ETHERLINE®
Uncontrolled copy
Cordsets, Cables, Connectors
Data communication systems for Ethernet technology
LAPP Industrial Data Communication (IDC) Stock Program
Flexible Industrial Ethernet Cordsets
These molded cordsets utilize high quality ETHERLINE® CAT.5e 4 pr flexible
cable with overmolded RJ45 connectors. For motion applications, these
cordsets are designed to provide interconnection between simple devices
(sensors and actuators) and high level devices (PLCs and computers)
Connector 1
Connector 2
RJ45 Shielded
RJ45 Shielded
Cable Length
Part number
0.5m
1m
2m
2.5m
3m
4m
5m
10m
15m
523359-0.5
523359-1
523359-2
523359-2.5
523359-3
523359-4
523359-5
523359-10
523359-15
Technical data
Material:
- contact carrier:
- molded head:
Rated voltage: 42V
125V (not for power applications)
polycarbonate
PVC; black (color is typical, not
standard)
gold-plated brass
foil & tinned copper braid
polyurethane; teal
polyethylene
- contacts:
- shield:
- cable jacket:
- conductor insulation:
Temperature range:
Rated current: 1.5A
Cable: 2170300
Conductor stranding:
-20°C to +70°C
stranded bare copper
Protection class: IP20
NEMA 1
Industrial Ethernet Cables
Part number
Category
Pairs
AWG
Application
Type
2170888
2170289
2170297
2170300
2170450
2140489
2170488
2170464
2170484
2170474
CAT 5
CAT 5e
CAT 5e
CAT 5e
CAT 5e
CAT 5e
CAT 6
CAT 6A
CAT 6A
CAT 7
2
2
4
4
4
4
4
4
4
4
22
26
24
24
22
26
26
22
24
22
Torsion
Cont. Flex
Stationary
Flexible
Flexible
Cont. Flex
Cont. Flex
Stationary
Cont. Flex
Stationary
Outer diameter
in
mm
0.256
0.240
0.248
0.240
0.380
0.248
0.307
0.343
0.355
0.343
6.5
6.1
6.3
6.1
9.6
6.3
7.8
8.7
9.0
8.7
Jacket
PUR
PUR
PUR
PUR
PVC
PUR
PUR
PVC
PUR
PVC
Description Detail
ETHERLINE® Torsion P CAT.5 2pr 22 AWG
ETHERLINE® FD P CAT.5e 2pr 26 AWG
ETHERLINE® P CAT.5e 4pr 24 AWG
ETHERLINE® P Flex CAT.5e 4 pr 26 AWG
ETHERLINE® Tray CAT.5e Y 4 pr 22 AWG
ETHERLINE® FD P CAT.5e 4 pr 26 AWG
ETHERLINE® FD P CAT.6 4pr 26 AWG
ETHERLINE® CAT.6A Y 4pr 22 AWG
ETHERLINE® FD P CAT.6A 4pr 24 AWG
ETHERLINE® CAT.7 4pr 22 AWG
Industrial Ethernet Connectors
Part number
Conductor size
Category
Conductors
CAT 5e
CAT 6A
CAT 6A
CAT 6A
CAT 6A
4
8
8
8
8
27 - 22 AWG (7 wire)
27 - 24 AWG (19 wire)
CAT 6A
CAT 6A
T568A
T568B
26 AWG (19 wire)
26 AWG (19 wire)
stranded
Cable outer diameter
solid
in
mm
Color Code
Description Detail
RJ45
21700605
21700600
21700601
21700615
21700616
24 - 22 AWG
PROFINET®
24 - 22 AWG
T568A
24 - 22 AWG 0.917 - 0.354 5.0 - 9.0
T568B
26 - 24 AWG
T568A
26 - 24 AWG
T568B
RJ45 - CAT.5e, field wireable, PROFINET®
RJ45 - CAT.6A, field wireable, T568A
RJ45 - CAT.6A, field wireable, T568B
26-24 AWG
26-24 AWG
RJ45 - CAT.6A, field wireable, 90 degree, T568A
RJ45 - CAT.6A, field wireable, 90 degree, T568B
RJ45 90 degree
21700639
21700640
0.217 - 0.394 5.5 - 10.0
T568A
T568B
M12
21700648
C5E203C
21700602
CAT 5
CAT 5e
CAT 6A
D-Coded 26 - 22 AWG (7 wire)
D-Coded
X-Coded 27 - 22 AWG (7 wire)
24 - 22 AWG 0.197 - 0.240 5.0 - 6.1
0.236 - 0.315 6.0 - 8.0
24 - 22 AWG 0.197 - 0.382 5.0 - 9.7
D-Coded M12-CAT.5, field wireable, D-Coded, Male, 4pos, TIA 568
D-Coded M12-CAT.5e, field wireable, D-Coded, Male, 4pos, PROFINET®
X-Coded M12-CAT.6A, field wireable, X-Coded, Male, 8pos
PROFINET® is a registered trademark of the PNO (PROFIBUS User Organization).
If not otherwise specified, all values relating to the product are nominal values.
Photographs are not to scale and are not true representations of the products in question.
for current information see: www.lappusa.com • www.lappcanada.com
很抱歉,暂时无法提供与“523359-1”相匹配的价格&库存,您可以联系我们找货
