FRC16C1J470JTP
FRC16C1J470JTP
    KAMAYA(釜屋电机)
    47 Ohms ±5% 0.063W,1/16W 芯片电阻 0603(1608 公制) 易熔,安全
FRC16C1J470JTP 数据手册
Spec. No.: Date: FRC−K−HTS−0001 2017. 1. 10 /8 Sp e c i f i c a t i o n Title: CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE Style: FRC16, 20, 32 RoHS COMPLIANCE ITEM Halogen and Antimony Free Product specification contained in this specification are subject to change at any time without notice If you have any questions or a Purchasing Specification for any quality Agreement is necessary, please contact our sales staff. Hokkaido Research Center Approval by: T. Sannomiya Drawing by: M. Shibuya Note: Stock conditions Temperature: +5°C ∼ +35°C Relative humidity: 25% ∼ 75% The period of guarantee: Within 2 year from shipmen t by the company. Solderability shall be satisfied. Drawing No: Title: FRC−K−HTS−0001 CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE FRC16, 20, 32 Page: /8 1/9 1. Scope 1.1 This specification covers the detail requirements for chip fusible resistors; rectangular type, style of FRC16, 20,32. 1.2 Applicable documents JIS C 5201: 1994, JIS C 5202: 1990 2. Classification Type designation shall be the following form. (Example) FRC 20 2A C 2 3 4 1 Style 1 Chip fusible resistors; rectangular type 2 Size 3 Characteristics symbol Symbol 4 Rated dissipation 1J 2A 2B 100 5 J 6 TP 7 Style Rated dissipation 0.063W 0.1W 0.125W 5 Rated resistance 100 E24 Series,3 digit, EX. 100-->10Ω 6 Tolerance on rated resistance J ±5% 7 Packaging form B TP Bulk (loose package) Paper taping 3. Rating 3.1 The ratings shall be in accordance with Table−1. FRC16 FRC20 Rated dissipation (W) 0.063 0.1 FRC32 0.125 Style Style FRC16 FRC20 FRC32 Limiting element voltage (V) 1.79 2.26 3.53 Table−1 Temperature coefficient of Rated resistance resistance (10−6 /°C) range(Ω) ± 500 3.9~51 ± 1000 1.0~51 ± 500 56~100 ± 1000 1.0~51 Max. overload voltage(V) 3.58 4.52 7.06 Symbol C Preferred number series for resistors Tolerance on rated resistance E24 J(±5%) Fusing characteristics Fusing power Fusing time (W) (s.) 1.89 2.0 30 max. 2.5 Operating temperature range(°C) −55~+125 Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: Title: FRC−K−HTS−0001 CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE FRC16, 20, 32 Page: /8 2/9 3.2 Derating The derated values of dissipation at temperature in excess of 70 °C shall be as indicated by the following curve. 100 Percentage of the rated Area of recommended operation dissipation (%) 0 −55 70 125 Ambient temperature (°C) Figure–1 Derating curve 3.3 Rated voltage d.c.or a.c.r.m.s.voltage calculated from the square root of the product of the rated resistance and the rated dissipation. E: Rated voltage (V) E = P · R P: Rated dissipation (W) R: Rated resistance (Ω) Max. overload voltage can only be applied to resistors when the resistance value is equal to or higher than the critical resistance value. At high value of resistance, the rated voltage may not be applicable. 4. Packaging form The standard packaging form shall be in accordance with Table−2. Table−2 Symbol Packaging form B Bulk (loose package) TP Paper taping 8mm width, 4mm pitches Standard packaging quantity / units 1,000 pcs. 5,000 pcs. Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: Title: FRC−K−HTS−0001 CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE FRC16, 20, 32 Page: /8 3/9 5. Dimensions 5.1 The resistor shall be of the design and physical dimensions in accordance with Figure−2 and Table−3. W L c d d H c Figure−2 Table−3 Style FRC16 FRC20 FRC32 L 1.6 ± 0.1 2.0 ± 0.1 3.2 ± 0.2 W 0.8 +0.15 −0.05 1.25 ± 0.10 1.6 ± 0.15 H 0.45 ± 0.10 0.6 ± 0.1 0.6 ± 0.1 C 0.3 ± 0.1 0.4 ± 0.2 0.5 ± 0.25 Unit: mm d 0.3 ± 0.1 0.4 ± 0.2 0.5 ± 0.25 5.2 Net weight (Reference) Style Net weight(mg) FRC16 2.2 FRC20 6 FRC32 10 6. Marking The Rated resistance shall be marked in 3 digits (E24) and marked on over coat side. (Example) “ 100 ” → 10 ×10 0 [Ω] → 10 [Ω] Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: Title: CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE FRC16, 20, 32 FRC−K−HTS−0001 Page: /8 4/9 7. Performance 7.1 The standard condition for tests shall be in accordance with Sub−clause 3, JIS C 5202: 1990. 7.2 The performance shall be satisfied in Table−4. Table−4(1) No. Test items Condition of test (JIS C 5202) Performance requirements 1 Resistance Within the specified tolerance of Sub−clause 5.1 rated resistance. Classification of test voltage: A 2 Temperature Sub−clause 5.2 See Table−1. characteristic of The resistor shall be mounted on the test substrate resistance as shown in Figure−3−2. Test resistance shall be measured at the room temp. and temp. about 100 °C higher than the room temp.. 3 Short time overload Sub−clause 5.5 Within ± (5%+0.1Ω) The resistor shall be mounted on the test substrate No evidence of appearance damage as shown in Figure−3−2. Test potential: 2 times rated voltage. Test period: 5 s. Test potential should not exceed limiting element voltage as shown in Table−1. 4 Insulation resistance Sub−clause 5.6 1,000MΩ min. The resistor shall be fixed on the test fixture as shown in Figure−5 Test potential: FRC16:100Vdc FRC20,32: 500Vdc Test period: 1 min. No flashover, fire and breakdown. 5 Voltage proof Sub−clause 5.7 The resistor shall be fixed on the test fixture as shown in Figure−5 Test condition: Normal pressure Test potential: FRC16: 100Vac FRC20,32: 500Vac +10 Test period: 60 0 s. 6 Fusing characteristic Characteristics: C Sub−clause 8.6 of EIAJ RC−2124 The resistor shall be mounted on the test substrate •Fusing time: 30 s. max. as shown in Figure−3−1. •The remaining resistance shall be Fusing power; FRC16: 1.89W exceeded more than 50 times FRC20: 2.0W against initial resistance. FRC32: 2.5W •No smoke and arc. Test condition: No draught over the resistors. The voltage which corresponds to fusing power shall be applied until fusing. After the fusing tests, the remaining resistance shall be measured according to No.1. 7 Bond strength of the face Sub−clause 6.1.4(1) Within ±1% plating The resistor shall be mounted on the test substrate No evidence of mechanical damage as shown in Figure−4. Bending value: 5 mm (Among the fulcrums: 90 mm) Duration: 10±1 s Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: Title: No. 8 9 Test items Vibration Solderability 11 Temperature cycling 13 Page: /8 5/9 Table−4(2) Condition of test (JIS C 5202) Performance requirements Within ±1% Sub−clause 6.3 The resistor shall be mounted on the test substrate No evidence of mechanical damage as shown in Figure−3−2. Class of vibration: A 3 directions perpendicular to the above and to each other. Duration of vibration: 2h in each directions. Resistance to soldering Sub−clause 6.10 Within ±3% heat No evidence of appearance Test by a piece. damage Temp. of solder bath: 260 °C ± 5 °C Immersion time: 10 s ± 1 s After immersion into solder, leaving at the room temp. for 1h or more and then measure the resistance. 10 12 FRC−K−HTS−0001 CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE FRC16, 20, 32 Load life in humidity Endurance at 70 °C Sub−clause 6.11 Test by a piece. Flux: Rosin−Methanol Temp. of solder bath: 235 °C ± 5 °C Immersion time: 2 s ± 0.5 s Sub−clause 7.4 The resistor shall be mounted on the test substrate as shown in Figure−3−2. Test cycle: 5 cycles for duty cycle as specified below. Step Time (min) Temperature (°C) 1 Room temp. 2∼3 2 30 −55±3 3 Room temp. 2∼3 4 30 125±2 Sub−clause 7.9 The resistor shall be mounted on the test substrate as shown in Figure−3−2. Test temp. & relative humidity: 40 °C ± 2 °C & 90∼95 % Test voltage: Cycle of 1 h 30 min. “ON” and 30 min. “OFF” at dc rated voltage. Test period: 1,000 +48 0 h Sub−clause 7.10 The resistor shall be mounted on the test substrate as shown in Figure−3−2. Test temp. & relative humidity: 70 °C ± 2 °C Test voltage: Cycle of 1 h 30 min. “ON” and 30 min. “OFF” at dc rated voltage. Test period: 1,000 +48 0 h The surface of terminal immersed shall be min. of 95% covered with a new coating of solder. Within ±5% No evidence damage of appearance Within ±5% No evidence damage of appearance Within ±5% No evidence damage of appearance Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: Title: FRC−K−HTS−0001 CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE FRC16, 20, 32 Page: /8 6/9 8. Test substrate :Copper clad :Solder resist d e f 5 g Unit:mm 25 5 g f e d a b c 5.08 5.08 3 55 Style a b FRC16 1.0 3.6 FRC20 1.2 4.0 FRC32 2.2 5.0 FRC TEST SUBSTRATE Figure−3−1 Remark 1). Material: Epoxide woven glass Thickness: 1.6mm Thickness of copper clad: 0.035mm c 1.0 1.65 2.0 d 7.0 6.9 6.4 e 5.7 5.5 5.0 f 1.25 1.25 0.75 g 3.75 3.75 4.25 Unit: mm Soldering land :Copper clad :Solder resist 2.5 7.5 5 30 5 4 3.5 2 2.5 2.5 8 1.5 1.5 2 2 2 4 2.5 49 FRC32 TEST SUBSTRATE Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: Title: FRC−K−HTS−0001 CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE FRC16, 20, 32 Page: /8 7/9 Unit: mm c Soldering land a :Solder resist 7.5 5.5 b 25 d 3.5 3 :Copper clad 2.5 5.08 5.08 3 Style FRC16 FRC20 58.5 a 1.0 1.2 b 3.6 4.0 c 1.0 1.5 d 4.5 4.3 FRC16, 20 TEST SUBSTRATE Figure−3−2 Remark 1). Material: Epoxide woven glass Thickness: 1.6mm Thickness of copper clad: 0.035mm 2). In the case of connection by connector, the connecting terminals are gold plated. However, the plating is not necessary when the connection is made by soldering. Unit: mm :Copper clad d 1 :Solder resist 4.5 40 d c a Style a FRC16 1.0 Soldering land 70 FRC20 1.2 100 FRC32 2.5 FRC BOUND STRENGTH OF THE END FACE PLATING TEST SUBSTRATE Figure−4 Remark 1). Material: Epoxide woven glass Thickness: 1.6mm Thickness of copper clad: 0.035mm b b 3.6 4.0 5.0 c 1.2 1.65 2.0 d 3.0 3.0 2.5 Insulation plate Metal block measurement Point A Metal plate R0.5mm Measurement point B Insulation surface Component Pressure by spring (1±0.2N) Figure−5 Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: Title: FRC−K−HTS−0001 CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE FRC16, 20, 32 Page: /8 8/9 9. Taping 9.1 Applicable documents JIS C 0806−3: 2014, EIAJ ET−7200C: 2010 9 2 Taping dimensions Paper taping (8mm width, 4mm pitches) Taping dimensions shall be in accordance with Figure−6 and Table−5. Unit: mm 4±0.1 t 1 φ1.5 Sprocket hole +0.1 0 2±0.05 1.75±0.1 B 8±0.2 A t 2 Carrier cavity 4±0.1 3.5±0.05 Direction of unreeling Style FRC16 FRC20 FRC32 A 1.15± 0.15 1.65 ± 0.15 2.00 ± 0.15 Figure−6 Table−5 B 1.9±0.2 2.5 ± 0.2 3.6 ± 0.2 t1 0.6±0.1 Unit: mm t2 0.8max. 0.8 ± 0.1 1.0max. 1). The cover tapes shall not cover the sprocket holes. 2). Tapes in adjacent layers shall not stick together in the packing. 3). Components shall not stick to the carrier tape or to the cover tape. 4). Pitch tolerance over any 10 pitches ±0.2mm. 5). The peel strength of the top cover tape shall be with in 0.1N to 0.5N on the test method as shown in the following Figure−7. 6). When the tape is bent with the minimum radius for 25 mm, the tape shall not be damaged and the components shall maintain their position and orientation in the tape. 7). In no case shall there be two or more consecutive components missing. The maximum number of missing components shall be one or 0.1%, whichever is greater. 8). The resistors shall be faced to upward at the over coating side in the carrier cavity. Top cover tape Carrier tape 165°to180° Peel−off ( About 300mm/ min) Direction of unreeling Figure−7 Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: Title: FRC−K−HTS−0001 CHIP FUSIBLE RESISTORS; RECTANGULAR TYPE FRC16, 20, 32 Page: /8 9/9 9.3 Reel dimension Reel dimensions shall be in accordance with the following Figure−8 and Table−6. Plastic reel (Based on EIAJ ET−7200C) Unit: mm 0     +1 φ60      0 φ13±0.2 2±0.5 φ180 −1.5 Marking A φ21±0.8 Marking B A B Figure−8 Table−6 Unit: mm B Note 11.4±1.0 Injection molding FRC16, 20, 32 9 +1.0 0 13±1.0 Vacuum forming Note: Marking label shall be marked on a place of Marking A or two place of marking A and B. Style A 9.4 Leader and trailer tape. 400mm min. 100mm min. 160mm min. End Start Trailer Leader Direction of unreeling Figure−9 10. Marking on package The label of a minimum package shall be legibly marked with follows. 10.1 Marking A (1) Classification (Style, Characteristics symbol, Rated dissipation Rated resistance, Tolerance on rated resistance, Packaging form) (2) Quantity (3) Lot number (4) Manufacturer’s name or trade mark 10.2 Marking B(KAMAYA control label) (5) Others Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10
FRC16C1J470JTP 价格&库存
很抱歉,暂时无法提供与“FRC16C1J470JTP”相匹配的价格&库存,您可以联系我们找货
