EFA2400A3S-10MH4L
EFA2400A3S-10MH4L
    LAIRD(莱尔德)
    RF ANT 2.44GHZ CER CABLE 100MM
EFA2400A3S-10MH4L 数据手册
A Datasheet mFlexPIFA 2.4 – 2.5 GHz mFlexPIFA +2 dBi Antenna, 100 mm cable length with U.FL or MHF4 connector Version 2.1 mFlexPIFA Datasheet REVISION HISTORY Version Date Notes 2.0 15 Aug 2017 Initial Release on website Sue White 2.1 20 Mar 2018 Added new antenna connector information; transitioned to new template; updated contact information Jay White Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 Contributors 2 Approver Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet CONTENTS 1 Ordering Information ..................................................................................................................................................... 4 2 Key Features .................................................................................................................................................................. 4 3 Specifications ................................................................................................................................................................. 4 4 Physical Dimensions ....................................................................................................................................................... 5 5 Test Setup ...................................................................................................................................................................... 6 6 Flat Surface Antenna Measurements ............................................................................................................................. 7 Return Loss ........................................................................................................................................................................ 7 7 Flat Surface Antenna Radiation Performance ................................................................................................................. 8 7.1 Antenna Setup ...................................................................................................................................................... 8 7.2 Results – Flat Surface ............................................................................................................................................ 9 2400 MHz ...................................................................................................................................................................... 9 2440 MHz .................................................................................................................................................................... 11 2480 MHz .................................................................................................................................................................... 13 8 Curved Surface Antenna Radiation Performance.......................................................................................................... 15 8.1 Antenna Setup .................................................................................................................................................... 15 8.2 Results – Curved Surface ..................................................................................................................................... 16 2440 MHz .................................................................................................................................................................... 16 9 Optimal Installation Guide ........................................................................................................................................... 18 9.1 Flex Limits of the mFlexPIFA ................................................................................................................................ 20 10 Product Revision History .............................................................................................................................................. 21 11 Contacting Laird ........................................................................................................................................................... 21 Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 3 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 1 ORDERING INFORMATION Table 1: Ordering information Order Number Description 001-0030 mFlexPIFA – 2.4 GHz embedded metal FlexPIFA antenna, 100 mm cable length w/U.FL connector EFA2400A3S-10MH4L mFlexPIFA – 2.4 GHz embedded metal FlexPIFA antenna, 100 mm cable length w/MHF4 connector 2 KEY FEATURES ▪ ▪ ▪ ▪ ▪ Designed to be installed directly on metal Can be installed on different conductive surfaces and thicknesses Can be installed on flat or curved surfaces ▪ Quick and easy Installation Adhesive holds to surface during humidity exposure and hot/cold cycles RoHS compliant 3 SPECIFICATIONS Table 2: mFlexPIFA specifications Specification Value Peak Gain +2 dBi Average Gain >-4.2 dBi Impedance 50 ohms Type Flexible Planar Inverted F Antenna (FlexPIFA) Polarization Linear VSWR ≤ 3.0:1, 2400 - 2480 MHz Frequency 2400 - 2480 MHz Weight 1.8 g Size 25.4 mm × 23.4 mm × 2.5 mm Antenna Color Clear Yellow Adhesive 3M 100MP Operating Temp -40°C to +85°C Connector Height U.FL: 2.5 mm maximum Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 4 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 4 PHYSICAL DIMENSIONS Note: All measurements are in millimetres (mm). Figure 1: Physical dimensions Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 5 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 5 TEST SETUP Antenna measurements such as VSWR are measured with an Agilent E5071C Vector Network Analyzer. Radiation patterns are measured with a CMT Planar 804/1 Vector Network Analyzer in a Howland Company 3100 Chamber equivalent. Phase Center is 9 inches above the Phi positioner. Flat surface measurements are done with the antenna centered on a 100 x 100 mm, 0.35 mm thick brass plate. Curved surface measurements are taken by placing the antenna on a curved surface made of 0.35 mm thick brass. Figure 2 Antenna Chamber Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 6 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 6 FLAT SURFACE ANTENNA MEASUREMENTS Return Loss Figure 3: Return loss measured on a 0.35 mm thick, 100 x 100 mm brass plate Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 7 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 7 FLAT SURFACE ANTENNA RADIATION PERFORMANCE 7.1 Antenna Setup The mFlexPIFA is centered on a 100 x 100 mm brass plate. Figure 4: Flat surface setup Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 8 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 7.2 Results – Flat Surface 2400 MHz Azimuthal Conical Cuts at 2400 MHz Figure 5: Total gain pattern – 2400 MHz Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 9 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 3D Plots at 2400 MHz Figure 6: Phi, theta, and total gain plots – 2400 MHz Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 10 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 2440 MHz Azimuthal Conical Cuts at 2440 MHz Figure 7: Total gain pattern – 2440 MHz Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 11 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 3D Plots at 2440 MHz Figure 8: Phi, theta, and total gain plots – 2440 MHz Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 12 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 2480 MHz Azimuthal Conical Cuts at 2480 MHz Figure 9: Total gain pattern – 2480 MHz Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 13 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 3D Plots at 2480 MHz Figure 10: Phi, theta, and total gain plots – 2480 MHz Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 14 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 8 CURVED SURFACE ANTENNA RADIATION PERFORMANCE 8.1 Antenna Setup The mFlexPIFA is placed on the outside of a 60-mm outer diameter metal tube. Figure 11: Convex curve setup Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 15 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 8.2 Results – Curved Surface 2440 MHz Azimuthal Conical Cuts at 2440 MHz Figure 12: Total gain pattern – 2440 MHz Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 16 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 3D Plots at 2440 MHz Figure 13: Phi, theta, and total gain plots – 2440 MHz Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 17 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 9 OPTIMAL INSTALLATION GUIDE Main Element Strong E-Field Between Plates Fringing Fields Ground Plate Figure 14: E-field radiation from the FlexPIFA. Taken from CST simulation Keep the main element clear of any non-metal objects (such as plastics) on top of it by at least three millimeters (see Figure 15). Figure 15: Top clearance Similarly, keep the two long sides of the mFlexPIFA clear of any non-metal objects by at least two millimeters (see Figure 16). For metal objects, the top side of the mFlex should be kept clear by at least two millimeters and the bottom side of the mFlex at least 12 millimeters (see Figure 17). 2 mm Figure 16: Non-metal side clearance Figure 17: Metal side clearance A one-millimeter clearance should be observed from the ground wall to any non-metal object (Figure 18). A 15-millimeter clearance should be observed for metal objects (Figure 19). Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 18 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 1 mm Figure 18: Non-metal ground wall clearance Important! Figure 19: Metal ground wall clearance Mounting the mFlexPIFA in a situation that does not allow for these clearance recommendations may change the gain characteristics stated in the datasheet, which could impact overall range of the wireless system. The ideal material for the mFlexPIFA to be mounted on (for maximum performance) is brass. However, as previously mentioned, the mFlexPIFA can tolerate other metallic surfaces and thicknesses and still radiate effectively. Depending on the type of material, the mFlexPIFA may be detuned. The coaxial cable feeding the mFlexPIFA should be routed away from the antenna. Do not run the coaxial cable over the top of the mFlexPIFA or near the tip of the main element. The cable should be routed perpendicular to the side of the mFlexPIFA (this is the way the cable comes assembled) or away from the ground wall. These options are shown in Figure 20. Perpendicular to the Side Away from the Ground Wall Figure 20: Recommended cable routing As with any antenna, do not place objects near the antenna (except as described in the next section). Other objects, such as an LCD display, placed near the antenna may not affect its tuning but can distort the radiation pattern. Materials that absorb electromagnetic fields should be kept away from the antenna to maximize performance. The following are some common things to keep in mind when placing the antenna: Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 19 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet ▪ ▪ ▪ ▪ ▪ Wire routing Speakers – These generate magnetic fields Battery location Proximity to human body Display screen – These absorb radiation 9.1 Flex Limits of the mFlexPIFA One of the unique features of the mFlexPIFA is its ability to flex. However, due to the adhesive, there are limits to how much the antenna can be flexed and still remain secured to the device. The mFlexPIFA should not be flexed in a convex position with a radius less than 60 millimeters. Going smaller than this may result in the antenna peeling off the surface over time. Should a tighter radius of curvature be required, we recommend that you contact Laird/LSR Design Services for assistance. Figure 21: Convex mounted We do not recommend mounting the mFlexPIFA in a metal-enclosed concave position. In this scenario, the limiting factor is performance. The ground plate of the antenna is pressed closer to the main element. The fringing fields developing off the end of the element are responsible for most of the radiation. In a concave position, the fringing fields are adversely affected and gain suffers. This can also potentially create a Faraday’s cage and cancel most of the RF radiation from the antenna. If a concave position is required, we recommend that you contact Laird/LSR Design Services for assistance. Note: The mFlexPIFA is not designed to be twisted or crumpled. The adhesive back should lay flush with the surface on which it is mounted. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 20 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610 mFlexPIFA Datasheet 10 PRODUCT REVISION HISTORY Rev 1: Initial Production Release 11 CONTACTING LAIRD Headquarters Laird W66 N220 Commerce Court Cedarburg, WI 53012-2636 USA Tel: 1(262) 375-4400 Fax: 1(262) 375-4248 Website: www.lairdtech.com Technical Support: ews.support@lairdtech.com Sales Contact: cs-sales@lairdtech.com Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 330-0243-R2.1 21 Americas: +1-800-492-2320 © Copyright 2018 Laird. All Rights Reserved Europe: +44-1628-858-940 The information in this document is subject to change without notice. Hong Kong: +852 2923 0610
EFA2400A3S-10MH4L 价格&库存
很抱歉,暂时无法提供与“EFA2400A3S-10MH4L”相匹配的价格&库存,您可以联系我们找货
