UltraTEC™ UTX Series
UTX15-12-F2-4040
A
Thermoelectric Coolers
The UltraTEC™ UTX Series is a high-performance thermoelectric cooler for demanding
applications. The module is assembled with next generation thermoelectric material that has
higher cooling capacity, temperature differential and efficiency than standard semiconductor
materials. The UltraTEC™ UTX Series uses a large number of N and P couples to generate a
higher heat flux density than standard thermoelectric coolers.
This product often uses a liquid heat exchanger on the hot side to dissipate heat generated by a
cooler. The series is available in multiple configurations and is ideal for spot cooling applications
that require higher cooling capacities with limited surface area.
FEATURES
APPLICATIONS
High heat pump density
Precise temperature control
Reliable Solid-State Operation
No sound or vibration
DC Operation
RoHS Compliant
Industrial Lasers
Analytical Instrumentation
Medical Diagnostics
Laser Projectors
*Specifications reflect thermoelectric coefficients updated December 2019
TECHNICAL SPECIFICATIONS*
Hot Side Temperature (°C)
Qmax (W)
Delta Tmax (°C)
Imax (Amps)
Vmax (Volts)
Module Resistance (Ohms)
27
123
72
14.6
14.6
0.89
LAPPING OPTIONS
SUFFIX
TA
THICKNESS (PRIOR TO THINNING)
0.112” +/- 0.001”
FLATNESS & PARALLELISM
0.001” / 0.001”
HOT FACE
Lapped
COLD FACE
Lapped
LEAD LENGTH
6.0”
TB
0.112” +/- 0.0005”
0.0005”/ 0.0005”
Lapped
Lapped
6.0”
SEALING OPTIONS
SUFFIX
RT
EP
SEALANT
RTV
Epoxy
COLOR
White
Black
TEMPERATURE RANGE
-60 to +204 °C
-55 to +130 °C
DESCRIPTION
Non-corrosive, silicone adhesive sealant
Low density syntactic foam epoxy encapsulant
UTX15-12-F2-4040 0120
UTX15-12-F2-4040
PERFORMANCE CURVES AT Th = 27° C
MECHANICAL DRAWINGS
Ceramic material 96%
Alumina ceramics
Solder construction: 138°C BiSn
Operating tips
• Max operating temperature: 80°C
• Do not exceed Imax or Vmax when
operating module
• Reference assembly guidelines for
recommended installation
www.lairdthermal.com
LTS-UTX15-12-F2-4040-DATASHEET-1119
Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and
limitations Laird will, at its option, either repair or replace any part of its products that prove defective because of improper workmanship or materials. This limited
warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is
not to exceed five (5) years from the original date of the end product purchase.
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and
application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness,
merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird
products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request.
© Copyright 2020 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate
company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“387004688”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+478.153391+57.19307
- 5+449.376635+53.75101
- 10+437.5344010+52.33453
- 30+419.4015530+50.16562
- 50+411.2308550+49.18830
- 100+400.39288100+47.89195
