EL-MOTE-ULT+
EL-MOTE-ULT+
    LASCAR
    Temperature Datalogger
EL-MOTE-ULT+ 数据手册
EL-MOTE-DULT+ Your data, anytime, anywhere High Accuracy, Dual Channel Ultra Low Temperature Cloud-Connected Cryogenic Vaccine Data Logger • Measurement range -100 to +100°C (-148 to +212°F) • High accuracy T-type probe on 2m cable • Records and uploads temperature data to the EasyLog Cloud • Access live temperature data via any Internet Browser or the EasyLog Cloud App • Set up alarm options for temperature zone breaches – email alerts, beeper alarms or LED flash alerts • Battery life of up to 2 years The EL-MOTE-DULT+ is designed to monitor vaccines in cryogenic dry ice storage. Products in the EL-MOTE range are simple to set-up and easy to use. Download the EasyLog Cloud App and set-up a device in minutes over your WiFi network. After set-up, the device can be placed anywhere within range of the WiFi network, continually monitoring and recording your data to the EasyLog Cloud. Access your data on any Internet Browser or the EasyLog Cloud App, enabling you to monitor the temperature of your chosen location from anywhere at any time. EL-MOTE devices can be programmed with high and low temperature alarm zones. If a temperature zone is breached, an alarm will be activated. Alarm options include: email alerts (which can be sent to one or multiple email addresses), beeper sound alarms, and LED flash alerts. EL-MOTE devices can be powered using the supplied batteries or a mains adapter (sold separately), and are provided with a wall mountable bracket for installation. With EasyLog’s brand new range of smart probe enabled data loggers, such as the EL-MOTE-DULT+, there is no need to take your product out of action and send it away for re-calibration for what can often be weeks. When it comes time to re-calibrate your data logger, simply order a new pre-calibrated smart probe, which you can immediately swap in for your old one. When setting up your logger, make sure you select the T-Type probe. www.lascarelectronics.com/data-loggers Issue 1 12/2020 Page 1 of 2 EL-MOTE-DULT+ Your data, anytime, anywhere High Accuracy, Dual Channel Ultra Low Temperature Cloud-Connected Cryogenic Vaccine Data Logger Logger Specification Minimum Typical Battery Life Maximum Unit 2* Battery Type years 4 x 1.5V AA cells Operating Temperature (Powered by Batteries Supplied) Operating Temperature (Mains Adapter Powered) -18 (-0.4) +55 (+131) -20 (-4) Temperature measurement range +60 (+140) ˚C (range) (˚F (range)) 0.1 (0.2) ˚C (˚F) Logging Period (User Configurable) 10 sec 10 min 12 hrs Transmission Period (User Configurable) 1 min 1 hour 24 hours Accuracy Probe Dimensions ˚C (˚F) -100 to +100 (-148 to +212) Resolution Dimensions ˚C (˚F) ±1.8 (±3.2) C (˚F) 93 x 93 x 32 (3.7 x 3.7 x 1.3) mm (inches) 300 x Φ 1.5, 2m cable (11.8 x Φ 0.05, 39.3 cable) mm (inches) IP Rating 67 The sensor is IEEE 802.11bgn (2.4GHz) compliant, supports WEP, WPA/WPA2 encryption and enterprise networks (PEAP, TTLS, FAST). * Battery life is dependent on: transmission period, WiFi encryption method, WiFi encryption key rotation frequency (determined by the router/access point), signal strength between router/access point and WiFi device, presence, volume and type of WiFi traffic from other devices, sample rate and operating temperature. Logging period and transmission period can be configured in Settings via the EasyLog Cloud App. 211-140401 CONTAINS FCC ID: YOPGS2011MIZ Probe tips must be kept electrically isolated. If metal sheathed probes are used, check that the sheath is isolated from the probe junction. If it is not or you are using an unsheathed probe, ensure that the probe tip is insulated. WHAT’S IN THE BOX? WHAT EXTRA ACCESSORIES ARE AVAILABLE? PART NUMBER DESCRIPTION PART NUMBER DESCRIPTION EL-MOTE WALL BRACKET Wall Mounting Bracket for EL-MOTE Device EL-MOTE-PSU Mains Power Adapter BATTERIES 1.5V AA x 4 EL-P-TC-T-ULT+ Replacement T-type thermocouple probe EL-P-TC-T-ULT+ x 2 Thermocouple probes EL-MOTE WALL BRACKET Wall Mounting Bracket for EL-MOTE Device Specifications liable to change without prior warning CALIBRATION CERTIFICATES NOW AVAILABLE EasyLog offers a Traceable Calibration Certificate Service on Temperature Data Loggers using reference equipment which has been calibrated by a UKAS/NIST/HKAS or CNAS accredited laboratory and using apparatus traceable to national or international standards. For more information please see www.lascarelectronics/calibration Issue 1 12/2020 Page 2 of 2
EL-MOTE-ULT+ 价格&库存
很抱歉,暂时无法提供与“EL-MOTE-ULT+”相匹配的价格&库存,您可以联系我们找货
EL-MOTE-ULT+
    • 1+2310.012541+299.94364
