EVB-Z100S1AFR
EVB-Z100S1AFR
    LAIRD(莱尔德)
    ZIGBEE EVAL BOARD ROUTER-RS232,
EVB-Z100S1AFR 数据手册
ZB2430 Wireless Module Innovative Technology for a Connected World THE FASTEST WAY TO WIRELESS Based on Texas Intstruments’ leading edge 802.15.4 SoC & Z-Stack™ technology, the ZB2430 family of wireless modules is one of the most powerful ZigBee™-compliant solutions in the market today. It provides OEMs with industry-leading 2.4GHz module performance in low power conservation, ease of integration, range, features, and functionality. ZB2430 is ideal for power-restricted or battery-operated applications. Its receive and power-down performance offer OEMs the lower power consumption of any comparable transceiver module. Since it operates in the 2.4 GHz ISM band, the modules can be used globally--allowing OEMs to standardize on a single platform. Although the IEEE 802.15.4 (PHY & MAC) and ZigBee stack are industry standards, our flexible approach allows OEMs to customize a solution specific to application requirements. With the embedded Z-stack, ZB2430 is aimed squarely at secure, low-power mesh network applications. Modules are offered as Coordinators, Routers, End Devices or Commissioners. Network scan, remote configuration, dynamic routing, discovery, security…all unleash the full power of ZigBee. The Development Kit platform and test utility allow the OEM to explore the best of ZigBee straight out of the box. Features Applications • Outstanding power consumption • Automated meter reading • Reliable ZigBee™ mesh architecture • Irrigation systems • 2.4GHz ISM band for global applications • Medical devices • Temperature sensor • ePOS • Long-range performance • Configurable GPIO, ADC • Over-the-air download (OAD) firmware updating capability global solutions: local support USA: +1 800 492.2320 Europe: +44 1628 858 940 Asia: +852 2268 6567 wirelessinfo@lairdtech.com www.lairdtech.com/wireless TM ZB2430 Wireless Module Innovative Technology for a Connected World ZB2430 supports ZigBee’s MESH architecture. Each system consists of a Coordinator, Router, Commissioner and optional End Devices. Parameter Z100S1* Z040S1* Form Factor Surface Mount Surface Mount Coordinator Output Power 100mW 40mW Frequency 2400-2483.5 MHz 2400-2483.5 MHz Outdoor Range 4.8 km (ext antenna) 1.6 km (ext antenna) Indoor Range 400m 160m Receive Sensitivity -100 dB typical -100 dB typical Serial Data Rate Up to 115 bps Up to 115 bps Router RF Baud Rate 250 kbps 250 kbps a) Maintains routing tables b) Communicates with any device type c) Extends range of network by routing data over multiple hops Temperature Range -40˚ C to +85˚ C -40˚ C to +85˚ C Size 25.4mm x 39 mm x 3.6 mm 25.4mm x 39 mm x 3.6 mm Serial Interface 3V TTL 3V TTL a) One coordinator per network b) Scans to find available channel c) Establishes a network d) Maintains routing tables e) Communicates with any device type Power Consumption: End Device Tx 140mA@ 3.3V +18dBm 95mA@ 3.3V +14dBm a) Communicates with any device type b) Supports sleep modes c) Dedicated to parent (Router or Coordinator) Rx 44mA @ 3.3V 30mA @ 3.3V Sleep 7.6 uA 7.6 uA Antenna Options Integrated 2dBi ceramic antenna, u.FL connector for external antenna Integrated 2dBi ceramic antenna, u.FL connector for external antenna Approvals* FCC/IC CE Commissioner a) One Commissioner per network b) Server module for OAD firmware upgrades c) Required for OAD ability *for additional country approvals, contact us for more information. ORDERING INFORMATION Coordinator Router End Device Commissioner Coordinator Router End Device Commissioner Z100S1*FC Z100S1*FR Z100S1*FE Z100S1*FM Z040S1*FC Z040S1*FR Z040S1*FE Z040S1*FM * = A for integrated antenna; U for u.FL connector (external antenna) Development Kit – External antenna Development Kit - Integrated antenna Development Kit – External antenna, CE Development Kit - Integrated antenna, CE Development Kit – External antenna OAD Development Kit - Integrated antenna OAD Development Kit – External antenna, CE, OAD Development Kit - Integrated antenna, CE, OAD SDK-Z100S1UF SDK-Z100S1AF SDK-Z040S1UF SDK-Z040S1AF SDK-Z100S1UF-M SDK-Z100S1AF-M SDK-Z040S1UF-M SDK-Z040S1AF-M Development Kit include one Coordinator module, two router modules and two end devices. LWS-SPEC-ZB2430 0209 Contact information: USA: +1 800 492 2320 EUROPE: +44 1628 858 940 ASIA: +852 2268 6567 Any information furnished by Laird Technologies and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies materials rests with the end user since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability, or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies terms and conditions of sale in effect from time to time, a copy of which will be furnished upon request. For further information please visit our website at www.lairdtech.com. Alternatively contact: wirelessinfo@lairdtech.com. Bluetooth® is a trademark owned by Bluetooth SIG, Inc., USA and licensed to Laird Technologies. © 2009 All Rights Reserved. Laird Technologies is a registered trademark of Laird Technologies, Inc. EMAIL: wireless.systems@lairdtech.com
EVB-Z100S1AFR 价格&库存
很抱歉,暂时无法提供与“EVB-Z100S1AFR”相匹配的价格&库存,您可以联系我们找货
