80028
80028
    KLEINTOOLS
    28-PC ELECTRICIAN TOOL SET
80028 数据手册
KLEIN TOOLS KITS Innovative Products, More Capability, Greater Productivity 12 Piece Tool Kit (Cat. No. 92003) * SKU Description D248-8 8" Diagonal Cutting Pliers High Leverage D203-8 8" Long Nose Pliers Side Cutting 5719 PowerLine Series 18 Pocket Electrician Tool Pouch 5705 PowerLine Web Work Belt 603-4 #2 Phillips Screwdriver, 4" Round Shank 662 #2 Square Screwdriver, 4" Round Shank 605-4 1/4" Cabinet Screwdriver, 4" Round Shank, HD 9375 7.5m Double Hook Magnetic Tape Measure 11045 Wire Stripper/Cutter (10-18 AWG Solid) * D213-9NE 9" Lineman’s Pliers, New England Nose * 601-6 3/16" Cabinet Screwdriver, 6" Round Shank * 935R Magnetic Torpedo Level * Products replaced previous items in this kit 28 Piece Tool Kit (Cat. No. 80028) * SKU Description D213-9NETP 9" Lineman’s Pliers, Fish Tape Pulling D248-8 8" Diagonal Cutting Pliers High Leverage D203-8 8" Long Nose Pliers Side Cutting D502-10 10" Pump Pliers 1005 Wire Crimper/Cutter (10-22 AWG) 11045 Wire Stripper/Cutter (10-18 AWG Solid) 630-3/16 3/16" Nut Driver, 3" Hollow Shaft 630-1/4 1/4" Nut Driver, 3" Hollow Shaft 630-5/16 5/16" Nut Driver, 3" Hollow Shaft 630-11/32 11/32" Nut Driver, 3" Hollow Shaft 630-3/8 3/8" Nut Driver, 3" Hollow Shaft 630-7/16 7/16" Nut Driver, 3" Hollow Shaft 630-1/2 1/2" Nut Driver, 3" Hollow Shaft 85191 Conduit-Fitting and Reaming Screwdriver 601-6 3/16" Cabinet Screwdriver, 6" Round Shaft 602-6 5/16" Keystone Screwdriver, 6" Round Shaft, HD 662 #2 Square Screwdriver, 4" Round Shank 5139 Canvas Zipper Bag 60159 Standard Safety Glasses, Clear 9125 25-ft Non-Magnetic Tape Measure * 603-4 #2 Phillips Screwdriver, 4" Round Shank * 935R Magnetic Torpedo Level * 44131 Folding Utility Knife * 55421BP-14 Tradesman Pro Backpack 39 Pockets * 605-4 1/4" Cabinet Screwdriver, 4" Round Shaft, HD * NCVT-3P Non-Contact Voltage Tester With Flashlight * RT210 GFCI Outlet Tester * 70550 11" Folding Hex Key Set * Products replaced previous items in this kit 92003 80028 80141 41 Piece Tool Kit (Cat. No. 80141) * SKU Description * SKU Description 600-4 1/4" Keystone Screwdriver, 4" Square Shaft, HD * 70550 11" Folding Hex Key Set 601-6 3/16" Cabinet Screwdriver, 6" Round Shaft * 55421BP-14 Tradesman Pro Backpack 39 Pockets 603-4B #2 Phillips Screwdriver, 4" Round Shaft, Wire Bending * 44131 Folding Utility Knife 662 #2 Square Screwdriver, 4" Round Shank * 935AB4V ACCU-Bend Level, 4 Vial 601-3 3/16" Cabinet Screwdriver, 3" Round Shaft * 63225 High Leverage Cable Cutter 650 Scratch Awl * 85091 Power Conduit Reamer with #2 Square Bit 605-6 1/4" Cabinet Screwdriver, 6" Round Shaft, HD * 56331 50-ft Steel Fish Tape 602-6 5/16" Keystone Screwdriver, 6" Round Shaft, HD * D2000-9NETP 9" Lineman’s Pliers, Fish Tape Pulling, HD 603-3 #1 Phillips Screwdriver, 3" Round Shaft * D2000-48 8" Diagonal Cutting Pliers High Leverage, HD 630-3/16 3/16" Nut Driver, 3" Hollow Shaft * D203-8N 8" Long Nose Pliers Side Cutting 630-1/4 1/4" Nut Driver, 3" Hollow Shaft * D502-10 10" Pump Pliers 630-5/16 5/16" Nut Driver, 3" Hollow Shaft * 1005 Wire Crimper/Cutter (10-22 AWG) 630-11/32 11/32" Nut Driver, 3" Hollow Shaft * 32561 6 in 1 Multi-Bit Stubby Screwdriver 630-3/8 3/8" Nut Driver, 3" Hollow Shaft * 32314 14 in 1 Multi-Bit Precision Screwdriver 630-7/16 7/16" Nut Driver, 3" Hollow Shaft * 31737 Folding Jab Saw 630-1/2 1/2" Nut Driver, 3" Hollow Shaft * NCVT-3P Non-Contact Voltage Tester With Flashlight 11055 Wire Stripper/Cutter (10-18 AWG Solid) * RT210 GFCI Outlet Tester K1412 Dual NM Cable Stripper/Cutter (12/2 and 14/2) * ET250 Voltage and Continuity Tester 9225 25-ft Double Hook Magnetic Tape Measure * 56049 Rechargeable Light Array Headlamp 60159 Standard Safety Glasses, Clear * MAG2 Magnetizer/Demagnetizer 5139 Canvas Zipper Bag * Products replaced previous items in this kit See our complete line of Tool Kits www.kleintools.com © 2021 Klein Tools, Inc., Lincolnshire, IL 60069 MKT082421US Rev. 08/21 A
80028 价格&库存
很抱歉,暂时无法提供与“80028”相匹配的价格&库存,您可以联系我们找货
