Tflex RB300 Series
Thermal Gap Filler
PRODUCT DESCRIPTION
Tflex™ RB300 is an exceptionally soft gap filler pad with a thermal conductivity of
1.2 W/mK. Tflex RB300 is specially formulation to minimize the amount of silicone
oil bleed in sensitive applications.
Tflex™ RB300, in achieving its stellar compliancy, does not sacrifice thermal
performance. With a thermal conductivity of 1.2 W/mK, low thermal resistances
can be achieved at low pressures.
Tflex™ RB300 is naturally tacky and requires no additional adhesive coating that
can inhibit thermal performance.
FEATURES AND BENEFITS
• Extreme compliancy allows material to “totally blanket” components
• Thermal conductivity of 1.2 W/mK
• Minimal silicone oil bleed
• Environmentally friendly solution that meets RoHS and REACH requirements
SPECIFICATIONS
Americas: +1.866.928.8181
Europe: +49.(0).8031.2460.0
Asia: +86.755.2714.1166
www.lairdtech.com
TYPICAL PROPERTIES
VALUE
TEST METHOD
Construction & Composition
Color
Thickness Range
N/A
Visual
N/A
Thermal Conductivity (W/mK)
Density (g/cc)
Ceramic filled silicone sheet
Grey
0.5 mm (0.020”) - 5.08mm
(0.20”)
1.2
1.78
Hardness (Shore 00)
Outgassing TML (weight %)
Outgassing CVCM (weight %)
Temperature Range
Rth@ 40 mils, 10 psi, 500C
27
0.22
0.05
-25°C to 200°C
1 .14 0C–in2/W
UL Flammability Rating
Volume Resistivity
V-0
10^14 ohm-cm
Hot Disk
Helium
Pycnometer
ASTM D2240
ASTM E595
ASTM E595
N/A
ASTM D5470
(modified)
UL 94
ASTM D257
Tflex RB300 Series
Thermal Gap Filler
Thermal Resistance vs Pressure
4.000 C-in2/W
3.500 C-in2/W
3.000 C-in2/W
2.500 C-in2/W
2.000 C-in2/W
1.500 C-in2/W
1.000 C-in2/W
0.500 C-in2/W
0.000 C-in2/W
10psi
40 mil
20psi
30psi
80 mil
40psi
50psi
100 mil
60psi
70psi
120 mil
80psi
160 mil
90psi 100psi
200 mil
Deflection vs Pressure
100%
90%
80%
70%
60%
50%
40%
30%
20%
10%
0%
5psi
10psi
40 mil
20psi
80 mil
30psi
40psi
100 mil
50psi
60psi
120 mil
70psi
80psi
160 mil
90psi
100psi
200 mil
AVAILABILITY
STANDARD THICKNESSES
0.5mm (0.020”) to 5.0mm (0.200”) thick material available in 0.25mm (0.010”) increments
Available in standard sheet sizes of 18” x 18” and 9” x 9” or custom die cut parts
PART NUMBER SYSTEM
Tflex™ indicates Laird elastomeric thermal gap filler product line. RB3xxx indicates Tflex RB300 product line with
thickness in mils (0.001”)
EXAMPLES:
Tflex™ RB340 = 0.040 inch thick Tflex™ RB300 material
A18156-00 Tflex RB300 DS 081621
Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end
user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or
consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies,
Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third
parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
很抱歉,暂时无法提供与“A18144-10”相匹配的价格&库存,您可以联系我们找货
