455-0009
455-0009
    LAIRD(莱尔德)
    TEMP PROBE 915 MHZ LORA BLE
455-0009 数据手册
A SECURE, SCALABLE WIRELESS SENSORS FOR LONG RANGE IOT APPLICATIONS Laird’s SentriusTM RS1xx External Series is a battery powered, long range sensor platform leveraging the benefits of LoRaWAN and Bluetooth Low Energy (BLE) connectivity. Its small, rugged form factor contains superior RF performance and flexibility with wide ranging external temperature probe. At its core, the RS1xx External Series utilizes Laird’s field-proven and reliable RS1xx Series hardware, providing LoRaWAN options in 868 and 915MHz frequencies, plus BLE for local data display, configuration and troubleshooting. Based on the Semtech SX1272 and Nordic nRF51 silicon, it offers a LoRa range up to 10 miles with a local 2.4 GHz connectivity option to smartphones and tablets. The RS1xx External Series works with Laird’s SentriusTM RG1xx Series of LoRa/multiwireless gateways for simple out-of-the-box integration and is compatible with 3rd party Cloud and LoRa network ecosystem partners. ▪ ▪ ▪ ▪ ▪ ▪ Multi-wireless: LoRaWAN (868/915 MHz) and Bluetooth v4.2 (Central/Peripheral) with fully integrated high-performance antennas External Sensor Probe: wide ranging temperature sensor on cabled IP67 probe Fully certified for FCC/IC/CE and Bluetooth SIG Simple wireless configuration using mobile application and BLE. Harsh Environments: Robust IP65 enclosure to serve many varied installation needs Integrated out of the box networks: Default configuration with Laird RG1xx gateways for simple, out-of-the-box cloud connectivity Develop a fully-owned private LoRa network to capture, route, and process IoT data for your application - choose from RM1xx modules, RS1xx finished sensors or RG1xx Gateways Robust enclosures provide a robust and resilient platform for recording and delivering sensor data from a range of harsh environments Robust multi-layer security at each interface to safeguard your network at every level Cold Chain Management and Food Safety FCC, IC, CE and Bluetooth SIG listing Route sensor data to the Cloud with Laird’s simplified wireless connectivity deployment Support works with Laird engineering to help configure and deploy your application Contact Sales - Americas: Europe: +1 262 375 4400 +44 1628 940 ext. 958 Korea: +82 10 2622 3935 Hong Kong: +852 2923 0610 Agricultural Humidity and Environmental Monitoring Industrial Heating and Cooling For documentation, software, sample apps and more visit: www.lairdtech.com/rs1xx-lora-sensors LoRa® Bluetooth® LoRa Frequencies Temperature Accuracy Ranges Dimensions Integrated Chipset Temperature Probe Antenna Power Software Battery Mobile Application Data logging Status User Input Dimensions Operating Temp. Storage Temperature Approvals Storage LED Button Physical Environmental Regulatory Warranty Semtech SX1272 Nordic nRF51822 – 256k / 32k 863 – 870 MHz (EU), 902 – 928 MHz (US) -10° to 85°C (+/-0.5°C) -55° to +125°C (+/-0.9°C) Overall Length 1520mm. Stainless Steel end tube – 6.35mm DIA x 200mm Long Custom Laird antenna for 868 or 915MHz Ceramic chip antenna for 2.4GHz 2 x AA - replaceable Android & iOS – Remote sensor display and/or configuration + Firmware Update 10,000 measurements (256k of flash memory available) 3 – BLE and LoRa status Multi-use – default BLE Pairing 116 x 91 x 34 mm -25° to +50°C (Note external probe capable of -55 to 125°C -40° to +50°C FCC, IC, CE, Bluetooth SIG 1-Year Warranty The SentriusTM RS1xx External Series LoRa/BLE sensor features integrated antennas, external temperature probe and rugged IP65 enclosures. ORDERING INFORMATION 455-0013 455-0010 455-0012 455-0009 455-0011 Contact Sales - Sentrius™ RS1xx External Sensor - 868MHz External Temperature Probe inc. LoRa & BLE Sentrius™ RS1xx External Sensor - 868MHz External Temperature Probe inc. LoRa & BLE – Bulk Sentrius™ RS1xx External Sensor - 915MHz External Temperature Probe inc. LoRa & BLE Sentrius™ RS1xx External Sensor - 915MHz External Temperature Probe inc. LoRa & BLE - Bulk External Temperature Probe Only (Single) Americas: Europe: +1 262 375 4400 +44 1628 940 ext. 958 Korea: +82 10 2622 3935 Hong Kong: +852 2923 0610 For documentation, software, sample apps and more visit: www.lairdtech.com/rs1xx-lora-sensors
455-0009 价格&库存
很抱歉,暂时无法提供与“455-0009”相匹配的价格&库存,您可以联系我们找货
