RMB024-POE
RMB024-POE
    LAIRD(莱尔德)
    ETHERNET BRIDGE IP67 TRANSCEIVER
RMB024-POE 数据手册
RAMP Bridge Simple, Long-Range Wireless Ethernet Bridging Laird’s RAMP Bridge provides a simple, high-performance Wireless Ethernet cable replacement system that eliminates the frustration, cost, and complication of its competitors, all contained in a small, durable form factor. Say goodbye to enormous outdoor antennas that rely on directional precision and complicated alignment. Laird’s RAMP Bridge makes it easier than ever to achieve industrial-strength long-range Ethernet cable replacement in any environment. QUICK AND EASY, RIGHT OUT OF THE BOX SMALL, RUGGED, AND ENTIRELY WEATHERPROOF ALL THE PERFORMANCE, NONE OF THE HASSLE RAMP Bridge starter packs contain two RAMP Bridge units configured as server and client. This allows you to plug into your network and get started quickly. Individual units are also for sale which may be set as either a server or a client with the on-board setup wizard. The RAMP Bridge setup wizard, accessible over your web browser, makes setting up, testing, backing up, and updating every RAMP Bridge device as simple as following a few prompts. In addition to the high-gain omnidirectional antenna, the RAMP Bridge is encased in a sturdy IP67 waterproof enclosure. This allows the RAMP Bridge to be reliably deployed without the cost or complications of external, directional antennas. The integrated antenna is complemented by an internal power amplifier to deliver range usually only available with an external antenna. The RAMP Bridge provides exceptional performance, connectivity, and range in an impressively small form factor. It achieves RF data rates up to 54Mbps at ranges as high as half a mile, and a maximum range of 3.5 miles. Don’t struggle with products that rely on huge directional antennas which must be carefully aligned and maintained to connect. The RAMP Bridge’s omnidirectional antenna means you’ll never have to carefully point antennas to achieve superior communications. This makes the RAMP Bridge the best and simplest solution for wireless deployment in all environments. Features & Benefits Application Areas  Point to point or point to multipoint bridging (up to five clients)  Omni-directional internal antenna (no pointing necessary)  RF Data rates up to 54Mbps  Browser-based configuration wizard, no need for external configuration software or drivers  Power Over Ethernet (802.3af)  IP67-certified waterproof enclosure  FCC/IC Regulatory approvals USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2923.0610 wirelessinfo@lairdtech.com www.lairdtech.com/RAMP Digital signage (LED signs, reader boards, outdoor menus) Remote POS terminals for hospitality / retail Easy, robust networking in remote worksite locations The details contained within this document are subject to change. Download the product specification from www.lairdtech.com/RAMP for the most current specification. RAMP Bridge Simple, Long-Range Wireless Ethernet Bridging CATEGORY FEATURE IMPLEMENTATION Wireless Specifications Network architecture Server/client Frequency band 2.400-2.483.5 GHz Modulation DSSS Ethernet interface data rate 10/100Mbps Channels 11 selectable Security 128 bit AES-CCMP RF Data Rate Up to 54Mbps Sensitivity -92 dB @ min RF data rate Range (line-of-sight) Up to 5.5 km (3.5miles) Transmit power Up to 4W EIRP Input Voltage 48V dc POE Power Consumption 7 Watts Power supply Power Over Ethernet (802.3af) Power Specifications Temperature -40º to +70ºC Environmental Ingress Protection IP-67 Dust Tight and Water Immersion up to 1m Physical Dimensions 355.6 x 106 mm (14 x 4.17 in.) Weight 798g (1.76lbs) Antenna Integrated 5dBi Omni Directional Mounting Options Wall Mount (Standard) Pole Mount 38.1mm (1.5in) to 114.3mm (4.5in)(optional) Hardware Standard interface RJ-45 Power Over Ethernet (802.3af) Software Configuration software Internal webserver for configuration The details contained within the document are subject to change. Ordering Information RMB024-POE Single 2.4GHZ Power Over Ethernet Unit RMB024-POE-SP Starter pack: Two 2.4GHZ Power Over Ethernet Units preconfigured in bridge mode CONN-DS-RAMP-BRIDGE_v1_0 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights. Revision History Version Date 1.0 12 Feb 15 Changes Initial Approved By C. Downey
RMB024-POE 价格&库存
很抱歉,暂时无法提供与“RMB024-POE”相匹配的价格&库存,您可以联系我们找货
