385912-015
385912-015
    LAIRD(莱尔德)
    NRC5000-A1-20-SC2
385912-015 数据手册
NRC5000 A Nextreme Recirculating Chillers The Nextreme Recirculating Chiller Series offers dependable performance in a simple, user-friendly system design. The platform offers several standard options and features that allows configuration of the product depending on specific application needs. FEATURES APPLICATIONS Reliable Performance • Industry proven components • Increased instrumentation for monitoring of system health • Ease of maintenance Medical • Imaging • Biotech • Pharmaceutical Environmentally Friendly • Low GWP refrigerant • Variable speed motors for increased energy efficiency and reduced noise User-Friendly • Logical flow of LCD touchscreen display and system operating status • Quick start guide to allow rapid setup • Detailed user manual for thorough system understanding Application Specific Configurations • Multiple cooling capacities • Flow control and measurement options • Several pump sizes and technologies Analytical Instrumentation • Mass Spectrometers • Chromatography • Microscopes Laser • • • • Surgical Marking Cutting Printing Industrial • X-Ray Scanning • Packaging • Additive Manufacturing Semiconductor • Lithography • Ion Implant • Etch MODEL NUMBERING NRC5000 Basic Model No. NRC5000 5,000 Watts A1 20 ST1 ___ Cooling Engine Electrical Configuration Pump Options System Options A1 20 Air Cooled / R513A W1 Water Cooled / R513A 200-240V~, 1ph,50/60Hz SC1 SC2 ST1 D Deionization Filter ** Stainless, Centrifugal Pump F Stainless, Centrifugal Pump Flow Control and Sensing H DI Water Compatible (High Purity) Stainless, Turbine Pump W Water Filter NOTE: System option codes are added to the end of the model number in alphabetical order. ** Must include option H with Deionization Filter. See Laird Thermal Systems Online Wizard Configurator for Manufacturer’s Part Number. www.lairdthermal.com AA- NRC5000 1119 NRC5000 Nextreme Recirculating Chillers PERFORMANCE NRC5000 1119 NRC5000 Nextreme Recirculating Chillers PUMP CAPACITY NRC5000 1119 NRC5000 Nextreme Recirculating Chillers TECHNICAL SPECIFICATIONS Model Performance Cooling Capacity1 Setpoint Range Temperature Stability Nominal Flow Rate1 (50Hz / 60Hz) Maximum available pressure Refrigerant Storage Temperature, w/o coolant Humidity Operation Coolant 2 Temperature Relative Humidity Altitude Input Voltage Frequency Physical Dimensions, W x D x H Weight (w/o coolant) Coolant Capacity Couplings Compliance 1. 2. NRC5000 5,000 Watts (17,060 BTU/hr) 0°C to 40°C (32°F to 104°F) ±0.1°C (±0.2°F) 15 lpm @ 2.8 bar / 15 lpm @ 1.7 bar (3.9 gpm @ 41 psi / ) 3.9 gpm @ 25 psi) 4.1 bar (60 psi) R 513A -25°C to 70°C (-13°F to 158°F) 5% to 95%, non-condensing Water or Water/Glycol 15°C to 40°C (59°F to 104°F) 30% to 80% ≤2,000 meters ≤(6,560 feet) 200 - 240 VAC 50/60 Hz 63 x 59 x 91 cm (24.8 x 23.2 x 35.8 in) 100 kg (220 lbs) 5 L (1.3 gal) 1/2” NPT UL Mark for Laboratory Equipment (ANSI / UL / CSA / IEC EN 61010-1 Edition 3) Nominal capacity rating is given at a 20°C (68°F) setpoint, 20°C (68°F) ambient temperature, sea level, 60Hz operation, and the ST1 pump. For ambient conditions outside this range, please contact Laird Thermal Systems. NRC5000 1119 NRC5000 Nextreme Recirculating Chillers FEATURES Process Coolant Inlet 4.3” Color LCD Touch Screen Breathable reservoir pressure cap Power Switch Power Entry Module Reservoir Level Sight Tube Communication Port Process Coolant Outlet Lockable Casters STANDARD FEATURES Feature Variable Speed Motors System Drain Description Variable speed compressor and condensing fans for quiet operation and improved energy efficiency. Optical Fluid Level Switch Sealed fluid system with breathable reservoir cap (similar to an automobile). This prevents evaporative loses, introduction of bacteria, and the need for components to prevent fluid from draining back into the system when installed below the application. Fluid level sensing with no moving parts. RS-232 / RS-485 Communications Supply Pressure Sensing Complete control integration of chiller into higher level assembly control system. Pressure sensing for applications sensitive to high operating conditions. Semi-Closed Fluid System OPTIONAL FEATURES Feature Water Filter Kit Flow Control Valve and Flow Sensing Kit High Purity Plumbing DI Water Package Description Hot swappable, 5-micron water filter for filtering particulates from the coolant circuit. Externally installed valve for reducing the overall flow to the application. Full flow continues through the chiller to maintain high heat transfer rates and temperature stability. Flow meter for measuring coolant flow rate. Installed external to the chiller with both a local display and connectivity to chiller LCD display. Wetted materials compatible with deionized water. Stainless steel and plastics used for components within the recirculating fluid loop. Ion filtration and wetted materials suitable for operation at fluid resistivity levels of 1 to 3 MOhm*cm. NRC5000 1119 NRC5000 Nextreme Recirculating Chillers DRAWINGS NOTE: 1. Dimensions are in mm. 2. Dimensions in parenthesis are in inches. Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective because of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. www.lairdthermal.com Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2019 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights. NRC5000 1119
385912-015 价格&库存
很抱歉,暂时无法提供与“385912-015”相匹配的价格&库存,您可以联系我们找货
