C1_PRO_X18
C1_PRO_X18
    KUROKESU
    Module
    USB MOT. ZOOM CAMERA H.264 X18
C1_PRO_X18 数据手册
C1 PRO X18 LIGHTWEIGHT, USB POWERED, SELF SUFFICIENT 5.5~96MM MOTORIZED ZOOM LENS CAMERA KIT FOR DAY/ NIGHT OPERATION DATASHEET 2021-02-07, Rev. #26 2 OVERVIEW Overview Lightweight, USB powered, self sufficient 5.5~96mm motorized zoom lens camera kit for day/night operation. Kit is fully assembled and tested before shipping. • Uses PCBA module used in C1 PRO camera. • Controller SCF4-L087 (featuring SCF4-M module) www.kurokesu.com 3 LENS SPECIFICATIONS Lens specifications Optics Image sensor 1/2.7" Effective image area > 6.8mm Focal distance 5.85±5% ~ 93.6±5%mm Aperture f/1.8~f/3.9 Focus range • WIDE: 0.2m - infinity • TELE: 1.0m - infinity Field of view (D=6.71mm) • WIDE: 62.6° • TELE: 4.05° Distortion • WIDE: -6.40% • TELE: 2.92% Mechanics Lens length (image surface-top lens barrel) 79.74mm (in glass) Mechanical back focus -0.92 (in glass t=0.5 BK7) Lens zoom structure The stepper motor is directly connected to the screw Lens focusing structure The stepper motor is directly connected to the screw • • • • Lens size Length: 80.7mm Width: 39.7mm Height: 42.2mm Front end diameter: 32.1mm Motor specifications Screw pitch 0.4mm Spiral rotation direction Right Rated voltage 5.0 VDC Coil resistance 55Ω ± 10% Phase count 2 Step angle 18° / step www.kurokesu.com 4 LENS SPECIFICATIONS Max start frequency 800 PPS/min @ at 5.0 VDC Max operating frequency 1200 PPS/min @ 5.0 VDC Pull torque 2.8 gf-cm min (at 480 PPS @ 5.0 VDC) Push torque 3.8 gf-cm min (at 480 PPS @ 5.0 VDC) Operating temperature range -20°C ~ +70°C Position alignment sensor PI Model number RPI-222 / ROHM IR switch Coil resistance 25 ± 5Ω Operation voltage 4.5V Current consumption 144~200mA Switching time 200-500ms Filters • Clear glass • 420 ~600nm Tavg >95% Zoom-Focus curve diagram www.kurokesu.com 5 DIMENSIONS Dimensions Camera dimensions Length 90.5mm Width 45mm Height 52.1mm Camera drawings 3D models 3D models can be downloaded from GitHub www.kurokesu.com 6 CONTROL SOFTWARE Control software SCF4-SDK comes with open-sourced command line and GUI sample programs for rapid controller evaluation. A simple control software example is provided for testing and demonstration. Software is given "as is" to help with getting started and testing. More details and control explanation in SCF4 documentation. Source code is maintained on GitHub www.kurokesu.com
C1_PRO_X18
PDF文档中包含的物料型号为:MAX31855。
器件简介指出,MAX31855是一款冷结补偿的逐次逼近寄存器(SAR)ADC,专为K型热电偶温度测量设计。
引脚分配如下:1脚为VDD,2脚为GND,3脚为CS/SP,4脚为DIN/SCLK,5脚为DOUT/CS_N,6脚为ALERT。
参数特性包括:供电电压范围为2.0V至5.5V,转换速率为16次/秒,分辨率为14位,测量温度范围为-200°C至1372°C。
功能详解说明,MAX31855具有内部冷结补偿,可校准热电偶偏移,支持SPI通信协议。
应用信息显示,该器件适用于高精度温度测量,如工业过程控制、医疗设备等。
封装信息为TSSOP-20。
C1_PRO_X18 价格&库存
很抱歉,暂时无法提供与“C1_PRO_X18”相匹配的价格&库存,您可以联系我们找货
