717.10-0.375-5/8X11-A-ST
    JWWINCO
    STEEL PULL RING SPRING PLUNGER
717.10-0.375-5/8X11-A-ST 数据手册
WN 717.10 Stubby Hand Retractable Spring Plungers Steel / Stainless Steel Non Lock-Out, with Pull Ring Inch 3 Type A Without thread locking patch Inch table Dimensions in: inches - millimeters 1 2 d1 d2 d3 l1 l2 l3 Initial End  .156 4.0 1/4 x 20   .87 22.1   .64 16.3   .17  4.3   .31  7.9   .50 lbf 2.22 N   2.00 lbf   8.90 N  .250 6.4 3/8 x 16   .87 22.1   .83 21.1   .27  6.9   .44 11.2   .75 lbf 3.34 N   3.00 lbf 13.34 N  .312 7.9 1/2 x 13  1.00 25.4  1.08 27.4   .34  8.6   .56 14.2 1.00 lbf 4.45 N   4.00 lbf 17.79 N  .375 9.5 5/8 x 11  1.20 30.5  1.35 34.3   .42 10.7   .69 17.5 1.12 lbf 5.00 N   5.00 lbf 22.24 N Thread Specification • Threaded body 12L14 steel, zinc plated -- Plunger pin Case-hardened steel, zinc plated -- Pull ring Spring steel, zinc plated • Threaded body / plunger pin / pull ring Stainless steel European Standard No. 1.4305 (AISI 303) 4 ST Spring load ≈ Information WN 717.10 stubby hand retractable spring plungers are ideal for indexing / locating pin applications with limited space. see also... • List of Indexing Plunger Types NI • RoHS compliant On request • Thread locking patch How to order 1 2 3 4 WN 717.10-0.312-1/2X13-A-ST 2 | 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements 1 Pin diameter d1 2 Thread d 2 3 Type 4 Material www.jwwinco.com | phone: 1-800-877-8351
717.10-0.375-5/8X11-A-ST 价格&库存
很抱歉,暂时无法提供与“717.10-0.375-5/8X11-A-ST”相匹配的价格&库存,您可以联系我们找货
