3TS33K
3TS33K
    JWWINCO
    ADJ LEVER PLASTIC, STAINLESS 1/4
3TS33K 数据手册
WN 300.1 Adjustable Levers Nylon Plastic, Tapped or Plain Bore Type, with Stainless Steel Components Inch | Metric Specification 1 4 • Lever body Plastic KT Nylon thermoplastic -- Glass fiber reinforced -- With molded-in stainless steel inlay -- Temperature resistant up to 230 °F (110 °C) • Color Black, RAL 9005, textured finish Orange, RAL 2004, textured finish Gray, RAL 7035, textured finish • Insert / retaining screw Stainless steel European Standard No. 1.4305 (AISI 303) • RoHS compliant SW OS GS Information Made in the USA, WN 300.1 adjustable levers are the result of modern industrial design: glass fiber reinforced thermoplastic with molded-in stainless steel inlay. All such levers have proven to be ideal wherever parts have to be clamped in a confined space or in a particular lever position. The insert is connected to the lever via serrations that can easily be disengaged. Pulling the lever upwards disengages the serrations, allowing it to be swiveled to the ideal clamping position. When releasing the lever, the serrations automatically re-engage. see also... • Adjustable Levers WN 300.1 (Nylon Plastic, Threaded Stud Type) • Adjustable Levers GN 300.1 (Zinc Die-Cast, Tapped or Plain Bore Type) • Adjustable Levers GN 300.5 (Stainless Steel, Matte Shot-Blasted Finish) • Adjustable Levers WN 303.1 (Nylon Plastic, with Push Button, Tapped or Plain Bore Type) • Adjustable Levers GN 303.1 (Zinc Die-Cast, with Push Button, Tapped Type) On request • Special colors, bores, and threads How to order (Inch) 1 2 3 4 WN 300.1-KT-45-10X32-OS How to order (Metric) 1 2 3 4 WN 300.1-KT-92-M12-SW 18 | 2.1 Tensioning, Clamping, Switching with Levers 1 Material 2 Lever length l1 3 Thread d1 (Bore d 2 ) 4 Color 1 Material 2 Lever length l1 3 Thread d1 (Bore d 2 ) 4 Color www.jwwinco.com | phone: 1-800-877-8351 WN 300.1 Adjustable Levers continued Inch table 2 3 l1 d1 Dimensions in: inches - millimeters 3 d 2 +0.001 Thread d3 Bore 1.18 30 10 x 32 10 x 24 1/4 x 20 B 1/4 - 1.77 45 10 x 32 10 x 24 1/4 x 20 B 1/4 - 2.48 63 1/4 x 20 5/16 x 18 - B 1/4 B 5/16 3.07 78 5/16 x 18 3/8 x 16 - B 5/16 B 3/8 3.62 92 3/8 x 16 1/2 x 13 - B 3/8 B 1/2 d4 h1 .39 .57 14.5 .96 24.5 4 .39 .57 14.5 .96 24.5 4 .53 13.5 .76 19.4 .63 .75 10 10 16 19 h2 h3 h4 .16 1.20 30.5 .14 3.5 9 .16 1.38 35 .14 3.5 9 1.22 31 .26 6.5 1.77 45 4 .87 22.2 1.42 36 8 .31 2.17 55 4 .99 25.2 1.69 43 11 .43 2.56 65 4 Stroke .16 .16 .16 t min. 11 14 17 .35 .35 .43 .55 .67 Metric table 2 3 l1 d1 30 1.18 M 3 - - - 30 1.18 M 4 M 5 M6 45 1.77 M 4 M 5 63 2.48 M 6 78 3.07 92 3.62 Dimensions in: millimeters - inches 3 d 2 H7 Bore d3 d4 h1 - 10 .39 14.5 .57 24.5 .96 4 B 5 B 6 10 .39 14.5 .57 24.5 .96 4 M6 B 6 - 10 .39 14.5 .57 24.5 .96 4 M 8 - B 6 B 8 13.5 .53 19.4 .76 31 1.22 M 8 M 10 - B 8 B 10 16 .63 22.2 .87 M 10 M 12 - B 10 B 12 19 .75 25.2 .99 Thread www.jwwinco.com | phone: 1-800-877-8351 h2 h3 h4 .16 30.5 1.20 3.5 .14 7 .16 30.5 1.20 3.5 .14 9 .16 35 1.38 3.5 .14 9 6.5 .26 45 1.77 4 36 1.42 8 .31 55 2.17 4 43 1.69 11 .43 65 2.56 4 Stroke .16 .16 .16 t min. 11 14 17 .28 .35 .35 .43 .55 .67 2.1 Tensioning, Clamping, Switching with Levers | 19
3TS33K 价格&库存
很抱歉,暂时无法提供与“3TS33K”相匹配的价格&库存,您可以联系我们找货
