3544
3544
    KITRONIK
    插件
    红色,绿色,蓝色(RGB) LED 指示 - 分立 3.85V 径向
3544 数据手册
LEDs 3MM STANDARD DIFFUSED LED Colour Typical mCd Code Red 275 3501 Green 35 3502 Yellow 125 3503 White 700 3564 Blue 500 3565 1+ 10+ 100+ 500+ 1000+ 100+ 500+ 1000+ 100+ 500+ 1000+ 3MM STANDARD WATER CLEAR LED Colour Typical mCd Code Red 1000 3598 Green 75 35101 Yellow 1000 3599 Blue 1750 35102 White 2750 35103 Amber 1750 35100 1+ 10+ 5MM STANDARD DIFFUSED LED Components Colour Typical mCd Code Red 275 3504 Green 35 3505 Yellow 125 3506 White 700 3542 Blue 500 3543 Orange 275 3567 1+ 10+ Calculate the resistor value for your LED the easy way with our online calculator: www.kitronik.co.uk/ledcalc T: 0845 8380781 F: 0845 8380782 LEDs 5MM STANDARD WATER CLEAR LED Colour Typical mCd Code Red 1150 35104 Green 1000 35107 Yellow 800 35105 White 2250 35109 Blue 1150 35108 Amber 900 35106 1+ 10+ 100+ 500+ 1000+ 5V DIFFUSED LED - 10 PACK 5mm LEDs in red, green & yellow, designed for use with a 5V supply. Pack of 10. Colour Typical mCd Code Red 80 3530 Green 32 3531 Yellow 32 3532 1+ FLASHING LED 5mm flashing LEDs in red, green, yellow, blue & white. The LEDs flash at around 2Hz when connected to a 5V supply. Typical mCd Code Red 3500 3538 Green 4000 3539 Yellow 3500 3540 Blue 3500 3545 White 8400 3592 1+ 10+ 100+ 1000+ Components Colour Free technical support on all products. Call or email us at: support@kitronik.co.uk www.kitronik.co.uk sales@kitronik.co.uk LEDs COLOUR CHANGING LED This LED slowly cycles through various colours, making it ideal for mood lighting, toys or ornaments. This LED does not require a current limit resistor. Operating voltage: 2.7V to 5V. Current consumption (ave): 25mA . Description Typical mCd Code 5mm high brightness 750 3527 5mm standard brightness 540 3591 10mm high brightness 3544 750 1+ 10+ Lens: Diffused. 100+ 500+ Usage example 5MM YELLOW CANDLE LED This LED flickers to produce a look similar to that of a candle. This makes it ideal for mood lighting, toys or ornaments. Operating voltage: 2.5V to 5V (this LED does not require a current limit resistor) Description Typical mCd Code Candle LED 5800 1+ 10+ 100+ 1000+ 3590 5MM RGB LED This 5mm RGB LED contains three LED elements (red, green and blue). Each element can be controlled independently. Components Description Typical mCd Code Common anode 2100 3551 Common cathode 2100 3574 1+ 10+ 100+ 500+ 5MM TRICOLOUR LED - 25 PACK This 5mm LED is a red, green & orange LED in one package. Description Typical mCd Code Tricolour LED - 25 pack 650 3511 For more information on LED forward voltages, viewing angles and brightness levels, see our online datasheet: www.kitronik.co.uk/leddata T: 0845 8380781 F: 0845 8380782 1+ LEDs 5MM RED BIKE LIGHT LED - 50 PACK Typical mCd Code 1000 3507 1+ 5MM ULTRABRIGHT WATER CLEAR LED Colour Typical mCd Code White 5000 3524 Blue 3500 3537 1+ 10+ 100+ 500+ 3MM 25° DEG MEGABRIGHT WATER CLEAR LED - 10 PACK Colour Typical mCd Code White 12500 3587-10 Blue 7000 3588-10 Red 12500 3589-10 1+ 5MM MEGABRIGHT WATER CLEAR LED Viewing angle Typical mCd Code White 15° 17500 3549 White 30° 17500 3550 Red 15° 17500 3575 Red 30° 9500 3579 Yellow 15° 17500 3576 Yellow 30° 9500 3580 Green 15° 17500 3577 Green 30° 9500 3581 Blue 15° 8500 3578 Sakuru* 15° 8400 35118 1+ 10+ 100+ 500+ Components Colour *(Lilac) www.kitronik.co.uk sales@kitronik.co.uk LEDs 5MM WIDE ANGLE WHITE LED A 5mm, wide angle, high brightness white LED. Viewing angle = 140° Typical mCd Code 3000 3546 1+ 10+ 100+ 500+ 5MM UV LED 5mm UV (ultra violet) LED is ideal for many lighting applications and products such as money checkers. Typical mCd Code 95 3566 1+ 10+ 100+ 500+ 4.8MM PINK LED This bright pink LED has a wide viewing angle and a shorter body than most 5mm LEDs. Typical mCd Code 700 3568 1+ 10+ 100+ 500+ 5MM INFRARED LED 5mm standard directivity high radiant power infrared LED. Water clear lens with superior weather resistance and UV resistant epoxy. Typical applications include IrDA, encoder, data comunication and IR camera. To be used with part code: 35111. Typical mCd Code 1100 35110 1+ 10+ 100+ Components INFRARED RECEIVER MODULE Miniature size, built in exlcusive IC infrared receiver module. Wide half angle and long reception distance with good noise-proof capability. High immunity against ambient light. To be used with part code: 35110. Code 1+ 10+ 100+ 10+ 100+ 250+ 35111 10MM STANDARD DIFFUSED LED T: 0845 8380781 Colour Typical mCd Code Red 350 3508 Green 350 3509 Yellow 350 3510 F: 0845 8380782 1+ LED 10MM HIGH BRIGHTNESS DIFFUSED LED - 10 PACK Colour Typical mCd Code Red 900 3583-10 Green 1750 3584-10 Yellow 900 3585-10 White 1750 3586-10 1+ LED SPACER - 100 PACK Description Code 5mm LED spacers - 100 pack 3525 9.5mm LED spacers - 100 pack 3526 1+ PANEL MOUNT LED CLIP Holder clips for panel mounting LEDs. 5mm LEd holder bezel: 8mm dia. 10mm LED holder bezel: 16mm dia. Size Pack Quantity Code 5mm 50 3541 10mm 25 3582 1+ Chrome plated brass recessed holder for 5mm LEDs. Panel cutout size: 8mm dia. Complete with fixing hardware. Description Code 5mm chrome bezel LED holder 35112 1+ 10+ 7 SEGMENT DISPLAY - 10 PACK 14.2mm high, green LED. Pack of 10. Description Typical mCd Code Common anode 6 3512 Common cathode 6 3513 www.kitronik.co.uk 1+ sales@kitronik.co.uk Components 5MM CHROME BEZEL LED HOLDER LEDs LED STAR These power LED stars offer an extremely high light output in an energy efficient way. Description Typical mCd Code 1W warm white power LED star 45000 3547 3W white power LED star 3548 67000 1+ 10+ 25+ 10+ 100+ 500+ 5MM SUPER FLUX LED - 10 PACK Colour Typical mCd Code White 1800 3597 Blue 1350 3596 Yellow 1250 3594 Green 1350 3595 Red 1250 3593 1+ www.kitronik.co.uk/fluxled CHOOSING A PSU FOR YOUR LED STRIPS LED strips are very easy to use, but you need to make sure the power supply has sufficient capacity for the length of LED strips being used. Components As all the colours of LED strips take about 400 mA per meter, the longer the length of strip the bigger the power supply has to be. To save you doing the maths below is a table showing the maximum length for each of the power supplies. www.kitronik.co.uk/ledstrips Max length Power supply Code Page 12.5m 12V, 500mA, wall plug PSU 2260 91 5m (1 reel) 12V, 2A, wall plug PSU 2266 91 T: 0845 8380781 F: 0845 8380782 LED FLEXIBLE LED STRIPS These energy efficient flexible LED strips are extremely versatile. They can be used in a wide range of lighting applications and products. The strips are adhesive backed and run off a 12DC supply. The strips can be cut into sections. 15 way = 15 LEDs per 0.5m with 5cm cut points. 30 way = 30 LEDs per 0.5m with 10cm cut points. FLEXIBLE LED STRIP - 0.5M Description Code Red flexible LED strip, 30 way - 0.5m 3352 Green flexible LED strip, 30 way - 0.5m 3353 Blue flexible LED strip, 30 way - 0.5m 3354 Yellow flexible LED strip, 30 way - 0.5m 3355 White flexible LED strip, 30 way - 0.5m 3356 1+ 10+ FLEXIBLE LED STRIP - 5M Code Red flexible LED strip, 30 way - 5m 3352-5M Green flexible LED strip, 30 way - 5m 3353-5M Blue flexible LED strip, 30 way - 5m 3354-5M Yellow flexible LED strip, 30 way - 5m 3355-5M White flexible LED strip, 30 way - 5m 3356-5M 1+ Components Description RGB FLEXIBLE LED STRIP - 0.5M Description Code RGB flexible LED strip, 15 way - 0.5m 3357 RGB flexible LED strip, 30 way - 0.5m 3363 1+ 10+ RGB FLEXIBLE LED STRIP - 5M Description Code RGB flexible LED strip, 15 way - 5m 3357-5M RGB flexible LED strip, 30 way - 5m 3363-5M www.kitronik.co.uk 1+ sales@kitronik.co.uk
3544
PDF文档中包含以下信息:
1. 物料型号:型号为W25Q128JVSFIG 2. 器件简介:W25Q128JVSFIG是一款128Mbit的串行闪存,采用QSPI/SPI接口,适用于需要大容量存储和快速数据传输的应用。
3. 引脚分配:共有8个引脚,包括CS、D0~D3、CLK、HOLD、VCC和GND。
4. 参数特性:工作电压2.7V~3.6V,工作频率最高可达104MHz,支持QSPI和SPI两种工作模式。
5. 功能详解:支持快速读取、页编程、块擦除、全芯片擦除等多种操作,具有数据保护和加密功能。
6. 应用信息:适用于工业控制、消费电子、物联网设备等领域。
7. 封装信息:采用SOIC-8封装。
很抱歉,暂时无法提供与“3544”相匹配的价格&库存,您可以联系我们找货
  • 1+7.313991+0.94686
