EL-WiFi-ULT+
High Accuracy, Ultra Low Temperature
Cryogenic Vaccine WiFi Data Logger
Your data, anytime, anywhere
• Measurement range -100 to +100°C (-148 to +212°F)
• High accuracy T-type probe on 2m cable
• Wirelessly stream and view data on the EasyLog Cloud,
App or on a PC
• View and analyse multiple sensors, including graphing of
historic data
• Configurable high and low alarms with indicator
• Easy sensor set-up using free PC software or App
The EL-WiFi-ULT+ is designed to monitor vaccines in cryogenic
dry ice storage.
Data is streamed wirelessly over any compatible WiFi network and can be viewed on a PC using free software or on the EasyLog
Cloud or App.
To configure the sensor for use on a given wireless network, either connect it via USB to a PC running EasyLog WiFi software on
the network, or configure wirelessly using the EasyLog Cloud app on a mobile phone with access to the network. The sensor
can then be placed anywhere within range of the network. If the sensor temporarily loses connectivity with the network, it will
log readings until it is able to communicate again with the PC application or EasyLog Cloud (max 30 days at 10 second sample
interval).
The sensor is IEEE 802.11bgn* (2.4GHz) compliant, supports WEP, WPA/WPA2 encryption and enterprise networks (PEAP, TTLS, FAST).
EL-WiFi-ULT+ has a protection rating of IP40. The unit is freestanding, but can be attached to a wall or surface using the bracket
provided. The unit can be clipped in and out of the bracket as required.
SPECIFICATIONS
Minimum
Typical
Battery life
Temperature measurement range
Maximum
>6
-100 (-148)
USB supply voltage (@500mA)
4.5
5.0
Months
+100 (+212)
°C (°F)
5.5
Vdc
+60 (+140)
°C (°F)
Operating temperature range
-20 (-4)
Logging period (user configurable)
10 sec
10 min
12 hrs
Transmission period
(user configurable)
1 min
1 hr
24 hrs
resolution
0.1 (0.2)
Temperature display resolution
Dimensions
°C (°F)
0.1
Accuracy
IP Rating
Unit
±1.8 (±3.2)
°C (°F)
IP40
(Bung fully inserted, not permanently powered, thermocouple connector fitted and fully inserted, device mounted
vertically.)
ACCESSORIES
PSU-5VDC-USB-USA
USB Mains Power
Adapter for USA
PSU USB-UK
USB Mains Power
Adapter for UK
PSU USB-EU
USB Mains Power
Adapter for EU
EL-P-TC-T-ULT+
Replacement T-type
Thermocouple probe
INCLUDED IN THE BOX
EL-WIFI WALL
BRACKET
Wall mounting bracket
for EL-WiFi sensors
EL-P-TC-T-ULT+
Thermocouple probe
CABLE USB A-MICRO B USB Type A to Micro B
82 x 70 x 23mm (3.22 x 2.75 x 0.91”)**
Probe dimensions
300 x Φ 1.5mm, 2m cable
(11.8 x Φ 0.05, 39.3” cable)
* MAC Address starting 98:8B:AD:2....... only
** Excluding probe and mounting bracket
CALIBRATION CERTIFICATES NOW AVAILABLE
Lascar now offers a Traceable Calibration Certificate Service on Temperature Data Loggers. Using reference equipment
which has been calibrated by a UKAS/NIST
accredited laboratory and using apparatus traceable to national or
www.lascarelectronics.com/data-loggers
international standards. For more information please see www.lascarelectronics.com.
Issue 1 01/2021 Page 1 of 2
EL-WiFi-ULT+
EasyLog Software
Lascar’s WiFi software* is available as a free download from:
www.lascarelectronics.com/software/easylog-wifi. Easy to install and use,
EL-WiFi-WIN allows easy connection of sensors to a WiFi network. The user
can select where data is stored - the PC or the Cloud.
When setting up your logger, make sure you select the T-Type probe.
Battery Life and Power Supply
The battery can be recharged (unit must be between 0 - 40°C) via a PC, a USB +5V wall adapter, or a portable USB battery pack
using the USB lead provided. It can also be permanently powered by a USB wall adapter or USB battery pack. Readings may be
affected while the internal battery is being charged. However, once charged, continued connection of the charger will have no
effect.
Battery life is dependent on: transmission period, WiFi encryption method, WiFi encryption key rotation frequency (determined by
the router/access point), signal strength between router/access point and WiFi device, presence volume and type of WiFi traffic
from other devices, sample rate and operating temperature.
Specifications liable to change without prior warning
*Requires Windows 7, 8.1, 10
Issue 1 01/2021 Page 2 of 2
很抱歉,暂时无法提供与“EL-WIFI-ULT+”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3180.394271+411.31146
- 国内价格 香港价格
- 1+2579.895551+333.65065
