523359-15
523359-15
    LAPP(缆普)
    IE RJ45 PATCH CABLE 15M CAT 5E
523359-15 数据手册
ETHERLINE® Uncontrolled copy Cordsets, Cables, Connectors Data communication systems for Ethernet technology LAPP Industrial Data Communication (IDC) Stock Program Flexible Industrial Ethernet Cordsets These molded cordsets utilize high quality ETHERLINE® CAT.5e 4 pr flexible cable with overmolded RJ45 connectors. For motion applications, these cordsets are designed to provide interconnection between simple devices (sensors and actuators) and high level devices (PLCs and computers) Connector 1 Connector 2 RJ45 Shielded RJ45 Shielded Cable Length Part number 0.5m 1m 2m 2.5m 3m 4m 5m 10m 15m 523359-0.5 523359-1 523359-2 523359-2.5 523359-3 523359-4 523359-5 523359-10 523359-15 Technical data Material: - contact carrier: - molded head: Rated voltage: 42V 125V (not for power applications) polycarbonate PVC; black (color is typical, not standard) gold-plated brass foil & tinned copper braid polyurethane; teal polyethylene - contacts: - shield: - cable jacket: - conductor insulation: Temperature range: Rated current: 1.5A Cable: 2170300 Conductor stranding: -20°C to +70°C stranded bare copper Protection class: IP20 NEMA 1 Industrial Ethernet Cables Part number Category Pairs AWG Application Type 2170888 2170289 2170297 2170300 2170450 2140489 2170488 2170464 2170484 2170474 CAT 5 CAT 5e CAT 5e CAT 5e CAT 5e CAT 5e CAT 6 CAT 6A CAT 6A CAT 7 2 2 4 4 4 4 4 4 4 4 22 26 24 24 22 26 26 22 24 22 Torsion Cont. Flex Stationary Flexible Flexible Cont. Flex Cont. Flex Stationary Cont. Flex Stationary Outer diameter in mm 0.256 0.240 0.248 0.240 0.380 0.248 0.307 0.343 0.355 0.343 6.5 6.1 6.3 6.1 9.6 6.3 7.8 8.7 9.0 8.7 Jacket PUR PUR PUR PUR PVC PUR PUR PVC PUR PVC Description Detail ETHERLINE® Torsion P CAT.5 2pr 22 AWG ETHERLINE® FD P CAT.5e 2pr 26 AWG ETHERLINE® P CAT.5e 4pr 24 AWG ETHERLINE® P Flex CAT.5e 4 pr 26 AWG ETHERLINE® Tray CAT.5e Y 4 pr 22 AWG ETHERLINE® FD P CAT.5e 4 pr 26 AWG ETHERLINE® FD P CAT.6 4pr 26 AWG ETHERLINE® CAT.6A Y 4pr 22 AWG ETHERLINE® FD P CAT.6A 4pr 24 AWG ETHERLINE® CAT.7 4pr 22 AWG Industrial Ethernet Connectors Part number Conductor size Category Conductors CAT 5e CAT 6A CAT 6A CAT 6A CAT 6A 4 8 8 8 8 27 - 22 AWG (7 wire) 27 - 22 AWG (7 wire) 27 - 22 AWG (7 wire) 27 - 24 AWG (19 wire) 27 - 24 AWG (19 wire) CAT 6A CAT 6A T568A T568B 26 AWG (19 wire) 26 AWG (19 wire) stranded Cable outer diameter solid in mm Color Code Description Detail RJ45 21700605 21700600 21700601 21700615 21700616 24 - 22 AWG PROFINET® 24 - 22 AWG T568A 24 - 22 AWG 0.917 - 0.354 5.0 - 9.0 T568B 26 - 24 AWG T568A 26 - 24 AWG T568B RJ45 - CAT.5e, field wireable, PROFINET® RJ45 - CAT.6A, field wireable, T568A RJ45 - CAT.6A, field wireable, T568B RJ45 - CAT.6A, field wireable, T568A RJ45 - CAT.6A, field wireable, T568B 26-24 AWG 26-24 AWG RJ45 - CAT.6A, field wireable, 90 degree, T568A RJ45 - CAT.6A, field wireable, 90 degree, T568B RJ45 90 degree 21700639 21700640 0.217 - 0.394 5.5 - 10.0 T568A T568B M12 21700648 C5E203C 21700602 CAT 5 CAT 5e CAT 6A D-Coded 26 - 22 AWG (7 wire) D-Coded X-Coded 27 - 22 AWG (7 wire) 24 - 22 AWG 0.197 - 0.240 5.0 - 6.1 0.236 - 0.315 6.0 - 8.0 24 - 22 AWG 0.197 - 0.382 5.0 - 9.7 D-Coded M12-CAT.5, field wireable, D-Coded, Male, 4pos, TIA 568 D-Coded M12-CAT.5e, field wireable, D-Coded, Male, 4pos, PROFINET® X-Coded M12-CAT.6A, field wireable, X-Coded, Male, 8pos PROFINET® is a registered trademark of the PNO (PROFIBUS User Organization). If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. for current information see:  www.lappusa.com • www.lappcanada.com
523359-15 价格&库存
很抱歉,暂时无法提供与“523359-15”相匹配的价格&库存,您可以联系我们找货
