IO-E4231S-6LZH-1000B
    IO
    8(4 对双绞线) 芯 多线对,Cat6 线缆 黑色 23 AWG 箔
IO-E4231S-6LZH-1000B 数据手册
BULK SOLID CATEGORY CABLE CAT 6 F/UTP LSZH OVERVIEW This category cable contains 4 twisted pairs of stranded 23 AWG conductors allowing for longer maximum cable runs and increased signal integrity. The twisted pairs are separated by a 4-way divider to maintain proper spacing and reduce crosstalk between pairs. Crosstalk between cables and electromagnetic interference is also reduced due to the heavy duty aluminum foil shield and the dedicated tinned copper drain wire for proper shield termination. The Cat 6 wire comes complete with a matte black, flame retardant low smoke, zero halogen (LSZH) jacket that protects the interior workings of the cable from harsh environments and installation stress. Distance markers are printed on the jacket every 2 ft so you never lose sight of how much wire you've installed. Low smoke, zero halogen cable is the new standard in safety. In a fire situation, a LSZH cable produces very little smoke and due to the extremely low levels of Halogens in the material, produces no toxic fumes. This solid Cat 6 wire provides an excellent foundation for any commercial or home network. It is perfect for structured cabling and transmission of digital and analog signals for data, video, and audio applications. It meets IEEE 802.3ab for 1000Base-T and also meets both IEEE 802.3af and IEEE 802.3at for PoE and PoE+ applications. It is also suitable for HDBaseT, AES 50, AES 67, AES/EBU, Digital Video, RS-422, and tested up to 550 MHz. Product specifications may change without prior notification Io Audio Technologies® is a registered trademark of Knight Electronics, Inc. 10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 | www.ioaudiotechnologies.com SPECIFICATIONS Product Conductors Part Number: IO-E4231S-6LZH-1000B Details: Bare Copper (Solid) Number of Conductors: 8 (4 Twisted Pairs) Size: 23 AWG plus drain wire Shield Insulation Details: Aluminum Mylar Material: Polyolefin O.D.: 1.03-1.10mm Jacket Colors: White/Orange, Orange, White/Green, Blue, O.D.: 7.2 ± 0.2mm White/Blue, Green, White/Brown, Brown Material: LSZH Electrical and Mechanical Characteristics Thickness: 0.45 ± 0.05mm Temperature Rating: 60°C Flammability Grade Spark Test: 2.5 KV DC AC Leakage Thru Overall Jacket: ≤ 10mA (1.5KV AC) Cable Cold Bend: -20°C for 4 hr Conductor DC Resistance: ≤ 9.38 Ω/100m Details: IEC 60332-1 / -2 IEC 61034-1 / -2 IEC 60754-2 Characteristic Impedance: 100 Ω±15 Drain Wire Resistance Unbalance: ≤ 5% Details: 24 AWG Solid Tinned Dielectric Strength: 1.5 Kv Ac For 2 S Copper Insulation Resistance: ≥ 5000 MΩ/Km Packaging Mutual Capacitance: ≤ 5.6 nF/100m Capacitance Unbalance Pair-to-ground: ≤ 330 pF/100m Operating Temperature: -20°C ~ +60°C (-4°F ~ +140°F) CONFIGURATION 1000’ Pull Box, Internal Spool 16.5” H x 12.5” W x 15.5” D Weight: 42 lbs. STANDARDS & CLASSIFICATIONS ANSI/TIA-568.2-D (2018) ISO/IEC 11801 (Edition 2.2) IEC 61156-6 (Edition 3.1) Product specifications may change without prior notification Io Audio Technologies® is a registered trademark of Knight Electronics, Inc. 10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 | www.ioaudiotechnologies.com TRANSMISSION PERFORMANCE at 20°C Freq Insertion Loss NEXT PS.NEXT ACR PS.ACR ACRF PS.ACRF Return Loss Propagation Delay Skew Delay MHz Max dB/100m Min dB/100m Min dB/100m Min dB/100m Min dB/100m Min dB/100m Min dB/100m Min dB/100m Max ns/100m Max ns/100m 1 2.03 77.3 75.30 75.28 73.28 70.80 67.80 20.00 570.00 4 3.78 68.27 66.27 64.49 62.49 58.76 55.76 23.01 552.00 8 5.32 63.75 61.75 58.43 56.43 52.74 49.74 24.52 546.73 10 5.95 62.30 60.30 56.35 54.35 50.80 47.80 25.00 545.38 16 7.55 56.24 57.24 51.68 49.68 46.72 43.72 25.00 543.00 20 8.47 57.78 55.78 49.31 47.31 44.78 41.78 25.00 542.05 25 9.51 56.33 54.33 46.83 44.83 42.84 39.84 24.32 541.20 31.25 10.67 54.88 52.88 44.20 42.20 40.90 37.90 23.64 540.44 62.5 15.38 50.36 48.36 34.98 32.98 34.88 31.88 21.54 538.55 100 19.80 47.30 45.30 27.50 25.50 30.80 27.80 20.11 537.60 150 24.71 44.66 42.66 19.95 17.95 27.28 24.28 18.87 536.94 200 28.998 42.78 40.78 13.80 11.80 24.78 21.78 18.00 536.55 250 32.85 41.33 39.33 8.48 6.48 22.84 19.84 17.32 536.28 300 36.43 40.14 35.14 3.72 1.72 21.26 18.26 16.77 536.08 350 39.79 39.79 37.14 N.A. N.A. 19.92 16.92 16.30 535.92 400 42.97 38.27 36.27 N.A. N.A. 18.76 15.76 15.89 535.80 450 46.01 37.5 35.50 N.A. N.A. 17.74 14.74 15.53 535.70 500 48.94 36.82 34.82 N.A. N.A. 16.82 13.82 15.21 535.61 550 51.76 36.19 34.19 N.A. N.A. 15.99 12.99 14.92 535.54 Values above 250 MHz are informational only. Product specifications may change without prior notification Io Audio Technologies® is a registered trademark of Knight Electronics, Inc. 10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 | www.ioaudiotechnologies.com 45.00
IO-E4231S-6LZH-1000B 价格&库存
很抱歉,暂时无法提供与“IO-E4231S-6LZH-1000B”相匹配的价格&库存,您可以联系我们找货
    库存:1
