A
SECURE, SCALABLE WIRELESS SENSORS FOR LONG RANGE IOT APPLICATIONS
Laird’s SentriusTM RS1xx External Series is a battery powered, long range
sensor platform leveraging the benefits of LoRaWAN and Bluetooth Low
Energy (BLE) connectivity. Its small, rugged form factor contains
superior RF performance and flexibility with wide ranging external
temperature probe. At its core, the RS1xx External Series utilizes Laird’s
field-proven and reliable RS1xx Series hardware, providing LoRaWAN
options in 868 and 915MHz frequencies, plus BLE for local data display,
configuration and troubleshooting. Based on the Semtech SX1272 and
Nordic nRF51 silicon, it offers a LoRa range up to 10 miles with a local
2.4 GHz connectivity option to smartphones and tablets. The RS1xx
External Series works with Laird’s SentriusTM RG1xx Series of LoRa/multiwireless gateways for simple out-of-the-box integration and is
compatible with 3rd party Cloud and LoRa network ecosystem partners.
Multi-wireless: LoRaWAN (868/915 MHz) and Bluetooth v4.2
(Central/Peripheral) with fully integrated high-performance
antennas
External Sensor Probe: wide ranging temperature sensor on
cabled IP67 probe
Fully certified for FCC/IC/CE and Bluetooth SIG
Simple wireless configuration using mobile application and BLE.
Harsh Environments: Robust IP65 enclosure to serve many varied
installation needs
Integrated out of the box networks: Default configuration with
Laird RG1xx gateways for simple, out-of-the-box cloud
connectivity
Develop a fully-owned private LoRa network to capture, route, and
process IoT data for your application - choose from RM1xx modules,
RS1xx finished sensors or RG1xx Gateways
Robust enclosures provide a robust and resilient platform for recording
and delivering sensor data from a range of harsh environments
Robust multi-layer security at each interface to safeguard your network
at every level
Cold Chain Management and Food Safety
FCC, IC, CE and Bluetooth SIG listing
Route sensor data to the Cloud with Laird’s simplified wireless
connectivity deployment
Support works with Laird engineering to help configure and deploy your
application
Contact Sales -
Americas:
Europe:
+1 262 375 4400
+44 1628 940 ext. 958
Korea:
+82 10 2622 3935
Hong Kong: +852 2923 0610
Agricultural Humidity and Environmental
Monitoring
Industrial Heating and Cooling
For documentation, software, sample apps and more visit:
www.lairdtech.com/rs1xx-lora-sensors
LoRa®
Bluetooth®
LoRa Frequencies
Temperature Accuracy
Ranges
Dimensions
Integrated
Chipset
Temperature Probe
Antenna
Power
Software
Battery
Mobile Application
Data logging
Status
User Input
Dimensions
Operating Temp.
Storage Temperature
Approvals
Storage
LED
Button
Physical
Environmental
Regulatory
Warranty
Semtech SX1272
Nordic nRF51822 – 256k / 32k
863 – 870 MHz (EU), 902 – 928 MHz (US)
-10° to 85°C
(+/-0.5°C)
-55° to +125°C
(+/-0.9°C)
Overall Length 1520mm. Stainless Steel end tube – 6.35mm DIA x 200mm Long
Custom Laird antenna for 868 or 915MHz
Ceramic chip antenna for 2.4GHz
2 x AA - replaceable
Android & iOS – Remote sensor display and/or configuration + Firmware Update
10,000 measurements (256k of flash memory available)
3 – BLE and LoRa status
Multi-use – default BLE Pairing
116 x 91 x 34 mm
-25° to +50°C (Note external probe capable of -55 to 125°C
-40° to +50°C
FCC, IC, CE, Bluetooth SIG
1-Year Warranty
The SentriusTM RS1xx External Series LoRa/BLE sensor
features integrated antennas, external temperature probe
and rugged IP65 enclosures.
ORDERING INFORMATION
455-0013
455-0010
455-0012
455-0009
455-0011
Contact Sales -
Sentrius™ RS1xx External Sensor - 868MHz External Temperature Probe inc. LoRa & BLE
Sentrius™ RS1xx External Sensor - 868MHz External Temperature Probe inc. LoRa & BLE – Bulk
Sentrius™ RS1xx External Sensor - 915MHz External Temperature Probe inc. LoRa & BLE
Sentrius™ RS1xx External Sensor - 915MHz External Temperature Probe inc. LoRa & BLE - Bulk
External Temperature Probe Only (Single)
Americas:
Europe:
+1 262 375 4400
Korea:
+82 10 2622 3935
很抱歉,暂时无法提供与“455-0012”相匹配的价格&库存,您可以联系我们找货
