2766
2766
    KITRONIK
    ELECTRO-FASHION, LED BOARD YELLO
2766 数据手册
ELECTRO-FASHION HOLDERS, SWITCHES & LEDs 113 E-TEXTILES SEWABLE PCB LEDs These ultra slim, pre-mounted LEDs are illuminated continuously. They have connections to which the conductive thread can be connected. These are clearly marked with ‘+’ and ‘-’ to indicate which is the positive and which is the negative connection. The PCBs are double sided making the thread connection very reliable. They are supplied on a small panel and the LEDs can easily be removed by snapping them out. Dimensions: L15 x W6.5 x H3mm Description Colour Code LED board - 10 pack White 2714 LED board - 10 pack Red 2712 LED board - 10 pack Green 2723 LED board - 10 pack Blue 2713 LED board - 10 pack Sakura (lilac) 2726 LED board - 10 pack Orange NEW! 2765 LED board - 10 pack Yellow NEW! 2766 1+ 10+ THROUGH HOLE LED HOLDERS Dimensions: L18 x W7.5mm These sewable LED holders make it easy to add a compatible 5mm through hole LED to an e-textiles project. The boards have two large sewable pads to which the conductive thread can be connected and these are clearly labelled with '+' and '-' symbols. Just slide the legs of the chosen LED through the holes in the middle of the board (making sure it matches the outline on the PCB) and solder into place. Supplied in a panel of 10. Requires soldering. Description Code Through hole LED holders - 10 pack 2746 1+ 10+ 5MM FLASHING LED These flashing LEDs can be used with the Electro-Fashion coin cell power boards. 5mm flashing LEDs in white, red, green, blue and yellow. The LEDs flash at around 2Hz when connected to a 5V supply. Colour Code White 3592 Red 3538 Green 3539 Blue 3545 Yellow 3540 1+ W: www.kitronik.co.uk 10+ 100+ 1000+ E: sales@kitronik.co.uk
很抱歉,暂时无法提供与“2766”相匹配的价格&库存,您可以联系我们找货
  • 15+61.1759015+7.92442
