455-0002
455-0002
    LAIRD(莱尔德)
    RF 传感器 868MHz 蓝牙 v4.2,LoRaWAN
455-0002 数据手册
A The SentriusTM RS1xx Series is a battery powered, long range integrated sensor platform leveraging the benefits of LoRaWAN and Bluetooth Low Energy (BLE) connectivity. Its small, rugged form factor contains superior RF performance and flexibility with precise temperature and humidity sensors, and room for future expansions. At its core, the RS1xx series utilizes our field-proven and reliable RM1xx module hardware, providing LoRaWAN options in 868, 915, and 923 MHz frequencies, plus BLE for local data display, configuration and troubleshooting. Based on the Semtech SX1272 and Nordic nRF51 silicon, it offers a LoRa range up to 10 miles with a local 2.4 GHz connectivity option to smartphones and tablets. The RS1xx Series works with our SentriusTM RG1xx Series of LoRa/multi-wireless gateways for simple out-of-the-box integration and is compatible with 3rd party cloud and LoRa network ecosystem partners. ▪ ▪ ▪ ▪ ▪ ▪ ▪ Multi-wireless: LoRaWAN (868/915/923 MHz) and Bluetooth v4.2 (Central/Peripheral) with fully integrated high-performance antennas Multi sensor: Temperature and humidity Fully certified for FCC/IC/CE/ASNZS/NCC/IMDA and Bluetooth SIG Simple wireless configuration using mobile application and BLE. Harsh Environments: Robust enclosure to serve many varied installation needs Integrated out of the box networks: Default configuration with RG1xx gateways for simple, out-of-the-box cloud connectivity New: The SentriusTM RS1xx Series now offers a range of additional sensor options available via expansion port. For more details, visit https://www.lairdconnect.com/wireless-modules/lorawansolutions/sentrius-rs1xx-lora-enabled-sensors Develop a fully-owned private LoRa network to capture, route and process IoT data for your application - choose from RM1xx modules, RS1xx finished sensors or RG1xx Gateways Robust enclosures provide a robust and resilient platform for recording and delivering sensor data from a range of harsh environments Robust multi-layer security at each interface to safeguard your network at every level Cold Chain Management and Food Safety Ready for deployment in multiple regulatory domains - FCC, IC, CE, ASNZS, NCC, IMDA and Bluetooth SIG listing Agricultural Humidity and Environmental Monitoring Route sensor data to the cloud with our simplified wireless connectivity deployment Industrial Heating and Cooling Our Tier-2 support and engineering teams work to help configure and deploy your application Interested in our RS1xx Sensor? https://www.lairdconnect.com/wireless-modules/lorawan-solutions/sentrius-rs1xx-lora-enabled-sensors Sentrius™ RS1xx Product Brief Category Feature Specification Chipset LoRa® Semtech SX1272 Bluetooth® Nordic nRF51822 – 256 k/32 k LoRa Frequencies 863 – 870 MHz (EU), 902 – 928 MHz (US), 915 – 928 MHz (AU915 + AS923) Temperature Accuracy Ranges -10° to +85°C -40° to +125°C (+/-0.4°C) (+/-1.1°C) Humidity Accuracy Ranges 0 – 90% RH 90 – 100% RH (+/- 3%) (+/- 4.5%) Antenna Integrated Custom Laird Connectivity antenna for 868, 915, or 923 MHz Ceramic chip antenna for 2.4 GHz Power Battery 2 x AA - replaceable Software Mobile Application Android & iOS – Remote sensor display and/or configuration + firmware update Storage Data logging 10,000 measurements (256 k of flash memory available) LED Status 3 – BLE and LoRa status Button User Input Multi-use – default BLE pairing Physical Dimensions 116 mm x 91 mm x 34 mm Environmental Operating Temp. -25° to +50°C Storage Temperature -40° to +50°C Approvals FCC, IC, CE, ASNZS, NCC, IMDA and Bluetooth SIG Sensors Regulatory Warranty 1-Year warranty The SentriusTM RS1xx Series LoRa/BLE sensor features integrated antennas, temperature and humidity sensors in rugged enclosures. Part Number Description 455-0001 Sentrius™ RS1xx Sensor - 915MHz Temp/Humidity including LoRa and BLE – North America 455-0002 Sentrius™ RS1xx Sensor - 868MHz Temp/Humidity including LoRa and BLE – Europe 455-00059 Sentrius™ RS1xx Sensor - 923MHz Temp/Humidity including LoRa and BLE – Taiwan 455-00060 Sentrius™ RS1xx Sensor - 923MHz Temp/Humidity including LoRa and BLE – New Zealand (AS923) 455-00061 Sentrius™ RS1xx Sensor - 923MHz Temp/Humidity including LoRa and BLE – Hong Kong 455-00062 Sentrius™ RS1xx Sensor - 915MHz Temp/Humidity including LoRa and BLE – Australia (AU915) 455-00063 Sentrius™ RS1xx Sensor - 923MHz Temp/Humidity including LoRa and BLE – Australia (AS923) 455-00095 Sentrius™ RS1xx Sensor - 923MHz Temp/Humidity including LoRa and BLE – Singapore NEW: The SentriusTM RS1xx Series now offers a range of additional sensor options available via expansion port. For more details, visit https://www.lairdconnect.com/wireless-modules/lorawan-solutions/sentrius-rs1xx-lora-enabled-sensors Interested in our RS1xx Sensor? See more at https://www.lairdconnect.com/wireless-modules/lorawan-solutions/sentrius-rs1xx-lora-enabled-sensors
455-0002 价格&库存
很抱歉,暂时无法提供与“455-0002”相匹配的价格&库存,您可以联系我们找货
