DVK-WB40NBT
DVK-WB40NBT
    LAIRD(莱尔德)
    SMD120模块
    802.11A/B/G/N MODULE
DVK-WB40NBT 数据手册
A Datasheet WB40NBT Version 3.12 WB40NBT Datasheet REVISION HISTORY Version Date Notes Approver 1.0 02/24/12 Initial Release Version. Andrew Chen 1.1 03/05/12 Changed RSTN to RESET. Andrew Chen 1.2 03/20/12 Resolved outstanding TBDs. Added AS/NZS (Australia, New Zealand) certifications. Updated AS/NZS links. Andrew Chen 1.3 6/29/12 Updated BT Transmit Power. Andrew Chen 1.4 7/5/12 Updated Receiver Sensitivity Values. Andrew Chen 2.0 10/2/12 Laird formatting and removal of schematic links to website. Andrew Chen 2.1 11/01/12 Changed Voltage Rise Time maximum from 5 ms to 100 ms. Andrew Chen 3.0 1/29/13 Updated Receive Sensitivity data Andrew Chen 3.1 1/30/13 Updated 5ghz channel and 5ghz frequency data Updated operating temperature data. Andrew Chen 3.2 3/4/13 Updated Pin Table. Changed Operating and Storage Humidity (Specs Table) Andrew Chen 3.3 4/26/13 Changed Operating and Storage Humidity (Specs Table) Andrew Chen 3.4 5/2/13 Updated Intro. Updated operating Linux kernel and version used for testing. Lowered Storage Humidity. Andrew Chen 3.5 17 May 13 Added BT Priority Important note to the Block Diagram. Andrew Chen 3.6 14 Oct 13 Removed references to summitdata.com Andrew Chen 3.7 11 Mar 14 Added Bluetooth SIG section. Jonathan Kaye 3.8 22 Oct 15 Added Approved By section to Revision History; fixed internal links Sue White 3.9 15 Aug 16 Changed Hardware Integration Guide to Datasheet Sue White 3.10 21 Feb 17 Updated FCC data to 24 non-overlapping channels Jay White 3.11 14 June 17 Updated the EU DoC for RED standards Tom Smith 3.12 20 June 2017 Changed EN 301 893 v2.1.0 (2017-03) to EN 301 893 v2.1.1 (2017-05) Tom Smith Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 2 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 WB40NBT Datasheet CONTENTS 1 Scope ..................................................................................................................................................................4 2 Product Description ............................................................................................................................................4 3 Block Diagram .....................................................................................................................................................5 4 Specifications ......................................................................................................................................................6 5 Electrical Characteristics.................................................................................................................................. 10 5.1.1 Absolute Maximum Ratings............................................................................................................. 10 5.1.2 Power Supply ................................................................................................................................... 10 5.1.3 Reset Characteristics ....................................................................................................................... 11 5.1.4 I/O Pin Characteristics (including UART interfaces) ........................................................................ 11 5.1.5 USB Transceiver Characteristics ...................................................................................................... 12 6 Pin Definitions ................................................................................................................................................. 13 7 Mechanical Specifications ............................................................................................................................... 18 7.1 Mounting ................................................................................................................................................. 18 8 Integration Guidelines ..................................................................................................................................... 19 9 Regulatory ....................................................................................................................................................... 19 9.1 Certified Antennas ................................................................................................................................... 19 9.2 Documentation Requirements ................................................................................................................ 20 9.2.1 FCC ................................................................................................................................................... 20 9.2.2 Industry Canada ............................................................................................................................... 22 9.2.3 European Union ............................................................................................................................... 23 Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 3 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 WB40NBT Datasheet 1 SCOPE This document describes key hardware aspects of the Laird SDC-WB40NBT wireless bridge module. This document is intended to assist device manufacturers and related parties with the integration of this module into their host devices. Data in this document are drawn from a number of sources including data sheets for the Broadcom BCM4329 and Atmel AT91SAM9G20 CPU. Please contact Laird or visit the Laird website to obtain the most recent version of this document: http://www.lairdtech.com/Products/WB40NBT 2 PRODUCT DESCRIPTION The SDC-WB40NBT Wireless Bridge Module is a wireless communications subsystem that may be integrated into a variety of host devices via a number of available electronic and logical interfaces. The SDC-WB40NBT provides complete enterprise-class Wi-Fi connectivity with an integrated TCP/IP stack, full support for IEEE 802.11a/b/g/n air standards and a fully integrated security supplicant providing 802.11i/WPA2 Enterprise authentication and data encryption. The SDC-WB40NBT has a wide variety of interfaces including Fast Ethernet, serial UART, USB, SPI and I2C. The wireless bridge may be configured, monitored and managed via a Command Line Interface over an available dedicated console port, via a web interface over a wireless or Ethernet interface, or via a remote SDK interface over wireless or Ethernet. The SDC-WB40NBT incorporates the Laird SDC-SSD40NBT radio module and provides all the Wi-Fi capabilities of that device. The product features an ARM9 processor running at 396 MHz, 32 MB of SDRAM memory, and 64 MB of NAND flash storage. Several GPIO lines are available for data acquisition and similar applications. The platform runs an embedded Linux operating system based on the 3.2 kernel. A Software Developer’s Kit with Application Programming Interfaces and software tools are available for the development of custom software applications on the device. The SDC-WB40NBT measures 47 mm long by 37 mm wide by 3 mm tall. The wireless bridge physically interfaces to the host device via a 120 pin board to board connector that has a variety of mating options. The SDCWB40NBT may be secured to the host device via available grounded mounting holes. The SDC-WB40NBT operates at temperatures between -30° to +80°C degrees Celsius. SDC-WB40NBT is a fully integrated module: It has its own RF shielding and does not require shielding provided by the host device into which it is installed in order to maintain compliance with applicable regulatory standards. As such, the device may be tested in a standalone configuration via an extender card. The SDC-WB40NBTprovides two unique U.FL type antenna connectors to support dual band transmit and receive diversity. Supported host device antenna types include dipole and monopole antennas. Regulatory operational requirements are included with this document and may be incorporated into the operating manual of any device into which the SDC-WB40NBT is installed. The SDC-WB40NBT is designed for installation into mobile devices which typically operate at distances greater than 20 cm from the human body and portable devices which typically operate at distances less than 20 cm from the human body. See “Documentation Requirements” for more information. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 4 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 WB40NBT Datasheet 3 BLOCK DIAGRAM The following is the SDC-WB40NBT block diagram: Note: Transmitter frequencies for Wi-Fi are 2412-2462 MHz and 5180-5805 MHz. Transmitter frequencies for BT are 2402-2480 MHz. The SDC-SSD40NBT block diagram displays the RF circuitry of the SDC-WB40NBT. Note: BT functions on the AUX port and not on the Main port. For Wi-Fi and BT single-antenna implementations, the AUX port must be used. IMPORTANT: When BT is transmitting high priority traffic (such as during a scan and/or when sending audio traffic) Wi-Fi receive is sent to the main antenna port (even when set to AUX only). When high priority transmission ends, Wi-Fi receive functionality returns to the AUX port (when set to AUX only). For optimal Wi-Fi performance, we recommend that you populate both the Main and the AUX ports with an antenna. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 5 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 WB40NBT Datasheet 4 SPECIFICATIONS Feature Physical Interface Ethernet Interface Asynchronous Serial Port Interfaces (3.3 V TTL interface) Synchronous Serial Port Interface Secure Digital I/O Interface Description Kyocera Elco Series 5046 120 Pin Connector P/N 24 5046 120 000 829+ (see Mounting Instructions for mating connector options) 10/100 Mbps RMII (Reduced Media Independent Interface) Nine-wire UART DCE with full modem signaling, ring indication, and carrier detect Four-wire UART with hardware handshaking Two-wire UART ( console) Six-wire Operating Temperature Operating Humidity Storage Temperature Six Wire Note: Cannot be used simultaneously with SPI interface Five Wire, Master and Slave modes supported Note: Cannot be used simultaneously with SDIO interface Two 12 Mbps USB Host Ports One 12 Mbps USB Device Port Two-wire I2C (Inter-IC) or CANbus (Controller-area Network) 2 Hirose U.FL connectors for dual-band antenna diversity, 50 ohm Laird SDC-SSD40NBT Atmel 400 MHz ARM 9, P/N AT91SAM9G20-CU Embedded Linux, 3.2 kernel 32 MB SDRAM 64 MB NAND flash 3.3 VDC ±5% (core) Mode Avg. Current Transmit 369 mA (1218 mW) 802.11a 167 mA (551 mW) Receive Standby 79 mA (261 mW) Transmit 392 mA (1294 mW) 802.11b 167 mA (551 mW) Receive Standby 79 mA (261 mW) Transmit 355 mA (1294 mW) 802.11g 167 mA (551 mW) Receive Standby 79 mA (261 mW) Transmit 802.11n (2.4 GHz) 324 mA (1069 mW) Receive 167 mA (551 mW) Standby 79 mA (261 mW) Transmit 802.11n (5 GHz) 359 mA (1185 mW) Receive 167 mA (551 mW) Standby 79 mA (261 mW) -30° to 80°C (-22° to 176°F) 10% to 90% (non-condensing) -30° to 85°C (-22° to 185°F) Storage Humidity 5% to 90% (non-condensing) SPI Interface USB Interfaces Two Wire Interface Antenna Interface Wi-Fi Interface Processor Chip Set Operating System Memory Storage Input Voltage Requirements Wi-Fi Current Consumption Note: These current consumption measurements were taken using Linux kernel version 3.2.0. Note: Standby refers to the radio operating in PM1 powersave mode. Note: During calibration and initialization the SDC-WB40NBT may reach a 700 mA peak, which only lasts several milliseconds. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless 6 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 WB40NBT Datasheet Maximum Electrostatic Discharge Length Width Thickness Weight Mounting Wi-Fi Media Wi-Fi Media Access Protocol Network Architecture Wi-Fi Standards Wi-Fi Data Rates Supported Modulation 802.11n Spatial Streams Regulatory Domain Support 2.4 GHz Frequency Bands 2.4 GHz Operating Channels Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/wireless Maximum Contact Discharge (CD): 4 kV Maximum Air Discharge (AD): 8 kV 47 mm (1.85”) Note: Length, width, and thickness measurements include the metal shielding. 37 mm (1.46”) 3.6 mm (0.14”) 7.8 g (0.275oz) Connector and Through Holes, See “Mounting” section for more information. Direct Sequence-Spread Spectrum (DSSS) Complementary Code Keying (CCK) Orthogonal Frequency Divisional Multiplexing (OFDM) Carrier sense multiple access with collision avoidance (CSMA/CA) Infrastructure and ad hoc IEEE 802.11a, 802.11b, 802.11d, 802.11e, 802.11g, 802.11h, 802.11i, 802.11n 802.11a (OFDM) 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11b (DSSS, CCK) 1, 2, 5.5, 11 Mbps 802.11g (OFDM) 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11n (OFDM, MCS 0-7) 6.5, 7.2, 13.0, 14.4, 19.5, 21.7, 26.0, 28.9, 39.0, 43.3, 52.0, 57.8, 58.5, 65.0, 72.2 Mbps BPSK @ 1, 6, 6.5, 7.2 and 9 Mbps QPSK @ 2, 12, 13, 14.4,18, 19.5 and 21.7 Mbps CCK @ 5.5 and 11 Mbps 16-QAM @ 24, 26, 28.9, 36, 39 and 43.3 Mbps 64-QAM @ 48, 52, 54, 57.8, 58.5, 65, and 72.2 Mbps 1 (Single Input, Single Output) FCC (Americas, Parts of Asia, and Middle East) ETSI (Europe, Middle East, Africa, and Parts of Asia) MIC (Japan) (formerly TELEC) KC (Korea) (formerly KCC) ETSI 2.4 GHz to 2.483 GHz FCC 2.4 GHz to 2.483 GHz MIC (Japan) 2.4 GHz to 2.495 GHz KC 2.4 GHz to 2.483 ETSI: 13 (3 non-overlapping) FCC: 11 (3 non-overlapping) MIC (Japan): 14 (4 non-overlapping) 7 © Copyright 2017 Laird. All Rights Reserved Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 WB40NBT Datasheet KC: 13 (3 non-overlapping) 5 GHz Frequency Bands ETSI 5.15 GHz to 5.35 GHz 5.47 GHz to 5.725 GHz FCC 5.15 GHz to 5.35 GHz 5.47 GHz to 5.725 GHz 5.725 GHz to 5.82 GHz MIC (Japan) 5.15 GHz to 5.35 GHz KC 5.15 GHz to 5.35 GHz 5.725 GHz to 5.82 GHz 5 GHz Operating Channels ETSI: 19 non-overlapping FCC: 24 non-overlapping MIC (Japan): 8 non-overlapping KC: 12 non-overlapping Maximum Transmit Power 802.11a 6 Mbps 16 dBm (40 mW) Note: Maximum transmit power 54 Mbps 14 dBm (25 mW) varies according to individual 802.11b country regulations. All values 1 Mbps 17 dBm (50 mW) nominal, +/-2 dBm. 11 Mbps 16 dBm (40 mW) 802.11g Note: Laird 40 series radios 6 Mbps 15 dBm (32 mW) support a single spatial stream 54 Mbps 13 dBm (20 mW) and 20 MHz channels only. 802.11n (2.4 GHz) 6.5 Mbps (MCS0) 15 dBm (32 mW) 65 Mbps (MCS7) 11 dBm (13 mW) 802.11n (5 GHz) 6.5 Mbps (MCS0) 16 dBm (40 mW) 65 Mbps (MCS7) 13 dBm (20 mW) Bluetooth 0 dBm (1mW) (Class 2) Typical Receiver Sensitivity 802.11a: 6 Mbps -90 dBm Note: All values nominal, +/-3 24 Mbps -84 dBm dBm. 54 Mbps -75 dBm (PER
DVK-WB40NBT 价格&库存
很抱歉,暂时无法提供与“DVK-WB40NBT”相匹配的价格&库存,您可以联系我们找货
