387009391
387009391
    LAIRD(莱尔德)
    Peltier 模块 133.1W @ 27°C 16.4 A 120°C
387009391 数据手册
PowerCycling PCX Series PCX16-120-F2-5025-TB-RT-W6 MFG Part Number: 387009391 PowerCycling PCX Series Thermoelectric Cooler Features ● The PCX16-120-F2-5025-TB-RT-W6 is a high-performance thermoelectric cooler designed for thermal cycling between multiple temperature set points and is ideal for applications in healthcare among others, where fast temperature changes are required. The thermoelectric module is specially constructed to reduce the amount of stress induced on the thermoelectric elements during operation. It has a maximum Qc of 133.1 Watts when ΔT = 0 and a maximum ΔT of 73.6 °C at Qc = 0. ● ● ● ● Applications High thermal cycling reliability Precise temperature control Solid-state operation Boosted performance with next-gen material RoHS-compliant ● ● ● Molecular Diagnostics (DNA Amplification, PCR) Point of Care Testing Devices Thermal Test Sockets ELECTRICAL AND THERMAL PERFORMANCE For maximum performance, be sure to orient the CONTROL side of the TEC against the application to be managed and the HEATSINK side against the heat sink or other heat rejection method. The CONTROL side is always opposite the side with lead attachments. Lead attachment is a passive heat loss and less impactful if located on the side that attaches to the heat exchanger. Heat Pumped at Cold Side Thot = 27 °C Heat Pumped at Cold Side Thot = 27 °C 140.00 140.00 120.00 120.00 100.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 80.00 60.00 Qc (Watts) Qc (Watts) 100.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 80.00 60.00 40.00 40.00 20.00 20.00 0.00 0.00 2.00 4.00 6.00 8.00 10.0012.0014.0016.0018.0020.00 0.00 0.00 2.00 Operating Current (Amps) 4.00 6.00 8.00 10.00 12.00 14.00 16.00 Operating Voltage (Volts) Operating Voltage (Volts) Current vs Voltage (I vs V) Thot = 27 °C 16.00 14.00 12.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 10.00 8.00 6.00 4.00 2.00 0.00 0.00 2.00 4.00 6.00 8.00 10.00 12.00 Operating Current (Amps) 14.00 16.00 18.00 20.00 PowerCycling PCX Series PCX16-120-F2-5025-TB-RT-W6 MFG Part Number: 387009391 Coefficient of Performance (COP = Qc/Pin) Thot = 27 °C 6.00 6.00 5.00 5.00 3.00 3.00 2.00 2.00 1.00 1.00 0.00 0.00 5.00 10.00 15.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 4.00 COP ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 4.00 COP Coefficient of Performance (COP = Qc/Pin) Thot = 27 °C 0.00 0.00 20.00 2.00 Operating Current (Amps) 400.00 400.00 350.00 350.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 300.00 250.00 200.00 Qh (Watts) Qh (Watts) 450.00 12.00 14.00 16.00 200.00 100.00 100.00 50.00 50.00 0.00 0.00 20.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C ΔT=40°C ΔT=50°C ΔT=60°C 250.00 150.00 15.00 10.00 300.00 150.00 10.00 8.00 Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Thot = 27 °C 450.00 5.00 6.00 Operating Voltage (Volts) Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Thot = 27 °C 0.00 0.00 4.00 2.00 Operating Current (Amps) 4.00 6.00 8.00 10.00 12.00 14.00 16.00 Operating Voltage (Volts) Heat Pumped at Cold Side (Qc) Thot = 27 °C | Current = 13.8 Amps Coefficient of Performance (COP = Qc/Pin) Thot = 27 °C | Current = 13.8 Amps 140.00 2.00 120.00 1.50 80.00 COP Qc (Watts) 100.00 60.00 40.00 1.00 0.50 20.00 0.00 0.0 10.0 20.0 30.0 40.0 ΔT (°C) 50.0 60.0 70.0 80.0 0.00 0.0 10.0 20.0 30.0 40.0 ΔT (°C) 50.0 60.0 70.0 80.0 PowerCycling PCX Series PCX16-120-F2-5025-TB-RT-W6 MFG Part Number: 387009391 SPECIFICATIONS* Hot Side Temperature 27.0 °C 50.0 °C 80.0 °C Qcmax (ΔT = 0) 133.1 Watts 143.2 Watts 153.6 Watts ΔTmax (Qc = 0) 73.6°C 82.6°C 93.1°C Imax (I @ ΔTmax) 16.4 Amps 16.0 Amps 15.5 Amps Vmax (V @ ΔTmax) 14.0 Volts 15.6 Volts 17.6 Volts Module Resistance 0.81 Ohms 0.91 Ohms 1.04 Ohms Max Operating Temperature 120 °C Weight 21.0 gram(s) * Specifications reflect thermoelectric coefficients updated March 2020 FINISHING OPTIONS Suffix Thickness Flatness / Parallelism Hot Face Cold Face Lead Length TB 3.300 ±0.013 mm 0.130 ± 0.0005 in 0.013 mm / 0.013 mm 0.0005 in / 0.0005 in Lapped Lapped 152.4 mm 6.00 in SEALING OPTIONS Suffix Sealant Color Temp Range Description RT RTV Translucent or White -60 to 204°C Non-corrosive, silicone adhesive NOTES 1. 2. 3. 4. Max operating temperature: 120°C Do not exceed Imax or Vmax when operating module Reference assembly guidelines for recommended installation Solder tinning also available on metallized ceramics Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice. Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request. © Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered trademarks of Laird Limited or its subsidiaries. Revision: -- Date: 05-31-2022 Print Date: 06-20-2022
387009391 价格&库存
很抱歉,暂时无法提供与“387009391”相匹配的价格&库存,您可以联系我们找货
