EL-WiFi-21CFR-DULT+
High Accuracy, 21CFR Dual Channel
Ultra Low Temperature Cryogenic
Vaccine WiFi Data Logger
Your data, anytime, anywhere
• Can be installed as part of a 21CFR compliant system with additional controls
including permission-based use, authority level sign-off and full system audit
• Measurement range -100 to +100°C (-148 to +212°F)
• High accuracy T-type probe on 2m cable
• Wirelessly stream and view data on the 21CFR Cloud
• Configurable high and low alarms with indicator
• Easy sensor set-up using free 21CFR WiFi Sensor Software
The EL-WiFi-21CFR-DULT+ is designed to monitor vaccines in cryogenic dry ice
storage, in accordance with 21CFR part 11 data security standards.
Data is streamed wirelessly over any compatible WiFi network to be viewed on
the 21CFR Cloud. During configuration, the sensor will search for an existing
wireless network whilst physically connected to the PC. It can then be placed anywhere within range of the
network. If the sensor temporarily loses connectivity with the network, it will log readings until it is able to communicate
again with the 21CFR Cloud (max 30 days at 10-second sample interval).
The sensor is IEEE 802.11bgn* (2.4GHz) compliant, supports WEP, WPA/WPA2 encryption and enterprise networks (PEAP, TTLS,
FAST).
The EL-WiFi-21CFR-DULT+ has a protection rating of IP40 and the probe tip IP67. The unit is freestanding, but it can be attached
to a wall or surface using the bracket provided. The unit can be clipped in and out of the bracket as required.
ACCESSORIES
SPECIFICATIONS
Minimum
Typical
Battery life
Maximum
>6
-100 (-148)
Temperature measurement range
USB supply voltage (@500mA)
4.5
5.0
°C (°F)
5.5
Vdc
+60 (+140)
°C (°F)
Operating temperature range (logger)
-20 (-4)
10 sec
10 min
12 hrs
Transmission period
(user configurable)
1 min
1 hr
24 hrs
0.1 (0.2)
Temperature display resolution
IP Rating
±1.8 (±3.2)
°C (°F)
Logger IP40, Probe Tip IP67
(Bung fully inserted, not permanently powered, thermocouple
connector fitted and fully inserted, device mounted vertically.)
Dimensions (Display)
82 x 70 x 36mm (3.22 x 2.75 x 1.41”)**
Probe dimensions
USB Mains Power
Adapter for USA
PSU USB-UK
USB Mains Power
Adapter for UK
PSU USB-EU
USB Mains Power
Adapter for EU
EL-P-TC-T-ULT+
Replacement T-type
Thermocouple probe
°C (°F)
0.1
Accuracy
PSU-5VDC-USB-USA
Months
+100 (+212)
Logging period (user configurable)
Temperature measurement resolution
Unit
300 x Φ 1.5mm, 2m cable
(11.8 x Φ 0.05, 39.3” cable)
* MAC Address starting 98:8B:AD:2....... only. **Excluding mounting bracket.
INCLUDED IN THE BOX
EL-WIFI WALL
BRACKET
Wall mounting
bracket for EL-WiFi
sensors
2 x EL-P-TC-T-ULT+
Thermocouple
probe
CABLE USB A-MICRO B USB Type A to Micro B
21CFR COMPLIANCE
Permission based use and access
Authority based action sign-off
Data records cannot be edited or deleted
Complete system audit trail
For a detailed compliance checklist, please visit www.lascarelectronics.com/markets/21cfr/
CALIBRATION CERTIFICATES NOW AVAILABLE
Lascar now offers a Traceable Calibration Certificate Service on Temperature Data Loggers. Using reference equipment
which has been calibrated by a UKAS/NIST accredited laboratory and using apparatus traceable to national or
www.lascarelectronics.com/data-loggers
international standards. For more information,
please visit www.lascarelectronics.com/calibration.
Issue 1 12/2020
Page 1 of 2
EL-WiFi-21CFR-DULT+
21CFR WIFI SENSOR SOFTWARE
EasyLog 21CFR WiFi software* is available as a free download from
download.filesthrutheair.com. Easy to install and use, EasyLog 21CFR WiFi Sensor Software
allows easy sensor set-up and connection of sensors to a WiFi network and the 21CFR Cloud.
21CFR CLOUD
21CFR Cloud subscription delivers all of the flexibility of a remote monitoring system:
Interact with sensors via any internet-enabled device; manage and monitor sensors;
access event logs and set up email alerts; assign authorisation levels to user accounts and
view comprehensive audit trail records. Unlike the standard EasyLog Cloud service, 21CFR
Cloud includes other controls such as permission-based use, authority sign-off and full system audit to ensure data monitored
and collected is regulated to 21CFR Part 11 standard.
For full pricing information and to create an account, please visit https://21cfr.wifisensorcloud.com/. Any queries or questions,
please do not hesitate to contact our team.
Detailed data reporting
Detailed system audit reporting
Authority sign-off on actions
A Cloud account subscription is created during the WiFi sensor set-up process using EasyLog 21CFR WiFi Sensor Software. 21CFR
WiFi Sensors are only compatible with the 21CFR Cloud 21cfr.wifisensorcloud.com.
When setting up your logger, make sure you select the T-Type probe.
Download the latest version of the software free of charge from download.filesthrutheair.com
Battery Life and Power Supply
The battery can be recharged (unit must be between 0 - 40 °C) via a PC, a USB +5V wall adapter, or a portable USB battery
pack using the USB lead provided. It can also be permanently powered by a USB wall adapter or USB battery pack. Readings
may be affected while the internal battery is being charged. However, once charged, continued connection of the charger will
have no effect.
Battery life is dependent on: transmission period, WiFi encryption method, WiFi encryption key rotation frequency (determined
by the router/access point), signal strength between router/access point and WiFi device, presence volume and type of WiFi
traffic from other devices, sample rate and operating temperature.
Specifications liable to change without prior warning
*Requires Windows 7, 8.1, 10
Issue 1 12/2020
Page 2 of 2
EL-WIFI-21CFR-DULT+ 价格&库存
很抱歉,暂时无法提供与“EL-WIFI-21CFR-DULT+”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5407.230181+700.07458
