Lantronix SLC 8000 (16 Ports USB, Dual AC)
SLC81162201S
SLC 8000 Advanced Console Manager, USB 16‐Port, AC‐Dual Supply Product Code: SLC81162201S
Future Proof Your Secure Out-Of-Band Management Solution with
Scalability and Flexibility
The Lantronix SLC 8000 advanced console manager is the industry's first modular console server that provides
secure remote access to IT equipment, while reducing deployment costs and time.
Centrally Monitor, Manage, and Troubleshoot
Designed for system administrators, quality and test engineers, the SLC 8000 provides easy, secure administration
and management of IT equipment from anywhere and at any time. Users can access the SLC 8000 device ports via
Telnet/SSH, or a web browser-based console client without any proprietary software. Any IT asset that provides
console or serial port management services can be managed remotely and locally with the same interface and
capabilities. The SLC 8000 enables users to leverage the command line interface of most IT equipment for
reconfiguring, rebooting and reloading firmware from a single point of contact. This can be done over an in-band
network with dual Gigabit Ethernet connections for both public and management networks, or through out-of-band
connections including dial-up (optional internal modem, sold separately) and cellular connectivity (PremierWave® XC
HSPA+ intelligent gateway, sold separately). The users can securely access and control a wide variety of IT and
network equipment, including Linux, Unix or Windows® servers, routers, switches, firewalls, PBXs, UPSs, and even
building access devices through their serial ports.
Modular Design
The modular design of SLC 8000 allows users to keep the main unit and simply add or swap modules to expand the
number of device ports, upgrade from a single power supply to dual, and easily introduce new serial interfaces such
as USB to support a combination of existing and new IT equipment that are connected. This reduces the time
required to develop and deploy new services, and this flexibility minimizes capital expenditures while offering easy
scalability and upgrades.
Integrated Security
Protecting IT resources is a top priority. The SLC 8000 provides security features such as SSL and SSH for data
encryption in addition to remote authentication for integration with other systems already in place. For added
protection, the SLC 8000 also includes firewall features to reject connection attempts or block ports and has NISTcertified AES encry
Advanced Modular Console Management Appliance in 1 Rack Unit Design
Console Management
• Provides 16 serial ports for console connectivity depending on option
• Dual Gigabit SFP ports with bonding capability
• Enables systems administrators to remotely monitor, manage and troubleshoot IT equipment from anywhere at any
time over the Internet
• Allows quality and test engineers to increase testing productivity with up to 15 concurrent connections per port
• Software reversible device port pins to eliminate cable clutter
• Provides port logging to local files, syslog, USB, SD card, and NFS share
• Console event notifications via email
• Offers web management interface with dashboard and CLI support
• Integrates with Lantronix PremierWave XC HSPA+ cellular connectivity accessory
• Integrates with SGX 5150 Wi-Fi connectivity accessory
Modular Design
• Enables port scalability and interface flexibility
• Provides field-upgradeable power supplies and I/O modules
• Reduces time and cost required to develop and deploy IT services
• Enables balanced CAPEX and OPEX management
• Front-mid-rear mounting brackets
Security and Authentication
• Secure Shell (SSH v1, v2, Public Key)
• Secure Sockets Layer (TLS v1.0, v1.1 and v1.2)
• Packet filtering (firewall)
• Per port user permissions
• Configurable user rights and custom groups
• Remote authentication: LDAP, Active Directory, NIS, RADIUS, Kerberos, TACACS+
• FIPS 140-2 compliance mode for enhanced security
Central Management
• Compatible with Lantronix’ vSLM central management solution
Input Power Redundancy
• Dual AC inlets allow for power redundancy and automatic failover
• Automatic power source switchover feature monitors both AC inputs and transfers power to secondary power
source if primary power is lost
http://store.lantronix.com/product_p/slc81162201s.htm/3‐15‐19
很抱歉,暂时无法提供与“SLC81162201S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+30260.513611+3901.16393
