UltraTEC™ UTX Series
UTX9-28-F2-4040
A
Thermoelectric Coolers
The UTX™ Series is a high heat pumping density thermoelectric cooler. The module is
assembled with a large number of semiconductor couples to achieve a higher heat pumping
capacity than standard single stage thermoelectric coolers.
This product line is available in multiple configurations and is ideal for applications that require
higher cooling capacities with limited surface area. Assembled with Bismuth Telluride
semiconductor material and thermally conductive Aluminum Oxide ceramics, the UTX Series is
designed for higher current and larger heat-pumping applications.
FEATURES
APPLICATIONS
High heat pump density
Precise temperature control
Reliable Solid-State Operation
No sound or vibration
DC Operation
RoHS Compliant
Industrial Lasers
Analytical Instrumentation
Medical Diagnostics
Laser Projectors
*Specifications reflect thermoelectric coefficients updated December 2019
TECHNICAL SPECIFICATIONS*
Hot Side Temperature (°C)
Qmax (W)
Delta Tmax (°C)
Imax (Amps)
Vmax (Volts)
Module Resistance (Ohms)
27
179
72
9.3
33
3.14
LAPPING OPTIONS
SUFFIX
TA
THICKNESS (PRIOR TO THINNING)
0.110” +/- 0.001”
FLATNESS & PARALLELISM
0.0008” / 0.0016”
HOT FACE
Lapped
COLD FACE
Lapped
LEAD LENGTH
6.0”
TB
0.110” +/- 0.0005”
0.0005” / 0.0005”
Lapped
Lapped
6.0”
SEALING OPTIONS
SUFFIX
RT
EP
SEALANT
RTV
Epoxy
COLOR
White
Black
TEMPERATURE RANGE
-60 to +204 °C
-55 to +130 °C
DESCRIPTION
Non-corrosive, silicone adhesive sealant
Low density syntactic foam epoxy encapsulant
UTX9-28-F2-4040 0120
UTX9-28-F2-4040
PERFORMANCE CURVES AT Th = 27° C
MECHANICAL DRAWINGS
Ceramic material 96%
Alumina ceramics
Solder construction: 138°C BiSn
Operating tips
• Max operating temperature: 80°C
• Do not exceed Imax or Vmax when
operating module
• Reference assembly guidelines for
recommended installation
LTS-UTX9-28-F2-4040-DATASHEET
www.lairdthermal.com
Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and
limitations Laird will, at its option, either repair or replace any part of its products that prove defective because of improper workmanship or materials. This limited
warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is
not to exceed five (5) years from the original date of the end product purchase.
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and
application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness,
merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird
products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request.
© Copyright 2020 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or registered trademarks of Laird Inc. or an affiliate
company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“387004727”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 12+779.6288912+100.87472
