WN 580
Lifting Eye Bolts
Steel
Inch
d3
k
l
h
d4
d1
d2
Inch table
1
Dimensions in: inches - millimeters
2
d1
Lenght l
d2
d3
d4
h
k
Load bearing capacity
1/4 x 20
1.00
25.4
0.50 - 0.56
1.19
30.2
0.75
19.1
1.38
35.1
0.19 - 0.25
500 lbf
2224 N
5/16 x 18
1.125
28.6
0.56 - 0.62
1.44
36.6
0.88
22.4
1.69
42.9
0.25 - 0.31
900 lbf
4003 N
3/8 x 16
1.25
31.8
0.62 - 0.69
1.69
42.9
1.00
25.4
2.00
50.8
0.31 - 0.38
1300 lbf
5783 N
1/2 x 13
1.50
38.1
0.88 - 0.94
2.13
54.1
1.19
30.2
2.47
62.7
0.44 - 0.50
2400 lbf
10676 N
5/8 x 11
1.75
44.5
1.00 - 1.06
2.56
65.0
1.38
35.1
3.00
76.2
0.56 - 0.62
4000 lbf
17793 N
3/4 x 10
2.00
50.8
1.12 - 1.25
2.81
71.4
1.50
38.1
3.25
82.6
0.62 - 0.69
5000 lbf
22241 N
7/8 x 9
2.25
57.2
1.13 - 1.44
3.19
81.0
1.69
42.9
3.75
95.3
0.75 - 0.81
7000 lbf
31137 N
1 x 8
2.50
63.5
1.50 - 1.62
3.56
90.4
1.81
46.0
4.13
104.9
0.88 - 0.94
9000 lbf
40034 N
Thread
Specification
• Carbon steel 1030, ASTM A489
-- Forged
-- Zinc plated
3
ST
Information
When installing WN 580 lifting eye bolts, it is of utmost importance to ensure that the face is in firm
contact with the mating surface.
Do not apply load across the face of the ring!
The values given in the table are only applicable when the component attached to the ring is steel, cast
steel, or cast iron, and is fastened securely to the mating surface.
The load bearing capacity in the table is for straight vertical loading. The capacity is drastically reduced
when loading at any angle. Loading must never be made at an angle greater than 45° from the bolt
centerline. At an angle of 45°, the load bearing capacity is reduced to 1/4 of the value in the table.
Lifting eye meets MS51937 specification.
see also...
• Lifting Eye Nuts WN 583
• Lifting Eye Bolts DIN 580 (Metric Size)
• Safety Swivel Lifting Eye Bolts GN 581 (Metric Size)
How to order
1
2
3
WN 580-3/4X10-2.00-ST
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Thread d1
2
Length l
3
Material
www.jwwinco.com | phone: 1-800-877-8351
很抱歉,暂时无法提供与“580-1/4X20-1.00-ST”相匹配的价格&库存,您可以联系我们找货
