AC4790-1X1
AC4790-1X1
    LAIRD(莱尔德)
    RX TXRX MODULE CASTELLATION SMD
AC4790-1X1 数据手册
AC4790-1X1 900MHz Radio Module Innovative Technology for a Connected World THE FASTEST WAY TO WIRELESS Laird Technologies’ tiny AC4790-1x1 radio modules put the power of a pre-configured peer-to-peer protocol into the smallest, most cost-sensitive wireless applications. Despite their small size, 1x1 modules can communicate with any other in-range 1x1 radio module (even in harsh industrial conditions) allowing for virtually infinite range. The AC4790-1x1’s RF protocol features a dynamic addressing scheme that simplifies node-to-node communication. The radio module identifies the most efficient transmission path, so OEMs can design routing sequences that optimize the RF network. This makes 1x1 ideal for a wide variety of industrial applications that must rely on smooth, constant data flow. Using field-proven 900MHz FHSS technology that utilizes unlicensed frequency bands*, these modules reject interference, enable co-located system operation, and ensure data integrity. Integration is easy. OEMs simply solder the radio modules and antennas into place, then power-on. Hopping, synchronization, and data TX/RX is performed in the firmware. global solutions: local support USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2268.6567 wirelessinfo@lairdtech.com www.lairdtech.com/wireless TM FEATURES MARKETS • • • • • • • • • • • • True peer-to-peer protocol Ultra-fast sync time (25 msec) Smallest form factor: 1.0” x 1.0” API commands to control packet routing Software-adjustable sensitivity Network node discovery Range up to 1 mile Commercial Buildings Field Surveillance Utility Management Recreation Fleet Telemetry AC4790-1X1 900MHz Radio Module Innovative Technology for a Connected World FLEXIBLE RF PROTOCOL Laird Technologies’ embedded transparent protocol simplifies the OEM’s integration process by utilizing drop-in installation. As each radio module receives raw data, it manages the over-the-air protocol to assure successful communication. Headers, data packet length, and CRCs are not required. The RF232 supports simple cable-replacement to complex peer-to-peer configurations, broadcast communication to all radio modules or address packets to a specific destination using unique MAC addresses embedded in each radio module. SPECIFICATIONS RF PROTOCOL MODES Parameter AC4790–1x1 Interface SMT Frequency band (software selectable) (North America)** 902-928 MHz Modulation FHSS FSK Serial interface options 3V TTL Serial interface data rate Up to 115.2 Kbps Output power (w/ 3dBi antenna) 0mW-10mW variable Current consumption (transmit/receive)† 80mA / 28mA Channels Up to 48 (North America)** Security One-byte system ID Voltage 3.3V Sensitivity -99 dB @ full RF data rate Range (line-of-sight w/ 3dBi antenna) Up to 1 mile (1.6 km) Temperature -40º to +80ºC Humidity (non-condensing) 10% to 90% Dimensions 1.0 x 1.0 x 0.2 inches (25.4 x 25.4 x 6.0 cm) Weight < 0.5 oz (< 15 g) Antenna External, via SMT pad *The 900MHz band is approved in the Americas and Australia as an unlicensed spectrum subject to approval by device. **For products and specifications suited to non-U.S. countries (e.g. Australia and Europe), please contact Laird Technologies. †Current consumption assumes 50% transmitter on-tim The details contained within the document are subject to change. Download the product specification from www.lairdtech.com/wireless for the most current specification. AC4790 1X1 is not FCC approved. Laird Technologies will assist with the approval process for high volume customers. a) Communication Unicast (one-to-one addressing) Broadcast (one-to-multiple addressing) b) Acknowledgement mode (ACK) API with hardware and/or software ACK indication c) Ultra-fast sync time: Up to 25 simultaneous conversations; Intelligent self-extending session time requires only one 25 msec sync d) Remote over-the-air configuration e) Sensadjust, software-controlled RF desensitizer wards off interference f) Random back-off g) Network node discovery h) Dynamic radio data table: Retains data from up to 8 radio modules INTERFACE PROTOCOL a) On-the-fly transceiver configuration: Full API control Destination address RF transmit power RF channel Broadcast/addressed b) Raw data or transmit/receive API c) Long range mode, enables sensitivity control d) A/D, generic digital I/Os e) Variable baud rate f) RF packet size, timeout control g) Onboard temperature sensor h) Handshaking, CTS/RTS i) Session indicator j) Error detection Onboard CR Duplicate packet filtering k) Data encryption standard (DES) LWS-SPEC-AC4790 1X1 0209 Any information furnished by Laird Technologies and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies materials rests with the end user since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability, or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies terms and conditions of sale in effect from time to time, a copy of which will be furnished upon request. For further information please visit our website at www.lairdtech.com. Alternatively contact: wirelessinfo@lairdtech.com. Bluetooth® is a trademark owned by Bluetooth SIG, Inc., USA and licensed to Laird Technologies. © 2009 All Rights Reserved. Laird Technologies is a registered trademark of Laird Technologies, Inc.
AC4790-1X1 价格&库存
很抱歉,暂时无法提供与“AC4790-1X1”相匹配的价格&库存,您可以联系我们找货
