453-00039R
453-00039R
    LAIRD(莱尔德)
    模块
    802.15.4,蓝牙 蓝牙 v5.1,Thread,Zigbee® RF 收发器模块 2.402GHz ~ 2.48GHz 集成式,芯片 表面贴装型
453-00039R 数据手册
A Laird Connectivity’s new BL653 series enables Industrial OEMs to robustly implement longer range BLE applications in the harshest operating environments. This series of secure low power, microcontroller modules with multi wireless capabilities is the future of wireless Industrial Internet of Things (IIoT) connectivity. ▪ ▪ ▪ Powered by Nordic’s nRF52833 silicon, the small form factor BL653 modules and DVKs provide for a secure, robust BLE and Cortex -M4F CPU for any OEM’s product design. The BL653 provides you with maximum development flexibility with programming options for the Nordic SDK or Zephyr RTOS, a simple, intuitive AT command set, as well as Laird’s own smartBASIC environment. ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ The BL653 series brings out all nRF52833 hardware features and capabilities including USB access, up to +8 dBm transmit power up to 5.5V supply considerations, and NFC tag (type 2 / 4) implementation. Complete regulatory certifications enable faster time to market and reduced development risk completes Laird’s simplification of your next Bluetooth design! ▪ ▪ ▪ ▪ Bluetooth v5.1 Bluetooth Low Energy (BLE) plus NFC Bluetooth v5.2- capable 802.15.4 radio (non-certified – Thread & ZigBee via Nordic SDK or Thread via Zephyr) Widest range of configurable interfaces: UART, I2C, SPI, ADC, GPIO, PWM, FREQ, USB, PDM, and NFC Extended Industrial Temperature Rating (-40° to +105 °C) Ultra-small footprint (15 mm x 10 mm x 2.2 mm) BLE Peripheral/Central roles supported 2 Mbps and LE Long Range: Support for 2 Mbps, 1 Mbps, & 125 kps coded Bluetooth 5.1 - Direction finding – AoA and AoD Hostless operation – Internal MCU reduces BOM Powerful Core Cortex-M4F (512kB Flash, 128 k RAM) Built on years of experience with Nordic (BL600 and BL652 Series) Fully featured development kit everything needed to start BLE development Application design choice: Leverage Laird’s smartBASIC, simple AT command set, Zephyr RTOS or utilize Nordic SDK directly Nordic nRF52833 – 7x7 QFN with 42 GPIOs utilized. Mechanically same form factor as BL654 Series Includes radio capable of Bluetooth v5.1 Direction Finding with AoA and AoD Simple AT Command set or easily write event-driven, automated applications, no toolchain required with smartBASIC. Alternatively utilize either Zephyr RTOS or the Nordic SDK directly – develop application SW your way Professional Lighting Designed and certified to the highest industrial temperature range of -40 ºC to +105 ºC for every component utilised. Direction Finding / AoA / AoD Carries several modular FCC, IC, CE, RCM, MIC and Bluetooth SIG approvals. Secure Medical Peripherals Laird’s industry-renowned support is passionate about helping you speed your design to market. Industrial IoT Sensors Contact Sales - Americas: Europe: +1 262 375 4400 +44 1628 940 ext. 958 Korea: +82 10 2622 3935 Hong Kong: +852 2923 0610 For documentation, software, sample apps and more visit: http://www.lairdconnect.com/BL653-ble-thread-nfc-modules Wireless Specification Bluetooth® 802.15.4 Frequency Transmit Power Receive Sensitivity Link Budget Antenna Options Raw Data Rates (Air) UART Interface Host Interface and Peripherals USB Interface Other Key BLE Features Bluetooth Low Energy Programmability Options smartBASIC AT Command Set Nordic SDK Zephyr RTOS FW upgrade Supply Voltage Power Consumption Current Physical Environmental Miscellaneous Development Tools Dimensions Temp Range Lead Free Development Kit Utilities Qualifications Regulator Bluetooth® Approvals v5.1 Thread and Zigbee support via Nordic SDK 2.402 - 2.480 GHz + 8 dBm (maximum). Configurable down to -40 dBm -95 dBm (typical @ BLE 1 Mpbs) -103 dBm (typical @ BLE 125 kbps) 103 dB (@ BLE I Mbps), 111 db (@ BLE 125 kpbs) PCB trace antenna or trace pin for external antennas 1 Mbps, 2 Mbps, 125 kbps TX, RX, CTS, RTS. DTR, DSR, DCD, RI (GPIO) Default: 115200, N, 8, 1. Configurable from 1200 bps to 1 Mbps 2 pins - CDC/Audio/HID & mass storage virtual interfaces 42 multifunction GPIO’s that can provide: ▪ 2 PDM (2 GPIO pins each) ▪ 2 UART (4 GPIO pins each) ▪ 2 I2S (5 GPIO pins) ▪ 8 ADC channels (1 pin each) ▪ 2 GPIO pins for 32.768 kHz crystal ▪ 2 I2C (2 GPIO pins each) ▪ 2 GPIO pins for NFC ▪ 4 SPI Master ▪ PWM output on 16 pins (4 GPIO pins including CS each) ▪ FREQ output on 16 pins ▪ LE advertising extensions ▪ GATT client & GATT server – Any ▪ LE secure connections adopted/custom services ▪ Data packet length extensions ▪ Central/Peripheral roles ▪ LE privacy v1.2 ▪ Up to 8 BLE connections (smartBASIC) ▪ LE ping ▪ BLE mesh ▪ vSP – Virtual Serial Port ▪ CODED PHY ▪ Isochronous streams for audio (BT v5.2) ▪ 2M PHY On-board BASIC event driven programming language Simple AT Hayes-style command protocol Software/Support available from Nordic directly https://devzone.nordicsemi.com/ Software/Support available from https://www.zephyrproject.org/ Via UART or JTAG 1.7V – 5.5V Max Peak Radio Current (@ +8 dBm TX) – 14.1 mA (DCDC at 3V) Max Peak Radio Current (@ 0 dBm TX) – 4.9 mA (DCDC at 3V) Standby Doze – 2.6 µA Deep Sleep –0.6 µA (external signal wake-up) 15 mm x 10 mm x 2.2 mm (modules) -40°C to +105°C Lead-free and RoHS-compliant Development board and free software tools UwTerminalX (Multi-platform) Nordic nRFConnect - Android and iOS applications UART firmware upgrade Complete Declaration ID FCC/IC/CE/MIC/RCM - All BL653 Series For full specifications on BL653 modules, please see the appropriate datasheet. 453-00039R 453-00041R 453-00039C 453-00041C 453-00039-K1 453-00041-K1 Contact Sales - BLE module (Nordic nRF52833) – Integrated antenna (Tape/Reel) BLE module (Nordic nRF52833) – Trace pin (Tape/Reel) BLE module (Nordic nRF52833) – Integrated antenna (Cut Tape) BLE module (Nordic nRF52833) – Trace pin (Cut Tape) Development kit for Bluetooth + 802.15.4 + NFC module – Integrated antenna Development kit for Bluetooth + 802.15.4 + NFC module – Trace pin (external antenna) Americas: Europe: +1 262 375 4400 +44 1628 940 ext. 958 Korea: +82 10 2622 3935 Hong Kong: +852 2923 0610 For documentation, software, sample apps and more visit: http://www.lairdconnect.com/BL653-ble-thread-nfc-modules
453-00039R 价格&库存
很抱歉,暂时无法提供与“453-00039R”相匹配的价格&库存,您可以联系我们找货
