CTL-SW-MC
CTL-SW-MC
    LASCAR
    接近/占位传感器 无源红外线 继电器 天花板,墙壁
CTL-SW-MC 数据手册
CTL-SW Infrared Proximity Switch • 4cm pre-set* detection range • Red / green status light • 9.6 to 24VDC supply • 15mA standby current • 25mA active current Active Standby The CTL-SW is a touchless infrared proximity switch, which sits inside a Ø22mm natural anodised aluminium shell. Easily and reliably activated without contact, this proximity switch has a pre-set* detection range of 4cm. The CTL-SW has onboard LED’s showing red when the switch is in standby and green when activated. The momentary action is pre-set* to 10 seconds. SPECIFICATIONS Sensor type Infrared Panel cut out diameter 22-23mm Detection range 4cm* Required electrical supply 9.6 to 24VDC Operating current 15mA (standby) 25mA (active) Relay contact rating 1A 125VAC/2A 30VDC Contact resistance 100 mOhm LED colour Red (standby) Green (active) Ingress (IP) rating IP67 Impact (IK) Rating IK10 Operating temperature -30°C to +70°C Minimum number of operations 1,000,000 * The switch has 5 variables that can be user programmed. Contact www.lascarelectronics.com today to discover more. Body material Aluminium alloy Lens material Polycarbonate Length of wires provided 175mm FOUR MODELS IN THE RANGE • • • • CTL-SW-MC (Normally Closed) CTL-SW-MO (Normally Open) CTL-SW-LC (Normally Closed) CTL-SW-LO (Normally Open) Momentary Touchless Infrared Proximity Switch Momentary Touchless Infrared Proximity Switch Latching Touchless Infrared Proximity Switch Latching Touchless Infrared Proximity Switch CTL-SW Infrared Proximity Switch EXAMPLE WIRING DIAGRAM Wiring Red: 9.6V to 24V Black: Ground Yellow: Common White: Normally Closed Green: Normally Open Normally Closed (Part Number: CTL-SW-MC) Positive (+) RED Power Supply Negative (-) BLACK COM Alarm Control Panel (N.C. Input) YELLOW N.C. Output WHITE Normally Open (Part Number: CTL-SW-MO) Positive (+) RED Power Supply Negative (-) BLACK YELLOW COM Door Strike Power Supply + Electric Door Strike Diode MOV N.O. Output GREEN Normally Closed (Part Number: CTL-SW-LC) Positive (+) RED Power Supply Negative (-) BLACK COM Alarm Control Panel (N.C. Input) YELLOW N.C. Output WHITE Normally Open (Part Number: CTL-SW-LO) Positive (+) RED Negative (-) BLACK COM Power Supply YELLOW N.O. Output GREEN Compatible with the PanelPilot range of displays www.lascarelectronics.com Issue 4 11/2022 Door Strike Power Supply + Electric Door Strike Diode MOV
CTL-SW-MC 价格&库存
很抱歉,暂时无法提供与“CTL-SW-MC”相匹配的价格&库存,您可以联系我们找货
CTL-SW-MC
  • 1+319.207651+41.28223
  • 5+306.085155+39.58514
库存:26
