Connectors & Cables
PACK OF 10
CLIP WIRES
PACK OF 5
STACKABLE LEADS
Pack of ten wires in a
selection of five colours each
with insulated crocodile clips
on both ends. (Lead length
0.5m, max current 0.5 Amp)
0.5m length extra-flexible
40/0.1mm wire (o/d 3mm) with
stackable 4mm plug at
each end.
Code
1+
2407
Description
Code
Red leads - 5 pack
2408
Black leads - 5 pack
2409
1+
DC POWER PLUG
9V PP3 BATTERY CLIP LEAD
TO 2.1MM DC CONNECTOR
This 2.1mm DC jack plug
has a screw-off hood, which
allows access to the solder
connection so that a lead can
be made to your requirements.
Versatile PP3 adaptor: plug
a 9V battery into one end
and connect the other end
to anything with a 2.1mm,
centre-positive barrel jack.
Code
1+
10+
100+
4123
Code
1+
10+
4132
USB TO DC JACK
CROCODILE CLIP
Components
This cable adapts from a USB
port to a 5.5x2.1mm barrel
connector, center positive,
allowing a USB port to provide
development boards with 5V.
Code
1+
4120
A 50mm crocodile clip, with a
4mm socket. Screw or solder
connection. Pack of 25.
Code
1+
2422
USB CABLE A TO B
USB TYPE-A TO
MICRO-B USB CABLE
Standard issue USB 2.0 cables.
This is the most common A to B
Male/Male type peripheral cable.
May come in White or Black.
Code
1+
4109
T: 0845 8380781
This is a USB 2.0 type A to
Micro-B 5-pin cable.
Code
4125
F: 0845 8380782
1+
Connectors & Cables
STEREO PCB SOCKET
3.5MM CHASSIS
MOUNT CONNECTOR
A 3.5mm stereo jack socket
with switched contacts and
a plastic body. Pack of 25.
Code
1+
4102
A 3.5mm chassis mount stereo
jack socket with fixing nut.
Pack of 10.
Code
4114
6.35MM MONO
JACK SOCKET
3.5MM MONO
JACK LEAD
6.35mm chassis mounting
mono jack socket.
Solder terminals.
Stereo 3.5mm jack lead, with
ground and one channel
connected to a 50cm lead. (As
used in the mono amplifier kit)
Code
1+
Code
1+
10+
100+
4105
iPOD/iPHONE
AMPLIFIER LEAD
STEREO AMP CABLE
Stereo 3.5mm jack lead with
ground, left and right channel
used in the stereo amplifier kit)
1+
10+
100+
4111
iPod lead (excluding Lightning
version) with ground, left and
right channel connected to a
50cm lead. Only suitable for
amp kits with volume control.
Code
1+
10+
4112
3.5MM TO 3.5MM
STEREO JACK CABLE
Standard stereo mini jack
lead, ideal for use on PC,
personal audio device, in-car
and any modern audio devices.
1.2m length.
Code
1+
10+
4126
www.kitronik.co.uk
sales@kitronik.co.uk
Components
4116
Code
1+
很抱歉,暂时无法提供与“4132”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.497831+1.43677
