A
Laird Connectivity’s new BL653 series enables Industrial OEMs to robustly
implement longer range BLE applications in the harshest operating
environments. This series of secure low power, microcontroller modules
with multi wireless capabilities is the future of wireless Industrial Internet
of Things (IIoT) connectivity.
Powered by Nordic’s nRF52833 silicon, the small form factor BL653
modules and DVKs provide for a secure, robust BLE and Cortex -M4F CPU
for any OEM’s product design. The BL653 provides you with maximum
development flexibility with programming options for the Nordic SDK or
Zephyr RTOS, a simple, intuitive AT command set, as well as Laird’s own
smartBASIC environment.
The BL653 series brings out all nRF52833 hardware features and
capabilities including USB access, up to +8 dBm transmit power up to
5.5V supply considerations, and NFC tag (type 2 / 4) implementation.
Complete regulatory certifications enable faster time to market and
reduced development risk completes Laird’s simplification of your next
Bluetooth design!
Bluetooth v5.1 Bluetooth Low Energy (BLE) plus NFC
Bluetooth v5.2- capable
802.15.4 radio (non-certified – Thread & ZigBee via Nordic SDK or
Thread via Zephyr)
Widest range of configurable interfaces: UART, I2C, SPI, ADC, GPIO,
PWM, FREQ, USB, PDM, and NFC
Extended Industrial Temperature Rating (-40° to +105 °C)
Ultra-small footprint (15 mm x 10 mm x 2.2 mm)
BLE Peripheral/Central roles supported
2 Mbps and LE Long Range: Support for 2 Mbps, 1 Mbps, & 125 kps coded
Bluetooth 5.1 - Direction finding – AoA and AoD
Hostless operation – Internal MCU reduces BOM
Powerful Core Cortex-M4F (512kB Flash, 128 k RAM)
Built on years of experience with Nordic (BL600 and BL652 Series)
Fully featured development kit everything needed to start BLE
development
Application design choice: Leverage Laird’s smartBASIC, simple AT
command set, Zephyr RTOS or utilize Nordic SDK directly
Nordic nRF52833 – 7x7 QFN with 42 GPIOs utilized.
Mechanically same form factor as BL654 Series
Includes radio capable of Bluetooth v5.1 Direction Finding with AoA and AoD
Simple AT Command set or easily write event-driven, automated applications,
no toolchain required with smartBASIC. Alternatively utilize either Zephyr RTOS
or the Nordic SDK directly – develop application SW your way
Professional Lighting
Designed and certified to the highest industrial temperature range of -40 ºC to
+105 ºC for every component utilised.
Direction Finding / AoA / AoD
Carries several modular FCC, IC, CE, RCM, MIC and Bluetooth SIG approvals.
Secure Medical Peripherals
Laird’s industry-renowned support is passionate about helping you speed your
design to market.
Industrial IoT Sensors
Contact Sales -
Americas:
Europe:
+1 262 375 4400
+44 1628 940 ext. 958
Korea:
+82 10 2622 3935
Hong Kong: +852 2923 0610
For documentation, software, sample apps and more visit:
http://www.lairdconnect.com/BL653-ble-thread-nfc-modules
Wireless Specification
Bluetooth®
802.15.4
Frequency
Transmit Power
Receive Sensitivity
Link Budget
Antenna Options
Raw Data Rates (Air)
UART Interface
Host Interface and
Peripherals
USB Interface
Other
Key BLE Features
Programmability
Options
smartBASIC
AT Command Set
Nordic SDK
Zephyr RTOS
FW upgrade
Supply Voltage
Power Consumption
Current
Physical
Environmental
Miscellaneous
Development Tools
Dimensions
Temp Range
Lead Free
Development Kit
Utilities
Qualifications
Regulator
Bluetooth®
Approvals
v5.1
Thread and Zigbee support via Nordic SDK
2.402 - 2.480 GHz
+ 8 dBm (maximum). Configurable down to -40 dBm
-95 dBm (typical @ BLE 1 Mpbs)
-103 dBm (typical @ BLE 125 kbps)
103 dB (@ BLE I Mbps), 111 db (@ BLE 125 kpbs)
PCB trace antenna or trace pin for external antennas
1 Mbps, 2 Mbps, 125 kbps
TX, RX, CTS, RTS. DTR, DSR, DCD, RI (GPIO)
Default: 115200, N, 8, 1. Configurable from 1200 bps to 1 Mbps
2 pins - CDC/Audio/HID & mass storage virtual interfaces
42 multifunction GPIO’s that can provide:
▪ 2 PDM (2 GPIO pins each)
▪ 2 UART (4 GPIO pins each)
▪ 2 I2S (5 GPIO pins)
▪ 8 ADC channels (1 pin each)
▪ 2 GPIO pins for 32.768 kHz crystal
▪ 2 I2C (2 GPIO pins each)
▪ 2 GPIO pins for NFC
▪ 4 SPI Master
▪ PWM output on 16 pins
(4 GPIO pins including CS each)
▪ FREQ output on 16 pins
▪ LE advertising extensions
▪ GATT client & GATT server – Any
▪ LE secure connections
adopted/custom services
▪ Data packet length extensions
▪ Central/Peripheral roles
▪ LE privacy v1.2
▪ Up to 8 BLE connections (smartBASIC)
▪ LE ping
▪ BLE mesh
▪ vSP – Virtual Serial Port
▪ CODED PHY
▪ Isochronous streams for audio (BT v5.2)
▪ 2M PHY
On-board BASIC event driven programming language
Simple AT Hayes-style command protocol
Software/Support available from Nordic directly https://devzone.nordicsemi.com/
Software/Support available from https://www.zephyrproject.org/
Via UART or JTAG
1.7V – 5.5V
Max Peak Radio Current (@ +8 dBm TX) – 14.1 mA (DCDC at 3V)
Max Peak Radio Current (@ 0 dBm TX) – 4.9 mA (DCDC at 3V)
Standby Doze – 2.6 µA
Deep Sleep –0.6 µA (external signal wake-up)
15 mm x 10 mm x 2.2 mm (modules)
-40°C to +105°C
Lead-free and RoHS-compliant
Development board and free software tools
UwTerminalX (Multi-platform)
Nordic nRFConnect - Android and iOS applications
UART firmware upgrade
Complete Declaration ID
FCC/IC/CE/MIC/RCM - All BL653 Series
For full specifications on BL653 modules, please see the appropriate datasheet.
453-00039R
453-00041R
453-00039C
453-00041C
453-00039-K1
453-00041-K1
Contact Sales -
BLE module (Nordic nRF52833) – Integrated antenna (Tape/Reel)
BLE module (Nordic nRF52833) – Trace pin (Tape/Reel)
BLE module (Nordic nRF52833) – Integrated antenna (Cut Tape)
BLE module (Nordic nRF52833) – Trace pin (Cut Tape)
Development kit for Bluetooth + 802.15.4 + NFC module – Integrated antenna
Development kit for Bluetooth + 802.15.4 + NFC module – Trace pin (external antenna)
Americas:
Europe:
+1 262 375 4400
Korea:
+82 10 2622 3935
很抱歉,暂时无法提供与“453-00041-K1”相匹配的价格&库存,您可以联系我们找货
