455-00104
455-00104
    LAIRD(莱尔德)
    pt100 温度传感器 -25°C ~ 50°C 非接地 连接器
455-00104 数据手册
A SECURE, SCALABLE WIRELESS SENSORS FOR LONG RANGE IOT APPLICATIONS Laird Connectivity’s Sentrius RS1xx external RTD temperature probe is a battery-powered, long range sensor platform that leverages the benefits of LoRaWAN and Bluetooth Low Energy (BLE) connectivity. Packaged in a small, rugged form factor containing superior RF performance and connected to a stainless-steel probe measuring just 100 millimeters (4 inches) in length, housing a Class A tolerance PT100 RTD with a measurement temperature range of -40°C to +180°C (-40°F to +350°F) At the high end of the supported range the external temperature probe is ideally designed for monitoring low and slow cooking temps mounted inside a smoker and transmitting your data over LoRaWAN. Equally, the probe can be used in any environment from -40°C to +180°C where a shorter, thinner stainless-steel probe would be beneficial. ▪ Multi-wireless: LoRaWAN (868/915/923 MHz) and Bluetooth v4.2 (Central/Peripheral) with fully integrated high-performance antennas ▪ External Sensor Probe: Class A PT100 RTD temperature sensor within cabled IP67 probe ▪ Fully certified for FCC/IC/CE/ASNZS/NCC/IMDA and Bluetooth SIG ▪ Simple wireless configuration using mobile application over BLE ▪ Harsh Environments: Robust IP65 enclosure to serve many varied installation needs ▪ Integrated out of the box networks: Default configuration with Laird Connectivity’s RG1xx gateway for simple, out-of-the-box cloud connectivity At its core, the RS1xx external RTD temperature sensor utilizes Laird Connectivity’s field proven and reliable RS1xx Series hardware, providing LoRaWAN options in 868, 915, and 923 MHz frequencies. The RS1xx works with Laird Connectivity’s Sentrius RG1xx Gateway for simple out-of-the-box integration and is compatible with third-party Cloud and LoRa network ecosystem partners. Develop a fully owned private LoRaWAN network to capture, route and process IoT data for your application. Choose from RM1xx modules, RS1xx finished sensors, or RG1xx Gateways Robust enclosures provide a robust and resilient platform for recording and delivering sensor data from a range of harsh environments Robust multi-layer security at each interface to safeguard your network at every level Ready for deployment in multiple regulatory domains – FCC, ISED, EU, ASNZ, NCC, IMDA and Bluetooth SIG listing Product transportation monitoring Route sensor data to the Cloud with Laird Connectivity’s simplified wireless connectivity deployment Food safety management Our Tier-2 support and engineering teams work to help configure and deploy your application Industrial heating and cooling Contact Sales - Americas: +1 262 375 4400 Europe: +44 1628 940 ext. 958 Korea: +82 10 2622 3935 Hong Kong: +852 2923 0610 For documentation, software, sample apps and more visit: https://www.lairdconnect.com/rs1xx-sensors Sentrius RS1xx External RTD Temperature Probe (+180°C) Product Brief Chipset LoRa Temperature Probe LoRa® Bluetooth® Frequencies Type Interface Operating Range and Variance Antenna Power Software Storage LED Button Physical Environmental Regulatory Warranty Dimensions and Connector Integrated Battery Mobile Application Data logging Status User Input Enclosure Dimensions Connector Enclosure Operating Temp Storage Temperature Approvals Semtech SX1272 Nordic nRF51822 – 256 k/32 k 863 – 870 MHz (EU), 902 – 928 MHz (US), 915 – 928 MHz (AU + AS923) Class A tolerance PT100-M222 RTD Resistance Temperature Detector (RTD) using 3-wire interface -40°C (-40°F) to +180°C (350°F) Variance of reported temperature data can be calculated taking the following uncertainties into account: i) BS EN 60751:2008/IEC 60751 standards which state accuracy of class A PT100 measurements to be ± (0.15°C + 0.002 |t|) ii) RTD-to-Digital conversion, utilizing the MAX31865 with a ‘Total Accuracy Over All Operating Conditions’ of 0.5°C As such, max. variance at -40°C = +0.57°C or max. variance at +180°C = +1.01°C Cable length – 1320 mm (+20 mm); stainless-steel shaft - 4.0 mm (+0.2 mm) (dia.) x 100 mm (+2 mm) (length) RJ45C connector (IP66~68 rated), user connected Custom Laird Connectivity antenna for 868, 915, or 923 MHz. Ceramic chip antenna for 2.4 GHz 2 x AA - replaceable Android and iOS – Remote sensor display and/or configuration + firmware update 10,000 measurements (256 k of flash memory available) 3 – Bluetooth LE and LoRa status Multi-use – default Bluetooth LE pairing 116 x 131 x 34 mm RJ45C Jack (IP66~68 rated), user connected -25° to +50°C (temperature range dictated by AA battery chemistry, Alkaline/Lithium) -40° to +50°C FCC, ISED, EU, ASNZ, NCC, IMDA, and Bluetooth SIG One-year warranty 455-00103 455-00104 455-00105 455-00106 455-00108 455-00109 455-00110 455-00111 455-00112 455-00112B Sentrius™ RS1xx LoRaWAN – 915 MHz Ext. RTD temperature enclosure - North America Sentrius™ RS1xx LoRaWAN – 868 MHz Ext. RTD temperature enclosure - Europe Sentrius™ RS1xx LoRaWAN – 923 MHz Ext. RTD temperature enclosure - Taiwan Sentrius™ RS1xx LoRaWAN – 923 MHz Ext. RTD temperature enclosure - New Zealand (AS923) Sentrius™ RS1xx LoRaWAN – 923 MHz Ext. RTD temperature enclosure - Singapore Sentrius™ RS1xx LoRaWAN – 923 MHz Ext. RTD temperature enclosure - Hong Kong Sentrius™ RS1xx LoRaWAN – 915 MHz Ext. RTD temperature enclosure - Australia (AU915) Sentrius™ RS1xx LoRaWAN – 923 MHz Ext. RTD temperature enclosure - Australia (AS923) RTD Temp Sensor, -40°C ~ +180°C, 100 mm x 4.0 mm SS probe, 1320 mm cable, cable assembly ONLY (SINGLE) RTD Temp Sensor, -40°C ~ +180°C, 100 mm x 4.0 mm SS probe, 1320mm cable, cable assembly ONLY (BULK - carton qty. 50 pcs.) 455-00124 455-00124B 455-00123 455-00123B RTD temp sensor, -100°C ~ +100°C, 50 mm x 3.3 mm SS Probe, 2000 mm cable, cable assembly ONLY (SINGLE) RTD temp sensor, -100°C ~ +100°C, 50 mm x 3.3 mm SS Probe, 2000 mm cable, cable assembly ONLY (BULK - carton qty. 50 pcs.) RTD temp sensor, -50°C ~ +450°C, 200 mm x 4.0 mm SS Probe, 2000 mm cable, cable assembly ONLY (SINGLE) RTD temp sensor, -50°C ~ +450°C, 200 mm x 4.0 mm SS Probe, 2000 mm cable, cable assembly ONLY (BULK - carton qty. 50 pcs.) Note: The RTD external temperature probe cable assembly is not included with the Sentrius sensor enclosure and each part must be ordered individually. It’s a 1:1 ratio of region-specific sensor enclosure to sensor cable assembly. Additionally, sensor cable assemblies available as part of the Sentrius product range are not interchangeable between Sentrius sensor enclosures (blue housing) with RJ45 port. The user must connect the appropriate sensor cable assembly with the intended enclosure. Please check the product description on the sensor label/part number on the packaging if in doubt. Contact Sales - Americas: +1 262 375 4400 Europe: +44 1628 940 ext. 958 Korea: +82 10 2622 3935 Hong Kong: +852 2923 0610 For documentation, software, sample apps and more visit: https://www.lairdconnect.com/rs1xx-sensors
455-00104 价格&库存
很抱歉,暂时无法提供与“455-00104”相匹配的价格&库存,您可以联系我们找货
    • 1+1600.21440
    • 200+638.49600
    • 500+617.16600
    • 1000+606.62520
