TflexTM HD7.5 Series
Thermal Gap Filler
Preliminary Data Sheet
PRODUCT DESCRIPTION
Tflex™ HD7.5 gap filler is a very soft silicone material in our high deflection series. With a thermal
conductivity of 7.5W/ mk, Tflex™ HD7.5 is designed to provide superior pressure versus deflection
characteristics. The material will provide minimal stress on components during application while
maintaining low thermal resistance. As a result, less mechanical and thermal stresses will be
experienced within your device.
Tflex™ HD7.5 gap filler is available in thickness from 1mm (0.040”) to 5mm (0.200”). Laird can provide
material to meet your production needs in any region through our local production facilities. Please
contact your local Laird sales or field engineering contact for samples or questions.
FEATURES AND BENEFITS
7.5 W/mK thermal conductivity
Low pressure versus deflection
Minimizes board and component stress
Low Outgassing and oil bleeding
Large tolerance applications
SPECIFICATIONS
TYPICAL PROPERTIES
VALUE
TEST METHOD
Construction & Composition
Color
Thickness Range
Ceramic filled silicone sheet
Grey
1mm (0.40”) - 5mm (0.200”)
N/A
Visual
N/A
Thermal Conductivity (W/mK)
Density (g/cc)
Hardness Shore 00 (3 sec)
Hardness Shore 000 (3 sec)
Outgassing TML (weight %)
7.5
7.8
3.4
15
60
TBD
Hot Disk
ASTMD5470
Helium Pycnometer
ASTM D2240
ASTM D2240
ASTM E595
Outgassing CVCM (weight %)
TBD
ASTM E595
Europe: +49.8031.24600
Temperature Range
Rth at 1mm, 10 psi
-40°C to 150°C
0.119°C–in2/W
Laird Test Method
ASTM D5470
Asia: +86.755.2714.1166
Dielectric Constant at 1 MHz
TBD
ASTM D150
UL Flammability Rating
V-0 (pending)
USA: +1.866.928.8181
www.laird.com
Volume Resistivity
14
1.1X10 Ω.cm
UL 94
ASTM D257
*Preliminary release, all data subject to change
THR-DS-Tflex™ HD7.5 051622
Any information furnished by Laird Technologies, Inc. or any of its affiliates or agents (“Laird”) is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the
end user. Laird makes no warranties as to the fitness, merchantability, suitability or non-infringement of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products
are sold pursuant to the Laird’s Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2022 Laird Technologies, Inc. All Rights Reserved. Laird™, Laird Technologies™, the Laird Logo, and other marks are
trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. DuPont™ is a trademark or registered trademark of DuPont de Nemours, Inc. or an affiliate company thereof. Other marks may be owned by third parties. Nothing
herein provides a license under any Laird or any third-party intellectual property rights.
Thermal Gap Filler
Tflex HD7.5 Thermal Resistance vs Pressure
0.140
0.120
°C-in2/W
0.100
0.080
0.060
0.040
0.020
0.000
10 PSI
20 PSI
Tflex HD7.5 1.0mm
30 PSI
Tflex HD7.5 1.5mm
40 PSI
50 PSI
Tflex HD7.5 2.5mm
Tflex HD7.5 Deflection vs Pressure
120.0
% Deflection
100.0
80.0
60.0
40.0
20.0
0.0
5psi
10psi
20psi
30psi
Tflex HD7.5 1.0mm
Tflex HD7.5 4.0mm
40psi
50psi
60psi
TflexAxis
HD7.5
1.5mm
Title
Tflex HD7.5 5.0mm
70psi
80psi
90psi
Tflex HD7.5 2.5mm
100psi
AVAILABILITY
STANDARD THICKNESSES
1 mm (0.040”) up to 5 mm (0.200”) thick material available in 0.25mm (0.010”) increments
Available in standard sheet sizes of 18” x 18” and 9” x 9” or custom die cut parts.
OPTIONS
DC1 – Eliminate tack from one side
A1 – Adhesive on one side
PART NUMBER SYSTEM
Tflex™ indicates Laird elastomeric thermal gap filler product line. HD7.5 indicates high deflection 7.5 W/mk material. Thickness of sheet in mm is
listed after material name.
EXAMPLES:
Tflex™ HD7.5,1.00 =1.00mm thick for Tflex™ HD7.5 material
Tflex™ HD7.5,1.00,A1 =1.00mm thick for Tflex™ HD7.5 material with adhesive on one side
THR-DS-Tflex HD7.5 Data Sheet 05162022
Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end
user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or
consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2013 Laird Technologies,
Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third
parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
很抱歉,暂时无法提供与“A18444-09”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2785.205101+360.30880
- 10+2463.9439810+318.74877
- 25+2346.3503025+303.53623
