2712
2712
    KITRONIK
    ELECTRO-FASHION SEWABLE LEDS, RE
2712 数据手册
Electro-Fashion SEWABLE LED KITS Kits are packed ready for student use and include a coin cell holder, a coin cell, 2m of conductive thread and either two flashing LEDs or one colour changing LED. They allow lighting effects to be added to textiles designs without soldering. Description Code Flashing blue sewable LED kit 2702 Flashing green sewable LED kit 2703 Flashing red sewable LED kit 2704 Flashing yellow sewable LED kit 2705 Colour changing sewable LED kit 2706 1+ 10+ Project Example ELECTRO-FASHION - 60 STUDENT BULK PACK Pack includes: 60 x sewable coin cell holders. 10 x colour changing LEDs. 60 x CR2032 coin cell batteries. 25 x each of blue, red, yellow 180m of conductive thread, 3m per student. and green flashing LEDs. Description Code Sewable LED - 60 student bulk pack 2707 1+ ELECTRO-FASHION KITS WITH FLAT LEDS These kits are ready-packed with all of the parts needed for students to make a simple E-Textiles circuit. The kit includes two flat LEDs that are marked up with + and – markings, making them smaller and easier to use than LEDs with leads. As well as the two flat LEDs, the kit also includes a 2m t-shirt of conductive thread, a sewable coin cell holder and coin cell. Project Example (requires extra LEDs) Description Code Sewable LED kit with blue flat LEDs 2735 Sewable LED kit with green flat LEDs 2736 Sewable LED kit with red flat LEDs 2737 Sewable LED kit with white flat LEDs 2738 1+ Textiles & Craft The bulk pack offers great value for teaching larger groups of students. Electro-Fashion ELECTRO-FASHION CAT KIT This cat kit contains all the items you need to make the cat (except for a pair of scissors and a needle). To make the cat the felt is cut into three pieces following the lines marked on the preprinted design. The LED eyes, battery holder and a switch are sewn on to a piece of felt following the stitch lines. The cat is then sewn together and stuffed with wadding. Pop the battery in and when the cat’s ear is pressed the eyes will light. Kit contents: - 1 x Printed felt. 2 x Sewable green slim LEDs. 1 x Sewable push button switch. 1 x Sewable coin cell holder. - 1 x CR2032 coin cell. 2 x Conductive thread. 8m Embroidery thread. Wadding. www.kitronik.co.uk/cat Code 1+ 2725 Textiles & Craft PROJECT EXAMPLES - ELECTRO-FASHION SEWABLE LEDs Examples of conductive fabric used on the hands of puppets. When these are touched together, the circuit is completed and the LED lights up. Electro-Fashion ELECTRO-FASHION FLASHER CONTROLLER, LEDS & THREAD This unit offers a simple way of adding ‘flashing’ white LEDs to a textiles project. The unit is programmed with a number of flashing patterns that are selected by a push button on the main PCB. Pressing this button cycles through the following patterns: all LEDs constantly on, slow flash (all on, all off), fast flash (each in turn), and turned off. The device features auto off, which turns the unit off after 30 minutes to preserve battery life. Depending upon flash pattern the battery lasts for approximately two days of constant use. This kit is supplied ‘pre-built’ so requires no soldering. Each kit comprises three small PCB’s. The largest of the three PCB’s holds an LED plus the control electronics, battery and a push button. On both of the remaining PCB’s there is an LED, which are connected to the main board with conductive thread. Includes approximately 2m of conductive thread. Includes a CR2032 battery. Description Code Flasher controller and LEDs 2719 1+ 10+ ELECTRO-FASHION MAGNETIC SWITCH & MAGNET This magnetic switch can turn on LEDs when the magnet is placed near the switch. Description Code Magnetic switch & magnet 2720 1+ 10+ ELECTRO-FASHION LIGHT SENSOR This board allows LEDs to be turned on automatically when it is dark. On one side of the board is the coin cell holder, which takes a CR2032 coin cell as well as a small on off slide switch. On the other side of the board is the light sensor. The design means that it is possible to cut a small hole in the front of the product for the light sensor to detect the light level, whilst also being able to get to the back of the board to change the battery and turn the board off. When turned off any connected LEDs will be off. When turned on the connected LEDs will be off in day light but come on in the dark. Description Code Electro-Fashion - Light sensor 2721 1+ 10+ Textiles & Craft Dimensions: L34 x W20 x H9mm. Electro-Fashion LITHIUM 3V COIN CELLS Description Code 3V CR2032 - 200mA/h - 5 pack 2262 3V CR1220 - 40mA/h - 5 pack 2269 SWITCHED COIN CELL HOLDER This specially designed coin cell holder has large connection points for the conductive thread. These are clearly marked to show the battery polarity. The unit also has a small power switch so that you can turn the power on and off. 1+ SEWABLE COIN CELL HOLDER The specially designed coin cell holder has large connection points for the conductive thread and are marked to show the battery polarity. It is available on its own, to incorporate into your own designs. Accepts CR2032 battery. Accepts CR2032 battery. Dimensions: L44 x W20 x H4.5mm. Dimensions: L34 x W20 x H4.5mm. Code 1+ 10+ 2711 Textiles & Craft This specially designed coin cell holder has large connection points for the conductive thread. These are clearly marked to show the battery polarity. Accepts CR1220 battery. 1+ 10+ Code SEWABLE PUSH SWITCH This push button switch will allow LEDs to light whilst the switch is pressed. Dimensions: L18 x W8.5 x H6mm. Dimensions: L22 x W12.5 x H4mm. 1+ 2718 Code 1+ 10+ 2708 SEWABLE SLIDE SWITCH SEWABLE TILT SWITCH This two position miniature slide switch allows LEDs to be turned on or off in textiles projects. When horizontal this switch is off. When tilted 10° from horizontal the tilt switch is on. Dimensions: L18 x W8.5 x H4mm. 2709 Code 2701 MINIATURE COIN CELL HOLDER Code 10+ 1+ Dimensions: L26 x W6.5 x H7mm. 10+ Code 2710 1+ 10+ Electro-Fashion SEWABLE PCB LEDS These ultra slim, pre-mounted LEDs are illuminated continuously. They have connections to which the conductive thread can be connected. These are clearly marked with ‘+’ and ‘-’ to indicate which is the positive and which is the negative connection. The PCBs are double sided making the thread connection very reliable. They are supplied on a small panel and the LEDs can easily be removed by snapping them out. Dimensions: L15 x W6.5 x H3mm. Description Colour Code LED board - 10 pack Red 2712 LED board - 10 pack Blue 2713 LED board - 10 pack White 2714 LED board - 10 pack Green 2723 LED board - 10 pack Sakuru (lilac) 2726 1+ 10+ These flashing LEDs can be used with the Electro-Fashion coin cell power boards. 5mm flashing LEDs in red, green, yellow and blue. The LEDs flash at around 2Hz when connected to a 5V supply. Colour Code Red 3538 Green 3539 Yellow 3540 Blue 3545 1+ 10+ 100+ 1000+ FREE TO DOWNLOAD RESOURCES To help people new to Electro-Fashion get started we have worked with Julie Boyd to develop some free online resources. These give detailed step by step explanations of how to make a product. There are guides on adding an LED to a hat (both a standard LED and a slim line LED), making a zippi doll with light up eyes & adding three LEDs to a bag. We are always working on more resources so it’s worth keeping an eye on the website. www.kitronik.co.uk/fashionresources Textiles & Craft 5MM FLASHING LED
很抱歉,暂时无法提供与“2712”相匹配的价格&库存,您可以联系我们找货
  • 15+56.5245415+7.31232
