OP585011
OP585011
    LAIRD(莱尔德)
    RF ANT 5.9GHZ WHIP STR N MALE
OP585011 数据手册
VERTICALLY POLARIZED BROADBAND OMNI ANTENNAS OP585011 5850-6000 MHz VERTICALLY POLARIZED OMNIDIRECTIONAL ANTENNA The Laird OP585011 broadband omnidirectional antenna has a UV-stable fiberglass radome and is IP67 rated for dust and water intrusion providing excellent durability, reliability and performance. The OP585011 is available with a 914 mm (3') RG58 Low Temperature Rated Plenum cable with Type N-male connector. The vertical pattern is a full 360 degrees with 10.9 dBi gain to improve high-speed broadband system performance in a highly rugged and durable package for both indoor and outdoor applications. FEATURES MARKETS - APPLICATIONS • 10.9 dBi antenna gain. • Type N male connector with 914 mm (3') RG58 Low Temperature Rated Plenum cable. • • • • • Wireless broadband systems • DSRC (Dedicated Short Range Communications) IP67 Rated, lightweight design for inddoor & outdoor use. UV Stable polycarbonate radome. All stainless steel bracket for better corrosion protection. Performance engineered for optimum high speed broadband performance. PARAMETER • ITS (Intelligent Transportation Systems) • Point-to-multi-point systems • WLAN access points SPECIFICATIONS Model OP585011-91NM Frequency Bands, MHz Peak Gain, dBi (Typ) 5850-6000 MHz 10.6 dBi 10.9 dBi
OP585011 价格&库存
很抱歉,暂时无法提供与“OP585011”相匹配的价格&库存,您可以联系我们找货
