A18145-03
A18145-03
    LAIRD(莱尔德)
    热垫 灰色 228.60mm x 228.60mm 方形 胶粘 - 两侧
A18145-03 数据手册
Tflex RB300 Series Thermal Gap Filler PRODUCT DESCRIPTION Tflex™ RB300 is an exceptionally soft gap filler pad with a thermal conductivity of 1.2 W/mK. Tflex RB300 is specially formulation to minimize the amount of silicone oil bleed in sensitive applications. Tflex™ RB300, in achieving its stellar compliancy, does not sacrifice thermal performance. With a thermal conductivity of 1.2 W/mK, low thermal resistances can be achieved at low pressures. Tflex™ RB300 is naturally tacky and requires no additional adhesive coating that can inhibit thermal performance. FEATURES AND BENEFITS • Extreme compliancy allows material to “totally blanket” components • Thermal conductivity of 1.2 W/mK • Minimal silicone oil bleed • Environmentally friendly solution that meets RoHS and REACH requirements SPECIFICATIONS Americas: +1.866.928.8181 Europe: +49.(0).8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com TYPICAL PROPERTIES VALUE TEST METHOD Construction & Composition Color Thickness Range N/A Visual N/A Thermal Conductivity (W/mK) Density (g/cc) Ceramic filled silicone sheet Grey 0.5 mm (0.020”) - 5.08mm (0.20”) 1.2 1.78 Hardness (Shore 00) Outgassing TML (weight %) Outgassing CVCM (weight %) Temperature Range Rth@ 40 mils, 10 psi, 500C 27 0.22 0.05 -25°C to 200°C 1 .14 0C–in2/W UL Flammability Rating Volume Resistivity V-0 10^14 ohm-cm Hot Disk Helium Pycnometer ASTM D2240 ASTM E595 ASTM E595 N/A ASTM D5470 (modified) UL 94 ASTM D257 Tflex RB300 Series Thermal Gap Filler Thermal Resistance vs Pressure 4.000 C-in2/W 3.500 C-in2/W 3.000 C-in2/W 2.500 C-in2/W 2.000 C-in2/W 1.500 C-in2/W 1.000 C-in2/W 0.500 C-in2/W 0.000 C-in2/W 10psi 40 mil 20psi 30psi 80 mil 40psi 50psi 100 mil 60psi 70psi 120 mil 80psi 160 mil 90psi 100psi 200 mil Deflection vs Pressure 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% 5psi 10psi 40 mil 20psi 80 mil 30psi 40psi 100 mil 50psi 60psi 120 mil 70psi 80psi 160 mil 90psi 100psi 200 mil AVAILABILITY STANDARD THICKNESSES  0.5mm (0.020”) to 5.0mm (0.200”) thick material available in 0.25mm (0.010”) increments  Available in standard sheet sizes of 18” x 18” and 9” x 9” or custom die cut parts PART NUMBER SYSTEM Tflex™ indicates Laird elastomeric thermal gap filler product line. RB3xxx indicates Tflex RB300 product line with thickness in mils (0.001”) EXAMPLES:  Tflex™ RB340 = 0.040 inch thick Tflex™ RB300 material A18156-00 Tflex RB300 DS 081621 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
A18145-03 价格&库存
很抱歉,暂时无法提供与“A18145-03”相匹配的价格&库存,您可以联系我们找货
