387004681
    LAIRD(莱尔德)
    ULTRATEC UTX SERIES, THERMOELECT
387004681 数据手册
UltraTEC™ UTX Series UTX11-12-F2-3030 A Thermoelectric Coolers The UltraTEC™ UTX Series is a high-performance thermoelectric cooler for demanding applications. The module is assembled with next generation thermoelectric material that has higher cooling capacity, temperature differential and efficiency than standard semiconductor materials. The UltraTEC™ UTX Series uses a large number of N and P couples to generate a higher heat flux density than standard thermoelectric coolers. This product often uses a liquid heat exchanger on the hot side to dissipate heat generated by a cooler. The series is available in multiple configurations and is ideal for spot cooling applications that require higher cooling capacities with limited surface area. FEATURES • • • • • • APPLICATIONS High heat pump density Precise temperature control Reliable Solid-State Operation No sound or vibration DC Operation RoHS Compliant • • • • Industrial Lasers Analytical Instrumentation Medical Diagnostics Laser Projectors *Specifications reflect thermoelectric coefficients updated December 2019 TECHNICAL SPECIFICATIONS* Hot Side Temperature (°C) Qmax (W) Delta Tmax (°C) Imax (Amps) Vmax (Volts) Module Resistance (Ohms) 27 93 72 10.9 14.6 1.18 LAPPING OPTIONS SUFFIX TA THICKNESS (PRIOR TO THINNING) 0.095” ± 0.001” FLATNESS & PARALLELISM 0.001” / 0.001” HOT FACE Lapped COLD FACE Lapped LEAD LENGTH 6.0” TB 0.095” ± 0.0005” 0.0005”/ 0.0005” Lapped Lapped 6.0” SEALING OPTIONS SUFFIX RT EP SEALANT RTV Epoxy COLOR White Black TEMPERATURE RANGE -60 to +204 °C -55 to +130 °C DESCRIPTION Non-corrosive, silicone adhesive sealant Low density syntactic foam epoxy encapsulant UTX11-12-F2-3030 0120 UTX11-12-F2-3030 Thermoelectric Coolers PERFORMANCE CURVES AT Th = 27° C MECHANICAL DRAWINGS Ceramic material 96% Alumina ceramics Solder construction: 138°C BiSn Operating tips • Max operating temperature: 80°C • Do not exceed Imax or Vmax when operating module • Reference assembly guidelines for recommended installation LTS-UTX11-12-F2-3030-DATASHEET www.lairdthermal.com Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective because of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2020 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights. UTX11-12-F2-3030 0120
387004681 价格&库存
很抱歉,暂时无法提供与“387004681”相匹配的价格&库存,您可以联系我们找货
  • 1+475.625531+56.89071
  • 5+447.025185+53.46975
库存:5
