TRBLU24-00100-NA
TRBLU24-00100-NA
    LAIRD(莱尔德)
    Module
    MODULE BLUETOOTH
TRBLU24-00100-NA 数据手册
TRBLU24-00100 Embedded Bluetooth® HCI Module ® The Laird Embedded Bluetooth Module is specifically designed for applications that demand a robust and reliable Bluetooth connection. This product is designed with solder connections that allow the module to be mounted directly into your own designs and potted or enclosed within metal housing while exposing a high performance multilayer ceramic antenna. Key Features                USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2268.6567 wirelessinfo@lairdtech.com www.lairdtech.com/bluetooth Integrated antenna with up to 300 meter range Option for external antenna via u.FL variant Class 1 with +6 dBm transmit power (maximum) Current consumption less than 30 mA Version 2.0+ EDR Bluetooth Data transfer rates up to 3 Mbps Industrial -40°C to +85°C operating range Optimized for Windows CE USB or optional UART (H4, H5, BCSP) Piconet and Scatternet support Adaptive Frequency Hopping Wi-Fi coexistence support Bluetooth-approved Designed for rugged applications and potting Lead free – RoHS compliant Benefits             Fastest time to market Excellent range Rugged design Low power consumption Low cost of ownership Embedded system design Optimized for Microsoft Windows CE Supports encrypted data Industrial design for surface mount applications Flat mounting solder down board Potable without detriment to performance Extensive technical support The Host Controller Interface (HCI) is optimized to work with the Microsoft Windows CE embedded protocol stack and supports other HCI compliant Bluetooth stacks including Microsoft Windows XP Service Park 2 onwards. The interface allows the module access to the full range of features available from the Bluetooth version 2.0 specification from the CSR BlueCore BC4 chipset. TRBLU24-00100 Embedded Bluetooth® HCI Module FEATURE IMPLEMENTATION Bluetooth® Class 1 Frequency 2.402 – 2.480 GHz Max Transmit Power +6 dBm Low Power Hold, Sniff, Park Receive Sensitivity Better than -84 dB Range 300 m (free space) Interface HCI over USB or optional UART Lead Free RoHS compliant Physical Size 17.7 mm x 46.0 mm x 5.0 mm, 8 g Bluetooth Qualified Bluetooth 2.0+EDR Current Consumption Less than 36 mA Temperature Range -40 ˚C to +85˚ C Audio SCO and eSCO supported Piconet and Scatternet Supported Field Upgrades Supported Ordering Information TRBLU24-00100 Embedded Bluetooth HCI Module TRBLU24-00100-NA Embedded Bluetooth HCI Module –uFL connector for external antenna The details contained within the document are subject to change. Download the product specification from www.lairdtech.com/bluetooth for the most current specification. LWS-DS-TRBLU24_0713 Any information furnished by Laird and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird materials rests with the end user since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability, or suitability of any Laird materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird terms and conditions of sale in effect from time to time, a copy of which will be furnished upon request. For further information please visit our website at www.lairdtech.com. Alternatively contact wirelessinfo@lairdtech.com. Bluetooth® is a trademark owned by Bluetooth SIG, Inc., USA and licensed to Laird. © 2013 All Rights Reserved. Laird is a registered trademark of Laird, Inc.
TRBLU24-00100-NA 价格&库存
很抱歉,暂时无法提供与“TRBLU24-00100-NA”相匹配的价格&库存,您可以联系我们找货
