450-0132
450-0132
    LAIRD(莱尔德)
    KIT RF DEV SIFLEX02-R2-HP U.FL
450-0132 数据手册
SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET Integrated Transceiver Modules for ZigBee / 802.15.4 (900 MHz) Development Kit Available FEATURES DESCRIPTION  750mW output power  Long range  Up to 1Mbps RF data rate  Miniature footprint: 0.9” x 1.63”  Multiple antenna options  Dual antennas  Agency Approvals: FCC and IC  Powerful Atmel 256k ATXMEGA256A3U with 802.15.4 MAC or ZigBee Stack  LSR serial interface based on 802.15.4 MAC  Low power operation  RoHS compliant  Streamlined development with LSR design services.  License options available to purchase design or integrate design. APPLICATIONS  Security  Lighting Control  HVAC Control  Sensor Networks  Medical  Industrial Automation The SiFLEX02-R2-HP module is a high performance 900MHz IEEE 802.15.4 radio (AT86RF212B & RF amplifier circuit) and microcontroller (ATXMEGA256A3U) in a cost effective, pre-certified footprint. The module comes preloaded with the LSR host serial interface running on top of the Atmel 802.15.4 MAC. Full debug and programming capabilities are included to develop custom applications. Easily load the ZigBee stack or 802.15.4 MAC onto the module and create your own network. Need to get to market quickly? Not an expert in 802.15.4 or ZigBee? Need a custom antenna? Would you like to own the design? Would you like a custom design*n? Not quite sure what you need? Do you need help with your host board? LS Research Design Services will be happy to develop custom hardware or software, integrate the design, or license the design so you can manufacture yourself. Contact us at sales@lsr.com or call us at 262-375-4400. ORDERING INFORMATION Order Number Description 450-0127 SiFLEX02-R2-HP Module with U.FL connectors for external antennas (Tray) SPQ = 25, MOQ = 50 450-0128 SiFLEX02-R2-HP Module with castellated RF traces for off board antenna. Note: See Antenna Options section for more details. (Tray) SPQ = 25, MOQ = 1,000 NOTE: Non-standard part. Contact LSR directly for more information. 450-0132 SiFLEX02-R2-HP U.FL Development Kit Table 1 Orderable SiFLEX02-R2-HP Model Numbers The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 1 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET MODULE ACCESSORIES Order Number Description 001-0002 900 MHz Dipole Antenna with Reverse Polarity SMA Connector 080-0001 U.FL to Reverse Polarity SMA Bulkhead Cable 105mm Table 2 Module Accessories The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 2 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET Analog TMR/PWM BLOCK DIAGRAM Antenna RF Front End ATXMEGA256A3U (Microcontroller) SPI AT86RF212B (802.15.4 Radio) Power Amplifier / LNA Antenna GPIO PGM/DBG Serial I/O Figure 1 SiFLEX02-R2-HP Module Block Diagram – High-Level DEVELOPMENT KIT The SiFLEX02-R2-HP Development Kit can be used out of the box to evaluate RF range performance with the simple press of a button. Users interested in further investigating the performance and capabilities of the SiFLEX02R2-HP Module can use the ModFLEXTM Test Tool. This PC-based software can demonstrate just how easy it is to send & receive data, collect performance data, change channels, power levels, or addresses using the LSR Serial Host Protocol with another microcontroller. More advanced users can use the development board to create and debug their own software for the SiFLEX02-R2-HP module using the 802.15.4 MAC or ZigBee stack from Atmel. Part Number Description 450-0132 SiFLEX02-R2-HP Dev Kit Figure 2 SiFLEX02-R2-HP Development Board Kit Contents  ModFLEX Development Board with SiFLEX02-R2-HP Module with external antennas (x2)  USB Cable (x2)  AA Batteries (x4)  Software & Technical Information CD TM The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 3 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET TABLE OF CONTENTS FEATURES .......................................................................................................................... 1 APPLICATIONS ................................................................................................................... 1 DESCRIPTION ..................................................................................................................... 1 ORDERING INFORMATION ................................................................................................ 1 MODULE ACCESSORIES ................................................................................................... 2 BLOCK DIAGRAM ............................................................................................................... 3 DEVELOPMENT KIT............................................................................................................ 3 Kit Contents ................................................................................................................................................. 3 MODULE PINOUT AND PIN DESCRIPTIONS .................................................................... 6 MODULE OVERVIEW ........................................................................................................ 10 Microcontroller .......................................................................................................................................... 10 Radio .......................................................................................................................................................... 12 RF Front End (Power Amplifier and LNA) ............................................................................................... 13 Antenna Options ....................................................................................................................................... 14 OPERATING MODES TRUTH TABLE .............................................................................. 15 MODES OF OPERATION .................................................................................................. 16 Host Microcontroller ................................................................................................................................. 16 Software Stacks ........................................................................................................................................ 16 DEVELOPMENT TOOLS ................................................................................................... 18 AVR Studio................................................................................................................................................. 18 WinAVR ...................................................................................................................................................... 18 AVR JTAGICE mkII .................................................................................................................................... 18 AVRISP mkII ............................................................................................................................................... 18 IAR Embedded Workbench for Atmel AVR ............................................................................................ 18 ELECTRICAL SPECIFICATIONS ...................................................................................... 19 Absolute Maximum Ratings ..................................................................................................................... 19 Recommended Operating Conditions .................................................................................................... 19 General Characteristics ............................................................................................................................ 20 RF Characteristics .................................................................................................................................... 21 The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 4 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET SOLDERING RECOMMENDATIONS ................................................................................ 24 Recommended Reflow Profile for Lead Free Solder ............................................................................. 24 CLEANING ......................................................................................................................... 25 OPTICAL INSPECTION ..................................................................................................... 25 REWORK ........................................................................................................................... 25 SHIPPING, HANDLING, AND STORAGE ......................................................................... 25 Shipping ..................................................................................................................................................... 25 Handling ..................................................................................................................................................... 25 Moisture Sensitivity Level (MSL) ............................................................................................................. 25 Storage ....................................................................................................................................................... 25 Repeating Reflow Soldering .................................................................................................................... 26 AGENCY STATEMENTS ................................................................................................... 27 MECHANICAL DATA......................................................................................................... 33 PCB Footprint ............................................................................................................................................ 33 General Module Dimensions .................................................................................................................... 34 COMPATIBILITY ................................................................................................................ 35 TRAY PACKAGING (MM) .................................................................................................. 36 MODULE REVISION HISTORY ......................................................................................... 37 Rev 1.0 ........................................................................................................................................................ 37 CONTACTING LS RESEARCH ......................................................................................... 38 The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 5 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET MODULE PINOUT AND PIN DESCRIPTIONS MCU# 10 11 12 13 56 57 62 64 63 5 2 3 4 7 8 9 - GND GND GND NC NC VPA VPA NC JTAG TMS JTAG TDI JTAG TCK JTAG TDO 1 69 2 68 3 67 4 66 5 65 6 64 7 63 8 62 9 61 10 60 11 59 12 58 SiFLEX02-R2-HP (Atmel ATXMEGA256A3U) JTAG/PDI/JRST 13 nRESET PA0 NC PA2 PA1 PA7 PA4 PA5 PA6 PB1 PB2 PB3 VCC - 3V3DC 14 57 56 15 55 16 54 17 53 18 52 19 51 20 50 21 49 22 48 23 47 24 46 25 45 26 44 GND GND GND NC NC NC NC NC PC5 PC6 PC7 PC4 PE0 PE1 NC NC NC NC NC NC NC NC NC NC NC GND MCU# 21 22 23 20 36 37 - NC PF7 PF6 PF5 PC0 PC1/CTS PC2/UART RX PC3/UART TX PE2 PE3 PE4 PE5 PF0 PF1 49 48 47 46 41 40 39 38 19 18 17 16 51 54 55 PA3 MCU# PF2 PF3 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 1 - MCU# Figure 3 Module Pinout The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 6 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET Module Pin Name MCU Pin Type 1 GND N/A GND Ground 2 GND N/A GND Ground 3 GND N/A GND Ground 4 NC N/A NC No Connect 5 NC N/A NC No Connect 6 VPA N/A PWR RF Power Amplifier Supply Voltage For 750mW output power provide 4.0VDC For .5W output power provide 3.3VDC 7 VPA N/A PWR RF Power Amplifier Supply Voltage For 750mW output power provide 4.0VDC For .5W output power provide 3.3VDC 8 NC N/A NC No Connect 9 JTAG TMS 10 I/O General-purpose digital I/O (PB4), Analog input, JTAG TMS 10 JTAG TDI 11 I/O General-purpose digital I/O (PB5), Analog input, JTAG TDI 11 JTAG TCK 12 I/O General-purpose digital I/O (PB6), Analog input, JTAG TCK 12 JTAG TDO 13 I/O General-purpose digital I/O (PB7), Analog input, JTAG TDO 13 JTAG/PDI/JRST 56 I/O PDI/PDI_DATA 14 nRESET 57 Input 15 PA0 62 I/O General-purpose digital I/O, Analog input, Analog REF A 16 NC N/A NC No Connect 17 PA2 64 I/O General-purpose digital I/O, Analog input, Analog comparator 2 18 PA1 63 I/O General-purpose digital I/O, Analog input, Analog comparator 1 19 PA7 5 I/O General-purpose digital I/O, Analog input, Analog comparator output 20 PA4 2 I/O General-purpose digital I/O, Analog input 21 PA5 3 I/O General-purpose digital I/O, Analog input 22 PA6 4 I/O General-purpose digital I/O, Analog input 23 PB1 7 I/O General-purpose digital I/O, Analog input 24 PB2 8 I/O General-purpose digital I/O, Analog input 25 PB3 9 I/O General-purpose digital I/O, Analog input 26 VCC - 3V3DC VCC VCC 27 PF3 49 I/O General-purpose digital I/O, Output Compare, UART Tx 28 PF2 48 I/O General-purpose digital I/O, Output Compare, UART Rx 29 PF1 47 I/O General-purpose digital I/O, Output Compare, UART XCK0 Description RESET/PDI_CLOCK Supply Voltage The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 7 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET Module Pin Name MCU Pin Type 30 PF0 46 I/O General-purpose digital I/O, Output Compare 31 PE5 41 I/O General-purpose digital I/O, Output Compare, UART XCK1, SPI MOSI 32 PE4 40 I/O General-purpose digital I/O, Output Compare, SPI SS 33 PE3 39 I/O General-purpose digital I/O, Output Compare, UART Tx 34 PE2 38 I/O General-purpose digital I/O, Output Compare, UART Rx 35 PC3, UART TX 19 I/O General-purpose digital I/O, Output Compare, UART Tx 36 PC2, UART RX 18 I/O General-purpose digital I/O, Output Compare, UART Rx 37 PC1 17 I/O General-purpose digital I/O, Output Compare, IIC SCL 38 PC0 16 I/O General-purpose digital I/O, Output Compare, IIC SDA 39 PF5 51 I/O General-purpose digital I/O 40 PF6 54 I/O General-purpose digital I/O 41 PF7 55 I/O General-purpose digital I/O 42 PA3 1 I/O General-purpose digital I/O, Analog input 43 NC N/A NC No Connect 44 GND N/A GND 45 NC N/A NC No Connect 46 NC N/A NC No Connect 47 NC N/A NC No Connect 48 NC N/A NC No Connect 49 NC N/A NC No Connect 50 NC N/A NC No Connect 51 NC N/A NC No Connect 52 NC N/A NC No Connect 53 NC N/A NC No Connect 54 NC N/A NC No Connect 55 NC N/A NC No Connect 56 PE1 37 I/O General-purpose digital I/O, Output Compare, IIC SCL 57 PE0 36 I/O General-purpose digital I/O, Output Compare, IIC SDA 58 PC4 20 I/O General-purpose digital I/O, Output Compare, SPI SS 59 PC7 23 I/O General-purpose digital I/O, Output Compare, UART Tx, SPI SCK 60 PC6 22 I/O General-purpose digital I/O, Output Compare, UART Rx, SPI MISO Description Ground The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 8 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET Module Pin Name MCU Pin Type 61 PC5 21 I/O General-purpose digital I/O, Output Compare, UART XCK1, SPI MOSI 62 NC N/A NC No Connect 63 NC N/A NC No Connect 64 NC N/A NC No Connect 65 NC N/A NC No Connect 66 NC N/A NC No Connect 67 GND N/A GND Ground 68 GND N/A GND Ground 69 GND N/A GND Ground Description Table 3 SiFLEX02-R2-HP Module Pin Descriptions The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 9 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET MODULE OVERVIEW Figure 4 shows the internal interconnects of the ICs on the SiFLEX02-R2-HP module. Consult the respective IC datasheets for details, or contact LSR sales to purchase the SiFLEX02-R2-HP module schematics as part of LSR’s ModFLEX™ design program. For a high-level block diagram of the SiFLEX02-R2-HP module, see Figure 1. Antenna 1 26 27 /RST RX_START 28 IRQ 29 Atmel ATXMEGA256A3U SLP_TR 30 /SEL 31 MOSI 32 MISO 33 59 6 SCLK 8 10 1 24 2 11 9 23 22 DIG3 (TX EN) DIG4 (RX EN) DIG1 (ANT_SW) Atmel AT86RF212B RF Power Amplifier / LNA / TX/RX Switches Antenna 2 20 19 50 ANT_SEL VPA_AD VGE PA/LNA Power Supply Supply Voltage Figure 4 SiFLEX02-R2-HP Module Block Diagram – Internal Interconnects Microcontroller The AVR XMEGA A3U is a family of low power, high performance and peripheral rich CMOS 8/16-bit microcontrollers based on the AVR® enhanced RISC architecture. By executing powerful instructions in a single clock cycle, the XMEGA A3U achieves throughputs approaching 1 Million Instructions Per Second (MIPS), thus allowing the system designer to optimize power consumption versus processing speed. Figure 5 shows a block diagram of the ATXMEGA256A3U. The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 10 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET Figure 5 ATXMEGA256A3U Block Diagram The AVR CPU combines a rich instruction set with 32 general purpose working registers. All the 32 registers are directly connected to the Arithmetic Logic Unit (ALU), allowing two independent registers to be accessed in one single instruction, executed in one clock cycle. The resulting architecture is more code efficient while achieving throughputs many times faster than conventional singleaccumulator or CISC based microcontrollers. The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 11 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET The AVR XMEGA A3U devices have five software selectable power saving modes. The Idle mode stops the CPU while allowing the SRAM, DMA Controller, Event System, Interrupt Controller and all peripherals to continue functioning. The Power-down mode saves the SRAM and register contents but stops the oscillators, disabling all other functions until the next TWI or pin-change interrupt, or Reset. In Power-save mode, the asynchronous Real Time Counter continues to run, allowing the application to maintain a timer base while the rest of the device is sleeping. In Standby mode, the Crystal/Resonator Oscillator is kept running while the rest of the device is sleeping. This allows very fast start-up from external crystal combined with low power consumption. In Extended Standby mode, both the main Oscillator and the Asynchronous Timer continue to run. To further reduce power consumption, the peripheral clock for each individual peripheral can optionally be stopped in Active mode and Idle sleep mode. Radio The AT86RF212B is a low-power, low-voltage 900 MHz transceiver specially designed for low-cost IEEE 802.15.4, ZigBee™, and high data rate ISM applications. For the sub-1 GHz bands, it supports a low data rate of 40kbps of the IEEE 802.15.4-2003 standard and provides an optional data rate 250kbps using O-QPSK, according to IEEE 802.15.4-2006. Furthermore hardware accelerators improve overall system power efficiency and timing. The receiver path is based on a low-IF architecture. After channel filtering and down conversion the low-IF signal is sampled and applied to the digital signal processing part. Communication between transmitter and receiver is based on direct sequence spread spectrum with different modulation schemes and spreading codes. The AT86RF212B supports the IEEE 802.15.4-2006 standard mandatory BPSK modulation and optional O-QPSK modulation in the 900 MHz band. For applications not necessarily targeting IEEE compliant networks the radio transceiver supports proprietary High Data Rate Modes based on O-QPSK. The AT86RF212B features hardware supported 128 bit security operation. The standalone AES encryption/decryption engine can be accessed in parallel to all PHY operational modes. Configuration of the AT86RF212, reading, and writing of data memory as well as the AES hardware engine are controlled by the SPI interface and additional control signals. The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 12 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET Figure 6 AT86RF212B Block Diagram RF Front End (Power Amplifier and LNA) The SiFLEX02-R2-HP module contains a high performance RF Front End, containing both a RF Power Amplifier as well as a LNA. It is capable of 750mW output power, providing miles of range in outdoor applications. The signals DIG3 and DIG4 from the RF212B radio are used for transmit enable (TXEN) and receive enable (RXEN) respectively. When transmitting the DIG3 signal will be high and DIG4 will be low, which is controlled by the RF212. When receiving DIG3 will be low and DIG4 is high. In order to configure this functionality, the PA_EXT_EN bit in register TRX_CTRL_1 (0x04) of the RF212B needs to be set as a one. In addition the bits PA_LT[1] and PA_LT[0] in register RF_CTRL_0 (0x16) should both be set to one to maximize the PA lead time to 8usec. When putting the module to sleep the PA_EXT_EN bit should be set as zero. Upon wakeup the PA_EXT_EN should be set back to one. The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 13 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET Antenna Options The SiFLEX02-R2-HP module includes multiple antenna options. The module’s regulatory certification has been completed with the following antenna:  LS Research 001-0002 900 MHz Dipole Antenna with Reverse Polarity SMA Connector and LS Research 080-0001 U.FL to Reverse Polarity SMA Bulkhead Cable (105mm in length) The SiFLEX02-R2-HP RF castellations for off board antennas are not covered in the modular certification. If a host board is designed that will utilize off board antennas via the RF castellated antenna connections, an additional certification will be required. LS Research is equipped with a certification lab and can assist in getting this done at a very reasonable cost in a short period of time. An adequate ground plane is necessary to provide good efficiency. The ground plane of the host board on which the module is mounted increases the effective antenna ground plane size and improves the antenna performance. The environment the module is placed in will dictate the range performance The non-ideal characteristics of the environment will result in the transmitted signal being reflected, diffracted, and scattered. All of these factors randomly combine to create extremely complex scenarios that will affect the link range in various ways. It is also best to keep some clearance between the antennas and nearby objects. This includes how the module is mounted in the product enclosure. Unless the items on the following list of recommendations are met, the radiation pattern can be heavily distorted. Whichever antenna is used, it is best to keep a few things in mind when determining its location.  Never place ground plane or copper trace routing underneath the antenna.  LSR recommends keeping metal objects as far away from the antenna as possible. At a very minimum keep the antenna at least 5 cm from any metallic objects, components, or wiring. The farther the antenna is placed from these interferers, the less the radiation pattern and gain will be perturbed.  Do not embed the antenna in a metallic or metalized plastic enclosure.  If located within a plastic enclosure, keep the enclosure at least 1 cm from the antenna. The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 14 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET OPERATING MODES TRUTH TABLE Mode VGE LNA_EN ANT_SW ANT_SEL Sleep 0 0 0 0 Transmit – Ant J3, RF1 1 X 1 X Transmit – Ant J4, RF2 1 X 0 X Receive with LNA Disabled – Ant J3, RF1 1 1 X 1 Receive with LNA Disabled – Ant J4, RF2 1 1 X 0 Receive with LNA Enabled – Ant J3, RF1 1 0 X 1 Receive with LNA Enabled – Ant J4, RF2 1 0 X 0 Note: X = Don’t Care Table 4 Operating Modes Truth Table The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 15 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET MODES OF OPERATION  With a host microcontroller  With the Atmel 802.15.4 MAC  With the Atmel ZigBee stack Host Microcontroller PC LSR Test Tool Software Figure 8 ModFLEX™ Test Tool Communications Log UART Si-FLEX Module on Evaluation Board -OR- Your Microcontroller (Host) of Choice UART Si-FLEX Module on Your Board Some examples of serial commands that can be used with the SiFLEX02-R2-HP Module:  Set/Query RF channel  Set/Query RF power  Set/Query device address  Transmit RF data or notification RF data received  Go to Sleep Software Stacks Figure 7 Host Microcontroller Modes of Operation Out of the box the SiFLEX02-R2-HP module contains an 802.15.4 based application that uses a host serial processor. This allows features of the module to be explored with the LSR PC based test tool, or controlled with a host microcontroller. The advantage of this method is simplicity; all major features of using the radio are simplified into a simple serial message, taking the burden of becoming a radio expert off the developer. Use the Communications Log in the ModFLEX™ Test Tool software and serial host protocol documents to see the messages in action. It will help you become familiar with the serial commands and how to implement them on your own microcontroller. There are two software stacks provided by Atmel to streamline development: MAC (802.15.4) Atmel ZigBee Stack Overall Complexity and Development Effort Figure 9 SiFLEX02-R2-HP Compatible Stacks 802.15.4 MAC    Use for applications requiring point-topoint or star network topology. Advantages: Quick learning curve, minimize software development, easy to deploy in the field Disadvantages: No mesh networking The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 16 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET  Application Software (to control switches, LED’s, serial ports and so on) Software Interface Disadvantages: Large learning curve, more software development, complexity 802.15.4 MAC (To Tx/Rx RF data) Application Software (to control switches, LED’s, serial ports and so on) Software Interface ZigBee Stack (To Tx/Rx RF data) Figure 10 SiFLEX02-R2-HP with 802.15.4 MAC Atmel ZigBee Stack  Use when mesh networking is required.  Advantages: Covers a large area with a ZigBee network. Figure 11 SiFLEX02-R2-HP with Atmel ZigBee Stack The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 17 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET DEVELOPMENT TOOLS AVR Studio AVR Studio® is an Integrated Development Environment (IDE) for writing and debugging AVR® applications. AVR Studio includes an assembler, simulator, and in-circuit debugger. AVR Studio is the Integrated Development Environment (IDE) developed by Atmel for writing and debugging Atmel AVR applications. Figure 12 JTAGICE mkII WinAVR WinAVR is a suite of executable, open source software development tools for the Atmel AVR series of RISC microprocessors hosted on the Windows platform. It includes the GNU GCC compiler for C/C++. WinAVR contains all the tools for developing on AVR family microcontrollers from Atmel. This includes avr-gcc (compiler), avrdude (programmer), avr-gdb (debugger), and more. AVRISP mkII Another option for in-circuit programming is the AVRISP mkII from Atmel, Figure 13. The AVRISP mkII combined with AVR Studio® can program new AVR 8-bit RISC microcontrollers with ISP Interface. AVR JTAGICE mkII Custom firmware development can be done on the SiFLEX02-R2-HP module using development tools available through Atmel. Shown inError! Reference source not found., JTAGICE mkII interface is required. It plugs into the ModFLEX™ Development Board, and can easily be adapted to other hardware. See the Atmel website for more information and ordering options. Figure 13 AVRISP mkII IAR Embedded Workbench for Atmel AVR Another option is IAR Embedded Workbench for Atmel AVR. IAR Embedded Workbench for AVR is an integrated development environment for building and debugging embedded applications. Visit the IAR Systems website for additional information. The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 18 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET ELECTRICAL SPECIFICATIONS The majority of these characteristics are based on the use of the Atmel IEEE 802.15.4 MAC loaded with the generic application firmware written by LSR. Custom firmware may require these values to be re-characterized by the customer. Absolute Maximum Ratings Rating Min Max Unit Power supply voltage (VCC) 0 3.6 V Power Amplifier supply voltage (VPA) 0 4.5 V -0.3 Vcc + 0.3 V +10 dBm +85 ºC +150 ºC Voltage on any pin with respect to ground RF input power Operating temperature range -40 Storage temperature -50 Table 5 Absolute Maximum Ratings 1 Recommended Operating Conditions Characteristic Min Typ Max Unit Power supply voltage (VCC) 2.5 3.3 3.50 Vdc Power Amplifier supply voltage (VPA) 3.0 4.0 4.25 Vdc Ambient temperature range -40 25 85 ºC Table 6 Recommended Operating Conditions Operation of Vcc below 3.0v will result in a significant reduction in RF output power. Module will NOT transmit, if VPA > 4.25V. 1 Under no circumstances should exceeding the maximum ratings specified in the Absolute Maximum Ratings section be allowed. Stressing the module beyond these limits may result permanent damage to the module that is not covered by the warranty. The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 19 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET General Characteristics Parameter Min RF frequency range (Note 1, 2) Typ Max Unit 906 924 MHz RF data rate 40 1000 kbps Host data rate 1.2 921.6 kbps 19.2 Flash memory 256 kBytes RAM 16 kBytes EEPROM 4 kBytes Table 7 General Characteristics Note 1: The frequency range needs to be restricted to 915 to 924 MHz (channels 6-10) to meet Australian/New Zealand standards. Note 2:Due to the band pass filter, receiver sensitivity is reduced by approximately 1dB on channels 1, 2, 8, 9, and 10 (906MHz, 908MHz, 920MHz, 922MHz, and 924MHz). This improves receiver performance in the presence of interferers on channels 3, 4, 5, 6, and 7 (910MHz, 912MHz, 914MHz, 916MHz, and 918MHz). Power Consumption (TA = 25°C, VCC = 3.3V, VPA = 4.0V, fc = 906-924MHz, Rload = 50Ω) Parameter Transmit mode - VPA Test Conditions Min Maximum power step Transmit mode - VCC Typ Max Unit 450 600 mA 50 Receive mode - VPA Receive mode - VCC 27 1 uA 48 mA 1 µA 2 5 uA Typ Max Unit 39 Sleep mode - VPA Sleep mode - VCC mA Table 8 Power Consumption DC Characteristics – General Purpose I/O Parameter Test Conditions Min Logic input low -0.3 0.2 * Vcc V Logic input high 0.8 * Vcc Vcc + 0.3 V Logic output low IOUT = 15mA Vcc = 3.3V 0.4 V Logic output high IOUT = -8mA Vcc = 3.3V 2.9 V Table 9 DC Characteristics – General Purpose I/O The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 20 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET RF Characteristics Transmitter Characteristics (TA = 25°C, VCC = 3.3V, VPA = 4.0V, fc = 906-924 MHz) Parameter Test Conditions Min Typ Max Unit Nominal max output power (40kbps) 750mW (Notes: 1, 2) 26 27 29 dBm Nominal max output power (250kbps and higher) 750mW (Notes: 1, 2) 27 28 29 dBm Programmable output power range 22 Steps 15 28 dBm Harmonics (2fo) -50 dBm Harmonics (3fo) -55 dBm Error vector magnitude 10 35 % rms Table 10 Transmitter RF Characteristics Note 1: In accordance with FCC Part 15.247(e) and RSS 210 A8.2(b), the peak power spectral density should not exceed +8 dBm in any 3 KHz band. Note 2: In accordance with Australian/New Zealand 4268 : 2008, the peak power spectral density should not exceed +14dBm in any 3 KHz band in the 915 to 928 MHz frequency band. The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 21 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET RF Output Power and Transmit Current (TA = 25°C, VCC = 3.3V, VPA = 4.0V, fc = 914 MHz) Host Protocol RF Power Level AT86RF212 PHY_TX_PWR Register Value 21 BPSK into 50 ohms at U.FL RF Output Power (dBm) Typical Current Consumption (mA) 0xE7 27.9 465 20 0xE7 27.9 454 19 0xE7 27.8 442 18 0xE8 27.6 425 17 0xE8 27.2 393 16 0x42 26.5 365 15 0x43 26.2 346 14 0x23 26.0 338 13 0x23 25.5 318 12 0x24 25.1 304 11 0x66 24.3 281 10 0x04 24.3 277 9 0x05 23.3 254 8 0x06 22.4 236 7 0x07 21.5 219 6 0x08 20.6 207 5 0x08 19.9 198 4 0x09 18.9 188 3 0x0A 18.0 181 2 0x0B 17.2 177 1 0x0C 16.2 173 0 0x0D 15.3 171 Table 11 RF Power Settings The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 22 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET Receiver Characteristics (TA = 25°C, VCC = 3.3V, VPA = 4.0V, fc = 906-924 MHz) Parameter Test Conditions Min Typ Max Unit Receiver Sensitivity @ 1% PER BPSK 40kbit/s < -104 dBm Saturation Level @ 1% PER BPSK 40kbit/s -2 dBm Table 12 Receiver RF Characteristics For additional details regarding the electrical specifications, refer to the ATXMEGA256A3U and AT86RF212B datasheets on the Atmel website. The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 23 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET SOLDERING RECOMMENDATIONS Recommended Reflow Profile for Lead Free Solder Note: The quality of solder joints on the castellations (‘half vias’) where they contact the host board should meet the appropriate IPC Specification. See IPC-A-610-D Acceptability of Electronic Assemblies, section 8.2.4 Castellated Terminations.” The information in this document is subject to change without notice. 330-0153-R1.1 Copyright © 2014 LS Research, LLC Page 24 of 38 SiFLEX02-R2-HP TRANSCEIVER MODULE DATASHEET CLEANING In general, cleaning the populated modules is strongly discouraged. Residuals under the module cannot be easily removed with any cleaning process.    Cleaning with water can lead to capillary effects where water is absorbed into the gap between the host board and the module. The combination of soldering flux residuals and encapsulated water could lead to short circuits between neighboring pads. Water could also damage any stickers or labels. Cleaning with alcohol or a similar organic solvent will likely flood soldering flux residuals into the RF shield, which is not accessible for post-washing inspection. The solvent could also damage any stickers or labels. Ultrasonic cleaning could damage the module permanently. OPTICAL INSPECTION After soldering the Module to the host board, consider optical inspection to check the following:  Proper alignment and centering of the module over the pads.  Proper solder joints on all pads.  Excessive solder or contacts to neighboring pads, or vias. REWORK The module can be unsoldered from the host board if the Moisture Sensitivity Level (MSL) requirements are met as described in this datasheet. Never attempt a rework on the module itself, e.g. replacing individual components. Such actions will terminate warranty coverage. SHIPPING, HANDLING, AND STORAGE Shipping Bulk orders of the SiFLEX02-R2-HP modules are delivered in trays of 25. Handling The SiFLEX02-R2-HP modules contain a highly sensitive electronic circuitry. Handling without proper ESD protection may damage the module permanently. Moisture Sensitivity Level (MSL) Per J-STD-020, devices rated as MSL 4 and not stored in a sealed bag with desiccant pack should be baked prior to use. After opening packaging, devices that will be subjected to reflow must be mounted within 72 hours of factory conditions (
450-0132 价格&库存
很抱歉,暂时无法提供与“450-0132”相匹配的价格&库存,您可以联系我们找货
