MHE High Current Low DCR Power Inductors
MHE0503 Series
FEATURES AND APPLICATIONS
Laird MHE series high current power inductors improve performance,reliability and power efficiency.
A lower power loss benefits consumer electronics, Industrial and Telecom product design.
Products feature extremely low DCR with greater efficiency and enable a larger current in a small size.
Inductors are of magnetic shielding and molded construction and perform in operating temperatures
ranging from -40°C to 125°C (including self-heating temperature rise)
FEATURES
• High saturation current realized by optimum coil desigh and high performance powder
• Low profile and very compact in size
• Very low DCR
APPLICATIONS
• Industrial DC to DC power lines
• Telecom and Datacom DC to DC power lines
• DC to DC converter with low power loss, low voltage
and high output current such as CPU ,VRM, etc
PART NUMBER EXPLANATION
ELECTRICAL SPECIFICATIONS
• Inductance tested at 1MHz, 1.0V
• Heat Rated Current (Irms) is defined based on temperature rise approximate 40°C without core loss
(ambient temperature 25±5°C)
• Saturation Current (Isat) is the DC current at which the inductance drops off approximately 30% from
its value without current. (ambient temperature 25±5°C)
• Operating temperature range: -40°C~+125°C (including self-heating temperature rise)
• Storage temperature range (packaging conditions): -10°C~+40°C and RH 60%(MAX.)
Note: Heat Rated Current (Irms) is tested on a typical PCB and apply a constant current in still air.
The temperature rise is dependent on the application system condition including PCB PAD pattern,
trace width and thickness and adjacent components etc. It’s suggested to verify the temperature
rise of the component under the real operation application conditions.
www.laird.com
MHE0503 Series
Rev:B
1.MHE0503 SERIES DIMENSIONS
Recommended layout
MHE0503 Series
A
B
C
D
E
F
5.7±0.3
5.4±0.3
3.0 Max
4.2±0.3
2.0±0.3
2.4±0.3
www.laird.com
MHE0503 Series
Rev:B
2.SPECIFICATION
Part No.
DC
Inductance
DC
Resistance
(uH)
Resistance
(mohm)
1MHz/1.0V (mohm) Typ
Max
Isat
(A) Typ/Max
Irms
(A) Typ/Max
SRF
(MHz) Typ
MHE0503R33M-10 0.33±20%
3.4
3.6
26.0
23.4
19.2
17.3
102
MHE0503R68M-10 0.68±20%
5.8
6.5
22.0
19.8
14.5
13.8
70
MHE05031R0M-10
1.0±20%
7.2
8.5
17.0
14.0
11.1
10.5
55
MHE05032R2M-10
2.2±20%
13.2
14.5
11.0
9.2
9.7
9.2
34
MHE05033R3M-10
3.3±20%
20.0
23.0
10.5
8.7
8.1
7.7
28
MHE05034R7M-10
4.7±20%
29.5
35.5
8.5
6.8
5.9
5.6
21
3.EQUIVALENT CIRCUIT
4.MATERIAL LIST
(a) Coil
(b) Core
(c) Pin
www.laird.com
MHE0503 Series
Rev:B
5. CHARACTERISTICS CURVES
MHE0503R68M-10
100
0.40
80
0.80
80
0.30
60
0.60
60
0.20
40
0.40
40
0.10
0.00
8
12
16
28
3
6
9
12
MHE05031R0M-10
21
24
27
MHE05032R2M-10
100
2.5
100
1.20
80
2.0
80
0.90
60
1.5
60
0.60
40
1.0
40
0.30
0.00
4
6
8
10
12
14
16
L [uH]
1.50
Temp. Rise [℃]
L [uH]
18
DC Bias [A]
DC Bias [A]
18
4
6
DC Bias [A]
8
10
12
14
16
DC Bias [A]
MHE05033R3M-10
MHE05034R7M-10
100
6.00
100
4.00
80
4.80
80
3.00
60
3.60
60
2.00
40
2.40
40
1.00
4
6
8
DC Bias [A]
10
12
L [uH]
5.00
Temp. Rise [℃]
L [uH]
15
Temp. Rise [℃]
4
0.00
Temp. Rise [℃]
Temp.Rise [℃]
1.00
L [uH]
100
Temp.Rise [℃]
L [uH]
MHE0503R33M-10
0.50
2
3
4
5
6
7
8
DC Bias [A]
www.laird.com
MHE0503 Series
Rev:B
6. SOLDERING
Mildly activated rosin fluxes are preferred.
Recommended temperature profiles for re - flow soldering in Figure 1 .
www.laird.com
MHE0503 Series
Rev:B
7. PACKAGING
7-1 Reel Dimension
B
D
C
A
Type
A(mm)
B(mm)
C(mm)
D(mm)
13'x12
12.4+2/-0
100 ± 2
13+0.5/-0.2
330
7-2 Tape Dimension
W
E
F
P
A0
B0
P2
P0
12.0±0.3
1.75±0.1
5.50±0.1
8.00±0.1
5.5 Ref
6.0 Ref
2.0±0.1
4.0±0.1
K0
t
D0
3.25±0.1 0.35±0.05
Size
Reel
Inner Box
Outer Box
MHE0503
2000
4000
8000
1.5Ref.
www.laird.com
MHE0503 Series
Rev:B
7-3 Tearing Off Force
The force for tearing off cover tape is 10~100 grame in the arrow direction under the following conditions .
Room Temp
(°C)
Room
Humidity(%)
Room atm
(hPa)
Tearing Speed
mm/min
5~35
45~85
860~1060
300
8. Application Notice:
1.Storage Conditions:
To maintain the solderability of terminal electrodes:
a) Recommended products should be used within 12 months from the time of delivery .
b) The packaging materal should be kept where no chlorine or sulfur exists in the air .
2. Transportation:
a) Products should be -handled with care to avoid damage or contamination from perspiration and skin oils .
b) Vacuum pick up is strongly recommended for individual components .
c) Bulk handling should ensure that abrasion and mechanical shock are minimized .
www.laird.com
很抱歉,暂时无法提供与“MHE0503R33M-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.776461+1.39410
- 国内价格 香港价格
- 1+10.759191+1.39187
- 10+8.8536710+1.14536
- 100+7.27765100+0.94148
- 1000+6.047091000+0.78229
