3.5 .14 Stroke - 20 .63 32 1.26 .79 .16 30.5 1.20 32 1.26 20 25 .39 14.5 .57 .98 .63 16 25 h4 10 16 20 h3 - 20 20 h2 - 16 16 h1 - .47 16 d4 - .39 12 d3 .98 .31 2.1 Tensioning, Clamping, Switching with Levers | .16 .16 .16 .16 .16 .16 9
1T32F33O
- 物料型号: WN 300 Adjustable Levers - 器件简介: JWWINCO A Ganter Company生产的可调杠杆,采用玻璃纤维增强的热塑性塑料,内嵌不锈钢,适用于狭窄空间或特定杠杆位置的部件夹持。 - 引脚分配: 螺纹型或平面型,螺纹尺寸从M3到M12不等。 - 参数特性: 包括杠杆体材料、塑料KT、尼龙热塑性塑料、玻璃纤维增强、内嵌不锈钢、耐高温达230°F(110°C)、颜色选项、螺纹型/保持螺丝材料等。 - 功能详解: 杠杆通过可分离的锯齿连接,向上拉动杠杆可释放锯齿,旋转至理想夹紧位置,释放后锯齿自动重新接合。 - 应用信息: 适用于需要张力、夹紧或开关操作的场合。 - 封装信息: 提供了详细的尺寸表,包括英寸和毫米单位,以及如何根据英寸和公制单位进行订购。
1T32F33O 价格&库存
很抱歉,暂时无法提供与“1T32F33O”相匹配的价格&库存,您可以联系我们找货
