2401
2401
    KITRONIK
    BREADBOARD TERM STRIP 3.23X2.13"
2401 数据手册
MINI PROTOTYPE BOARD A board for prototyping circuits. Components and wires can be placed into the board and the circuit built and tested without soldering. Multiple boards can be interconnected. This board has 170 tie points. Components not included Description Code Mini prototype board 2446 1+ 10+ PROTOTYPE BOARDS Components and wires can be placed into the board and the circuit built and tested without soldering. Multiple boards can be interconnected. Includes blue and red labelled ‘power rail’ along the length of the board on both edges. Description Code 1+ Large prototype board - PBU202 - 830 tie points 2444 Small prototype board - PBU301 - 400 tie points 2401 10+ 50+ BREADBOARD WITH BINDING POSTS This is a standard solderless breadboard with three binding posts, two power buses, and black aluminium plate backing. It works with various wire gauges. Code Breadboard with binding posts 2443 1+ STRIP BOARDS Strip boards are ideal for prototypes or projects. Boards have a 0.1” pitch hole spacing and hole diameter of 1mm. Sold in sizes of 160 x 100mm (pack of 5, 35 strips x 61 holes) and 100mm x 250mm (35 strips and 95 holes). Description Code Stripboards, 100 x 160 mm - 5 pack 2404 Stripboards, 100 x 250 mm 2439 1+ 10+ 1+ 5+ STRIP BOARD CUTTER A strip board cutter used to break the tracks on strip board. Description Code Stripboard cutter 2602 Components Description
很抱歉,暂时无法提供与“2401”相匹配的价格&库存,您可以联系我们找货
